#6
Mar 6, 2015
Bump including a rear set of calipers that need to be rebuild for $2800 total pads rotors and calipers.
#8
Mar 12, 2015
13,000 miles issue is the rear of the car had a caliper fire. so the rears will need to be rebuilt !
#10
Mar 12, 2015
Hot pit fire?
I've had two up front due to clag pick up in the rotor/caliper area - always carry an extinguisher.
GLWS!
0
Reply
#9
Mar 12, 2015
I have the car fax and the title of the car they came off of !
#13
Mar 12, 2015
only kept the brembos as a part of a retrofit for an R33 GT-R caliper kit I bought. now I need TE37's 18in rims since I did this.
#21
Mar 15, 2015
(8.7mm) Fronts , rears 9mm pad thickness factory OEM Brembo brake pads !
0
Reply
#16
Mar 13, 2015
Just wear...debating if its worth it to make an offer on the pads.
#17
Mar 13, 2015
I'm firm on the pads front and rear shipped in the lower 48's. will send you a measurement on the pads.
#19
Mar 13, 2015
You want $3300 for the pads, or were you including rotos?
You have insufficient privileges to reply here.
