Part #: cobb9C1800
Manufacturer: COBB Tuning
Description: Cobb 09 Nissan GT-R Coilover Sleeve System
COBB Tuning Coilover Sleeve System: COBB Tuning�s new Coilover Sleeve System gives you the ability to customize the ride height of your vehicle while retaining the factory adjustable shock absorbers. Suspension movement has also been enhanced by replacing the stock rubber bushings with teflon-lined FK spherical-bearing top mounts that allow for full articulation of the suspension while maintaining linear spring movement.
Handling is dramatically improved by utilizing more aggressive front and rear springs with a helper springs in combination to keep the rear spring seated through the full range of motion. Custom spring rates are also available.
Part #: kw25385006
Manufacturer: KW
Description: KW H.A.S. Nissan GT-R Skyline (R35)
KW Coilover Sleeves: KW Automotive Coilover Sleeves offer height adjustment for use with EM or aftermarket shocks. This budget-minded option does not include shocks as other KW Automotive coilovers include but still offer height adjustment.
