Re remembering logging parameters, we are building a feature list at the moment for ProECU and this feature is on the list. Interested if you have any others you'd like...aside from live tuning and end user tuning abilities. The kind of things I'm interested in are the blue skies stuff...so if I start you off with a few along the lines I'm thinking...voice activated map switching; auto logging when a fault is detected and so on...let me have your ideas.
Either Mac based support, or complete integration of an app. I don't know about others, but If i logged into an app, and was able to send maps right through my phone, I would pay double for ecutek. Just my .02
Hi, yes, Richard Lamb at Aquamist already has a set up for the BRZ using our software, and with Phase 5 it is also possible to set this up for the GT-R using Custom Maps. You could run a simple on/off closed loop system or a more sophisticated system with a flow meter connected. And with Phase 5 you could use it with or without 12 injectors.
And for whatever reason, everytime I try and log a ROM, I have to manually remove the MAF channels, and add in AFR Bank 2. Every time I click on "save default template" or whatever its called - it never takes
i believe this might have been asked before, the possibility of putting the car into neutral via pulling on both paddle shifters at the same time. I believe lambo/ferrari have this feature? I really don't see added value besides a cool factor but figured I'd just through it out there.
Rolling boost with one button without the need to have to set the speed, this would work as follows:
Turn on Cruise Control
Press and Hold the Cancel button
Mash gas pedal, boost starts building
Let go off the Cancel button and HOLD ON
ideality would be nice to be able to do this, for roll racing events setting the speed when your opponent is NOT a GT-R it makes it very hard to keep pace. I know is possible because I have seen it setup this way on one of the earlier BETA releases of Phase 5 so come on just make it available on the public release PLEASE ?
Ok think I've got the message on simplified rolling boost and also re the Mac OS version, although ProECU is stable and does work well through bootcamp
The adjustable gear shifts, is this 3D against PPS?
Also is it possible to have different shift up points to the downshift points? e.g. 2nd up to 3rd at 2500rpm, but 3rd down to 2nd at 2000rpm?
Gear shift maps are 2D: PPS and road speed as far as I am aware and with our TCM update, you can adjust the upshift and downshift point for the same gear independent of each other so you can do what you are asking.
I second the improved rolling boost
Also, how about removing the brake-throttle override so we can do left foot braking without the throttle being cut. More of a problem on the newer cars: http://www.gtrlife.c...aking-via-tune/
Hi Goonthree. This is currently possible using Custom Maps. Have a chat with your tuner and if he says not possible, ask him to contact support at EcuTek
^^ Yes, boot camp works well and i dont NEED Mac OS, but it would be nice not to have to reboot every time i log data. I can live with the current setup, but you asked
1. The ability for some of the parameters to be displayed in a larger format (digital gauges would be awesome) so they can be monitored on a daily level for those running tablets that are mounted in the car. Talking with a friend he said he would love to see fuel pressure, fuel temp, afr left, afr right, iat and knock correction.
2. The ability to record DTC's with time stamps as a file since there is storage capability with laptops and tablets. That way if you clear them, there is still a record of the DTC. Even with Cobb, I would always take a picture with my cell phone first before I erased it just in case it was relevant info I need to pass onto my tuner or for own tracking purposes.
1. Get rid of the vexing USB key. There are other reliable authentication/authorizations means out there that don't require me keeping track of something that is a pain in the ass to use with tablet computers and can be lost easily.
1.1 Ability to run the software without the USB key (so I can look at logs and such)
2. +1 for mac compatibility
3. +1 for mobile device integration -- think Cobb AP without needing a proprietary device -- would make logging so much easier
4. Fuel pressure monitoring as a built-in feature without needing custom maps
5. User tunability (limited)
6. Live tuning
7. Knock sensitivity scaling based on Ethanol content
1. Support for 2015 model year to see the Oil Temp range. This is not working at the moment.
2. Be able to clear the temp ranges the car has seen (the 1-5 ranges and the frequency)
We figured this one couldn't wait - @JimA, @GT-R_Nova, @GT-Rpilot, @Mr. G, @GZILA850 testing late on Friday night (the guys emerged out the dyno looking as though they had just walked off the set of The Revenant) has delivered you Simplified Rolling Boost. Just doing some more testing but should be available next week just in time for TX2K. It will work as you all want it as per JimA's specification.
Related Threads
Nissan GT-R Forum
1.7M posts
66.9K members
Since 2004
