STFT Failure (Help)
nissan gtr loss loss of power no boost troubleshoot stft failure stft fuel cut fbo
42 replies to this topic
#1 majj35
majj35
  • 1,122 posts
Posted 03 March 2017 - 11:51 AM
Updated.
I'm hoping for help and input while I work on finding shop(s)/appointments etc..and parts to order. I DAILY my 2014 FBO on flexfuel for 2+ years now. I barely run on e85. been a year i haven't. Always on pump 93.
2 years ago, I got a CEL and checked my accessport showing:
-P0138 - O2 Sensor circuit high voltage (Bank 1 Sensor 2)
-P0139 - O2 sensor slow response (Bank 1 Sensor 2)
-P0158 - O2 Sensor circuit high voltage (Bank 2 Sensor 2)
-P0159 - O2 Sensor slow response (Bank 2 Sensor 2)
I cleared the codes and never got it again for 2 years, until recently. In the past 2 months, I've been getting the same codes (not all 4 together-varies) probably 5-6 times (2-3 days apart after clearing codes).
Before these codes starting showing up more often, I drove one night on an empty strip on manual.. floored from 2nd to 5th ran fine. On my way back, the boost cuts at 4K rpms and car won't accelerate even when pedal is fully pressed. But no CEL. I stop for a second and its back to normal.
I noticed this keeps happening when I accelerate over 4K rpms, and shift up... then won't pass 4K. Using cobb I had the following Limp Status: 02 (which is STFT failure). Also STFT ranges from 85%-125%. I ran a datalog to send to tuner...just waiting to get a cable. I lost it lol.
in the meantime .. until I send the datalogs. I would appreciate any help so I could speed things up.  is this just a fuel pump failure that needs to be replaced? is it caused by the O2 sensor that ive been ignoring lol? Thanks!
Edited by majj35, 29 March 2017 - 11:55 AM.
2014 Black Edition | Alpha 7
FBO • FlexFuel
Engine:    Alpha Street fmic | Sakura 3" intakes | Asnu 1100cc | Asnu 330lph | Visconti FlexFuel v2
Exhaust: Alpha Downpipes | Cobb Midpipes | HKS Legamax Titanium
Exterior: Rexpeed K-style Splitter | Rexpeed Skirts | Difflow Fins | '15 Lights | 3M Trunk Wrap
Interior:  DCT Steering Wheel | COBB ApV3-005
Wheels: Advan RS-D 20x9.5/20x10.5 | TiTek Lugs | Eibach Spacers 15F/20R | Pzero 285/295
603whp/605wtq (pump 93)
646whp/661wtq (e85)
1968 Camaro SS 350V8 (for sale)
Instagram: @gwynethbluepearl
#2 Wicked
Wicked
    R35 Owner
  • Site Moderator
  • 6,676 posts
Posted 03 March 2017 - 12:22 PM
Safety trip?
Switzer Stage 1 Motor Build
Switzer Stage 1 Tranny Build
#3 majj35
majj35
  • 1,122 posts
Posted 03 March 2017 - 01:24 PM
Safety trip?
not sure what that is
FBO • FlexFuel
646whp/661wtq (e85)
#4 Wicked
Wicked
    R35 Owner
  • Site Moderator
  • 6,676 posts
Posted 03 March 2017 - 01:48 PM
Did you log the events?
#5 majj35
majj35
  • 1,122 posts
Posted 03 March 2017 - 03:31 PM
I haven't since it goes back to normal once I park the car or fully stop
FBO • FlexFuel
646whp/661wtq (e85)
#6 majj35
majj35
  • 1,122 posts
Posted 05 March 2017 - 06:36 PM
Limp status 2... any idea?? Sent from my iPhone using Tapatalk
FBO • FlexFuel
646whp/661wtq (e85)
#7 iamnotthestig
iamnotthestig
  • 325 posts
Posted 05 March 2017 - 06:48 PM
boost leak maybe? not bad enough to affect the car at idle, but once you hit boost, it bleeds off all the pressure?
#8 majj35
majj35
  • 1,122 posts
Posted 05 March 2017 - 07:11 PM
It did that same issue again, loss of power and wont go past 4k rpms. Then i go on auto mode and its back to normal
FBO • FlexFuel
646whp/661wtq (e85)
#9 AndyR35
AndyR35
  • 633 posts
Posted 06 March 2017 - 12:46 PM
Have you run a check with the AP for any codes?
#10 majj35
majj35
  • 1,122 posts
Posted 06 March 2017 - 02:10 PM
yeah i had the Accessport running. No codes or CEL came up. Dynamic ADV was -1/0  , and limp status 0/2   ( but not at the same time)
FBO • FlexFuel
646whp/661wtq (e85)
#11 yianni
yianni
  • 541 posts
Posted 11 March 2017 - 08:53 AM
I had a similar issue and it was a secondary pump failure Sent from my SM-G930V using Tapatalk
#12 GODzilla LIN
GODzilla LIN
  • 191 posts
Posted 11 March 2017 - 04:56 PM
Last time it happen to me, my intake tube was not tight and loose air, check all bolts to be secure. But this is me tho....
Have you done any installs after this happen?
2015-GTR Black on Red simply FBOs Ecutek tuned by Ben Linney 700HP;616WHP/634TQ 93pump gas on DYNOCOM @ 90"F Temp.
#13 majj35
majj35
  • 1,122 posts
Posted 16 March 2017 - 07:44 AM
I've been on this setup for almost 2 years now. This is the first time it happens... no installs have been done since.
FBO • FlexFuel
646whp/661wtq (e85)
#14 majj35
majj35
  • 1,122 posts
Posted 16 March 2017 - 07:45 AM
Oem or aftermarket pumps?
FBO • FlexFuel
646whp/661wtq (e85)
#15 tjlazer
tjlazer
  • 3,224 posts
Posted 16 March 2017 - 02:01 PM
You need to log the Safety trip to see if that is what it is.  Cobb has a Safety feature that will do as you describe if anything exceed the safety levels set by tuner.  It will pull power to protect the engine.
2010 Nissan GT-R Pearl White Premium
2009 Nissan 370Z Nismo Monterey Blue
#16 majj35
majj35
  • 1,122 posts
Posted 17 March 2017 - 11:21 AM
Is that an option i can choose to log? Because i found "Limp Status" cant remember if safety trip was on the list
FBO • FlexFuel
646whp/661wtq (e85)
#17 tjlazer
tjlazer
  • 3,224 posts
Posted 17 March 2017 - 01:32 PM
That's it
#18 majj35
majj35
  • 1,122 posts
Posted 20 March 2017 - 01:54 PM
That's it
I'll try to datalog, but when i had the accessport running w safety limp it said 2
FBO • FlexFuel
646whp/661wtq (e85)
#19 haul s
haul s
    I Haul Ass
  • 1,097 posts
Posted 20 March 2017 - 10:00 PM
You're tripping STFT safety (see https://cobbtuning.a...t/view/78610496 for other safety codes).
Yep, either a pump is on its way out, or the post-filter finally got plugged up.
Either way, I see a Visconti fuel basket in your future. ;)
2014 Nissan GT-R Black Edition - haulin' ass!
2004 Audi B6 S4 Sedan MT6 - SOLD - OG ass hauler
Brilliant Red, Black/Silver
#20 majj35
majj35
  • 1,122 posts
Posted 21 March 2017 - 08:15 AM
Hi, thanks thats very helpful. Could you please educate me more.. lol  I currently have 1100cc ASNU injectors and ASNU 330lph pumps... which pumps are you talking about?
I might be going for service this weekend, is it an oem part replacement or.. what do I need? Thanks !
note: I haven't used e85 for over a year now. I've had the injectors/pumps for almost 2yrs now.
Edited by majj35, 21 March 2017 - 08:22 AM.
FBO • FlexFuel
646whp/661wtq (e85)
