Detailed en543pm's GT-R(120 pics)
36 replies to this topic
#1 Wes_R Posted 07 June 2009 - 08:11 PM
Wes_R
  • 97 posts
I honestly don't know how to start this so let's just get straight into it.
So I was contacted initially for advice on how to deal with the swirls with the Porter Cable, Optimum Polishes, and some Lake Country Pads but along the conversation when I mentioned how long it would take we just decided that I would take it on. Problem now was it was gonna be a 2 week wait cause I was already booked up and the anticipation was killing me, I was really excited to spend time with godzilla.
Upon the GT-Rs arrival I had a chance to properly inspect the paint with my Sun Gun. At first in my mind I honestly thought that just a 1 step or 2 step polish at the most would be needed but taking a closer shocked look I realized that this was gonna need a full paint correction.
Anyway, here we go hopefully you guys enjoy the pics and possibly catch some tips.
Lets start with the basics. I don't approach a vehicle with anything on my clothing that could accidently scratch the car for example zippers, a belt buckle, watch, rings, etc.
Got in and backed it out.
And here she is.
My routine is to start with the wheels and engine generally because if you have already washed the car and then have to do either you will get the car dirty all over again.
Sprayed p21s Wheel Gel on the rims and tires. What's great about this wheel cleaner is it is non-acidic, meaning if you got ceramic brakes they won't damage them as say an acid based wheel cleaner would.
Let those soak and sprayed Meguiars All Purpose Cleaner cut 50/50 with water into the wheel well and let those sit and eat into the grime while I moved onto the engine.
Engine was not to bad at all just dusty at the most so nothing hardcore here other then a Meguiars All Purpose Cleaner spray, light rinse off, a blow dry with my Chemical Guy's Blow Dryer, and then dressed it with Meguiars Hyper Dressing cut 25/75 water. Turned on the engine and let the engine warm up for about 10 minutes or so.
Before
After
Now addressed the wheels with my E-Z Brush which is pretty cool cause it can be bent so that you can get it into different places. I really love the way these 2 pics with the E-Z Brush turned out!
Now this is what the rim should look like after using the brush properly.
Did the rim face with a microfibre mitt solely dedicated for the rims, which I prefer cause on those stubborn spots I can really apply some hard pressure.
Finally after all of that on to the washing. Chemical Guys Citrus Wash + Gloss was the car soap cut to strip anything they may have been on the car's surface, I forget the ratio to be honest.
Two Bucket Method. One soapy water the other just water for rinsing so you don't contaminate the soapy water with dirt.
Started rinsing off the car to wash off as much as I could of any loose debris. Bottom line the less dirt on your car when you start washing means that there will be less dirt that may get potentially dragged on the paint causing swirls.
Sheepskin wash mitt this time starting with the roof.
After each panel or even half a panel you should be rinsing off your mitt in the water only bucket. The reason you do this is because you do not want to be using one bucket and dragging that same dirt filled water all over the paint causing swirls. Common sense and pretty simple no, but surprisingly people don't do it. Also you may have to rinse along as you go cause this will make washing a little longer.
Also forgive me for not being able to explain this next part it is just habit now already that I learnt  years ago but hopefully someone can cover for me. All panels facing the sky should be done back and forth like in this pic hopefully you can see the pattern of the suds.
And all side panels should be up and down. The bottom half should be saved for last as usually those sections are the dirtiest.
Did the final rinse down and dried the car using a waffle weave towel. This towel is far superior to a chamois because of a couple things, they absorb water alot faster,  they have these pockets which dirt or dust blown on the car can escape into and not be dragged on the paint, and I could go on and on but you get the point if you have or get one I am sure you can find more things to appreciate about them.
Finally finished. Some may think that shines nicely but I am not finished with this car yet.
Pulled it into my garage and got ready to clay with Riccardo Clay yellow.
My last bar.
Now if your planning on claying your own car without any polishing involved and it is not a mild clay like Sonus Green Clay, you are gonna get clay bar marring but general proper clay bar procedure is to avoid the cold. What you can do is have something with high lubricity like Megiuars Last Touch cut 50/50 with warm water to help you out but sometimes it just can't be avoided.
Oh yeah and the reason you clay is because even though you have washed your car there are still tiny debris that get embedded into your clearcoat called surface contaminants that only a clay bar can sheer out. If after you wash your car and run your hand along the paint you will notice that it still feels rough(even new cars that get rail dust from being transported by train) but after a good clay bar only a baby's skin feels more smooth then your paint, honestly.
Started claying and it was not bad at all as expected but as usual some lower parts on the door  were a little bad and the whole back end had quite a bit.
Claying the hood.
Nothing really.
After the clay barring I want to mask the car with blue painters tape to protect rubber trim from being burnt. I like using two kinds of width.
It's 3M tape and the product number is 2090 which is medium adhesion, nothing to strong.
Here are some pics of the masking.
Put the thick tape over the edge of the clear bra.
And now time to measure the paint with a paint thickness gauge for any possible low spots and also to report to the owner if any panels have been repainted(I never thought anything would be repainted here though but just to look out for low spots).
Measured the paint in microns which is a thousandth of a millimeter or .001 of a mm. Generally in my experience OEM is 100 to 130 microns.
Measurements were looking healthy and very consistent around 140 more or less with maybe only 2 or 3 panels showing 130 or 150.
Even though I am only showing one measurement per panel what I am actually doing per panel is doing at least 10 more or less measurements. It's kind of weird but I kind of imagine the paint as a plain and imagine the different grooves of where it is high and low kind of like a field with hills.
Anyway with all the prep work finally out of the way we can now begin polishing. Imagine and no disrespect to anyone but if you go to a hack shop they just wash your car and get straight into polishing, it's kind of scary especially if you prize your car and have to leave it in their hands what is happening to your baby.
So back to things here is what I was pretty much dealing with under 500 watt halogen lighting.
I went straight into it with Menzerna Super Intensive Polish, a 6.5 orange Lake Country Pad, the Meguiars Solo Backing Plate, and the Makita Rotary.
I used the Zenith Point Technique where 5 beads the size of a skittle were spread out at 600rpm, broken down at 1200rpm, then polished until clear at around 1700rpm. Then back down the scale from 1700rpm to 1500rpm, and then refined at around 1100rpm over a 12 x 18 area.
Here are some before and afters.
Before
After
A 50/50 shot with the right side polished and the left side not.
A shot of me polishing.
Before
After
Another 50/50
Before(this one was bad)
After
Before
After
Before(this one was pretty bad to)
After
Before
After
Edited by Wes_R, 08 June 2009 - 06:52 AM.
#2 Wes_R Posted 07 June 2009 - 08:13 PM
Wes_R
  • 97 posts
So after the cutting stage I also polished the tail lights as they had swirls on them as well but with a forced rotation dual action polisher(the new Flex 3401). Here are some before and afters.
Before
After
Before
After
Now after all that was said and done the hard part comes. Chasing all what is called rds or rids random deep scratches or random isolated deep scratches by wetsanding. Now just a 2 step polish will get the paint in the 95% range more or less perfected(which is in my opinion perfectly fine for a daily driver) but deeper stuff will be left behind. How deep the scratches are varies some you can feel with your nail others you can't but with spot wetsanding you can either get them out completely or at the least round off the edges so that the sunlight is dispersed in a way to not make them so noticeable or not noticeable at all even though they may be there.
Now excuse me please because 1 this was very labour intensive and 2 my photography skills are not on a level to capture these fine scratches.
The process was to wetsand with either 2000 or 2500 grit then cross hatch sand with 3000 grit. Basically when you sand with either 2000 or 2500 grit you sand in the motion vertically then go back over with 3000 and go horizontally to cross hatch making polishing out the wetsanding marks easier.
Here is a rid.
Wetsanding it out.
And gone.
Here are some during shots. I honestly just wanted to get it done and spent a good couple hours going through this process.
Now with that tedious stage done I could finally jewel the paint, but first a couple things.
Unmask
Dust out the crevices.
And finally an alcohol wipe down. The reason you do this is because the polishes contain oils that can fill very very light scratches so the wipe down allows you to properly check your work.
So alcohol cut 50/50 with water wiped on with a plush microfibre cloth, and a 3M Sun Gun were used to check my work.
The Sun Gun for those that don't know omits they same spectrum light as the sun and I believe is 99.3% similar. There are some reflections in the paint that may seem like something but are not.
Finally the last stage of polishing which is the jeweling or burnishing stage which is a very light cutting polish and light cutting pad which burnish the paint to a very high gloss(they don't do this at the factory).
Tools for this job were my new Flex 3401 which I have been dying to use and this is the first time, Menzerna P085RD, and a white Lake Country pad.
A during shot.
Some amazing reflection shots!
Look at the gloss and there isn't even a wax on yet.
After spending a couple hours refining the paint another alcohol wipe down was done not only to inspect for defects but to also create a clean surface for the wax to bond to.
Wax of the day was Swissvax Concorso. For dark colors a carnuba based wax gives on amazing glow but for light colored cars I suggest a sealant like Zaino Z2 or Werkstatt.
Your supposed to apply it by hand because it is heat activated but I just warm my applicator every panel(this stuff is not cheap you know).
I let the wax cure for about an hour or so, so in the mean time I did other things like polish the mufflers.
I did that with Meguiars Super Degreaser and 0000 steel wool to clean it up, then polished with Meguiars NXT All Metal polish. Here are some before and afters.
Before
After
Here is a closer look of the driver's side.
And the passenger's side.
I also put Poor Boy's Wheel Sealant on the rims to protect against brake dust and also on the newly polished mufflers.
No pics but I applied Blackfire Long Lasting Tyre Gel to the tires.
After everything I finally wiped off the wax, sealant, and cleaned the windows.
And now ladies and gentlemen.... the eye candy.
It was cloudy which was great and not so great cause the sun was playing hide seek but I was getting some beautiful cloud reflections.
Tree reflection shot( a Brazo thing, UK detailer joke)
This pic is so cool!
My signature reflection shot.
Another tree shot.
Gloss, clarity, shine, everything looking perfect.
Sun came out for a bit so I raced around to get shots of the sun on the paint to show no swirls.
And finally my favorite shot.
I also got to go for a little cruise around my block.
Got to feel some g-force go through my body and experience the torque and braking power.
Dropped back home and there goes a shiny black GT-R.
Thank you very much to the owner for allowing to me to spend time with this awesome machine.
Hope you guys enjoyed the write up and any comments good, bad, or ugly are welcome.
Cheers!
Wes
Edited by Wes_R, 28 July 2009 - 12:22 PM.
#3 rsfootball Posted 07 June 2009 - 08:21 PM
rsfootball
  • R35 Member
  • 2,039 posts
WOW...great work.
2009 Nissan GTR Blk/Blk Premium-Delivered July 31 2008
(SP Engineering w/GReddy USA)SPE GODZILLA PKG+
GReddy Turbo Kit /SPE Modified Billet Turbos , 4.3L GReddy Stroker Kit
Big Thanks to Volk, WPC, Dodson, KW Suspension, & to a special machine shop in Japan.
Very slow 1/4mile times. Praying to go faster...
#4 Keller Posted 07 June 2009 - 08:32 PM
Keller
  • 1,135 posts
Wow, how long did that all take?
You for hire :headshake:
Great job!!
2013 White GT-R
2010 SS GT-R (Sold)
2009 GM GT-R (Sold)
#5 Gdzilla_ Posted 07 June 2009 - 08:43 PM
Gdzilla_
  • 680 posts
f*ckin' awesome!!  great job wes... reminds me of why i try and not acquire anymore black cars..ha
i also got your back on the 'all panels that face the sky'.. i do the same...  don't know why either, but i think it has some sort of aerodynamic purpose.. :headshake:
Delivered September 8th 2008...
2009 GTR R35 Premium... Ivory Pearl/Black...
#6 davidm_sh Posted 07 June 2009 - 09:08 PM
davidm_sh
  • 953 posts
:headshake:
That is simply the most amazing looking black car work up I have seen (both end product and write up/pics!!) Awesome job!
#7 Nex Posted 07 June 2009 - 10:04 PM
Nex
  • 142 posts
Great job!!
+1
:cheers:
#8 en543pm Posted 07 June 2009 - 10:30 PM
en543pm
  • 399 posts
I have to give Wes total props for the job he did.  I was stunned when I got to see my car again.  An amazing job as the pictures show.
Wes has ambition and he has a dream.  He's a big fan of the GTR and a supporter of the  GTR community.  He's a good guy.  I hope we can all help him achieve his dream.
Thank you Wes.
2009 Black/Black Canadian Spec. SOLD!
Advan F7's
Blizzaks for winter
T1R Mid-pipe
AAM Competition Downpipes
HKS Legamax Exhaust
HKS Superfire Spark Plugs
AMS Z Store Pulley
Custom Cobb Tune from AAM
Carbotech Pads
Clear Bra
iPod
Rear View Camera
Boomerang
#9 iWantOne Posted 07 June 2009 - 10:37 PM
iWantOne
  • NAGTROC Newbie
  • 32 posts
Awesome! I'm saving this thread in my favorites.  I looked at a black GTR this weekend and although I was all for the Ivory Pearl, black just adds that extra mean ness to the car.  The only thing I was worried about was keeping it clean, scratches etc.  After this post I'm sold on the black.....thanks!!!!
'-- Nissan GTR (Soon, I hope)
'07 Cadillac Escalade (SOLD)
'07 Cadillac CTS-V (Lease Trade In)
'05 Infiniti G35 Coupe (SOLD)
'03 Le Mans Sunset 350Z (SOLD)
'96 civic-GSR (SOLD)
I got that Car Fetish
#10 Wes_R Posted 08 June 2009 - 06:37 AM
Wes_R
  • 97 posts
View Postrsfootball, on Jun 7 2009, 10:21 PM, said:
WOW...great work.
Thank you  :).
You for hire :cheers:
Great job!!
Over 25hrs.
I wish I could but we are expecting my second so I can't go to far.
Thank you very much.
i also got your back on the 'all panels that face the sky'.. i do the same...  don't know why either, but i think it has some sort of aerodynamic purpose.. :)
Your missing out on the black cars, but white cars are still cool to  :).
I have to research that again so I can give a proper explanation
View Postdavidm_sh, on Jun 7 2009, 11:08 PM, said:
:jawdrop:
Thank you very much  :).
View PostNex, on Jun 8 2009, 12:04 AM, said:
+1
:helpsmilie:
lol however I can help just let me know.
Thank you Wes.
I really appreciate it, your a great guy aswell. lol at my GT-R fantasies.
Cheers :cheers:
Glad I could help, feel free to pm me on any advice you may need as I can point you in the right direction.
#11 Toronto GTR Posted 08 June 2009 - 06:53 AM
Toronto GTR
  • 738 posts
Hi Wes R great job...I am always amazed how good the black looks when it is done properly.
The write up was great - loved all the pics....a job well done.
2009 GT-R Premium Dark Gun Metallic/Black
"Bring whatever you like to the party. The GT-R will blitz it. It blitzes everything." Clarkson
#12 clintb Posted 08 June 2009 - 08:10 AM
clintb
  • NAGTROC Newbie
  • 40 posts
VERY NICE INDEED
Nissan should hire you to do every car before it's delivered
Do Ferrari/Lambo dealers prep a car like this before sale?
i'm amazed how much you know about this stuff !!!  Very impressive
which of these steps would you recommend for the average guy who wants to wash his car on the weekend?
and what should we be doing 1x/month when we "polish"?
Clint
#13 rcalcaide Posted 08 June 2009 - 08:38 AM
rcalcaide
  • 865 posts
Wes R,
Excellent work. Detailing is truly an art form, and you my friend are an artist. Paint correction has to be done properly and its not about hiding swirls with OTC products. Very many GT-R owners or high end car owners know little about what a experienced detailer can bring to the table.
Again excellent work! Now Im gonna go detail my car again!
R
#14 ESCUE Polo Posted 08 June 2009 - 09:33 AM
ESCUE Polo
  • 1,787 posts
OMGGGGGGGGG. i will fly u down to florida if u can do that to mine! looks fantastic.  alot of time spent.  i wouldnt let my car leave the garage if it was that clean!
Tuned by Jack Cecil @ HorsePower Logic
#15 Wicked Posted 08 June 2009 - 12:25 PM
Wicked
  • Site Moderator
  • R35 Owner
  • 2,087 posts
very informative bro........thanks for the info......
SPI Stage 1 Motor Build
SPI Stage 1 Tranny Build
SPI 90mmSS Exhaust = Loud as Fawk!!
AKA Forum Moderator 2 (Previous Nick: **DMG Godzilla**)
#16 NickTO Posted 08 June 2009 - 02:45 PM
NickTO
  • SpecV Member
  • 3,593 posts
Wes,
The enthusiasm for your work in this writeup and level of professionalism (and attention to detail) we're able to see speaks for itself.  Absolutely stunning.
You will be the only person other than me to detail my car!!!
Anytime to want to show a GT-R, you know how to reach me!
#17 Toronto GTR Posted 08 June 2009 - 05:48 PM
Toronto GTR
  • 738 posts
I am with Nick - I am already planning a "spring cleaning" each year as it comes out of storage, and Wes will be the first call.
There IS an art form to detailing and over the years I have taken my cars to various shops...this surpasses anything I have seen done.
That black looked like a damn mirror...it will not be as dramatic with my DMG but a job done like this each spring will make the car look new (hell better than new).  Keep up the good work.  I sent your name to my dealer in case any of the other owners come in asking - a job like that deserves the referal.
Edited by Toronto GTR, 08 June 2009 - 05:50 PM.
#18 Wes_R Posted 11 June 2009 - 02:52 PM
Wes_R
  • 97 posts
Thank you, black taken care of right definitely is amazing
View Postclintb, on Jun 8 2009, 10:10 AM, said:
VERY NICE INDEED
Clint
To be honest I am not sure if Lambo/Ferrari does this for their deliveries.
I would suggest the washing tips.
Once a month would just be waxing, after a medium to aggressive correction polish maintaining the car properly(good washing technique) you should only need a light 1 step polish a year.
I can actually recommend a great guy in your area.
View Postrcalcaide, on Jun 8 2009, 10:38 AM, said:
Wes R,
R
I try to avoid fillers as much as possible but sometimes it does make sense.
I am glad you recognize it as an art form.
When things settle down here I may take you up on your offer.
I'm glad you got to learn something.
View PostNickTO, on Jun 8 2009, 04:45 PM, said:
Wes,
I am honored and may quote you on that for my website or something.
I am not sure what I am gonna do yet in terms of that and how my budget goes but we will definitely be in touch.
I look forward to it!
DMG may not reflect as strong as dark colors but the gloss and shine will definitely be strong.
And thank you very much for the referal.
#19 Wicked Posted 12 June 2009 - 04:32 PM
Wicked
  • Site Moderator
  • R35 Owner
  • 2,087 posts
Gotta find myself an E Z brush....cleaning the rims once a week manually is a pain........
#20 dtectproject Posted 13 June 2009 - 12:44 AM
dtectproject
  • 459 posts
beautiful result. refreshing to see work done to such a high level of professionalism/artistry.
...and thanks for the detailed account of your process, definitely gives me the tools required to quench my OCD when it comes to detailing my car.
'09 Premium DMG: VR.G2's (HMB), CBRD midpipe, STATUS Racing carbon Ring seats
