weird behavior after putting down pipes!
13 replies to this topic
#1 GTRHOLIC
GTRHOLIC
  • 236 posts
Posted 12 March 2017 - 04:12 AM
So after I put my catless down pipes, I got this annoying weird noise with somewhat pressurized flow when I rev @ mid range for a moment then it goes away after i pass flooring that area.. is this normal with catless down pipes ?
i'm with catless mid pipes too (stock exhaust )
Thank you ..
Edited by GTRHOLIC, 12 March 2017 - 04:13 AM.
#2 AndyR35
AndyR35
  • 632 posts
Posted 12 March 2017 - 06:05 AM
What does it sound like and at what rpm?
#3 GTRHOLIC
GTRHOLIC
  • 236 posts
Posted 12 March 2017 - 06:35 AM
Deep rasp with a sense of a pressurized flow ..
it happens @ ~ 4k give or take ..
#4 AndyR35
AndyR35
  • 632 posts
Posted 12 March 2017 - 08:45 AM
Probably just the change from cats to decat. As you are probably aware the lack of restriction means more volume and vibrations that you don't get from cat oem pipes. I take it you have had the car tuned for the deletion of the cats?
Edited by AndyR35, 12 March 2017 - 08:46 AM.
#5 240Z TwinTurbo
240Z TwinTurbo
  • 955 posts
Posted 12 March 2017 - 09:52 AM
the pipes could be resonating, which happens.  You can try wrapping the downpipes and midpipe to dampen the resonance, if that is the issue.
2006 EVO IX (573hp/439tq)
2009 GTR Premium (534hp/563tq)
Built RB26 with no home (everything is for sale...lots of stuff)
DIY700 - 700hp on a Budget
Garrett V-band TwinScroll GTX35r Topmount Experiment
Garrett V-band TwinScroll GTX3576r, Curt Brown 10:1 2L, R2's, 110octane, 573hp/439tq
#6 GTRHOLIC
GTRHOLIC
  • 236 posts
Posted 12 March 2017 - 09:40 PM
Yup ..sure, car is tuned and is almost alpha 6 level.
non res - non catted
#7 L.L.
L.L.
  • 734 posts
Posted 12 March 2017 - 10:10 PM
Is the sound you're talking about also present during cold starts and sounds like an air pump?
2015 Nissan GT-R Premium
AMS Alpha 9+ Turbochargers | AMS Alpha Induction Kit | AMS Alpha Front Mount Intercooler
AMS Alpha 3" Intakes | AMS Alpha 90mm Downpipes  | Litchfield 102mm Triple Silenced Exhaust
AMS 4.0 BAR Map Sensor | AMS Alpha Coolant Expansion Tank | AMS Alpha Splash Shield
Speed Density on Cobb AP3 | ID1300 Injectors | Tial Q BOV | DW300C Fuel Pumps | GotBoost Flexfuel Kit | GotBoost Fuel Pressure Monitoring Kit
Stock Block/Transmission | Tuned by Chris Black & ACG Automotive | Built by JohnWigs @ Pacific Nissan
FS: AAM Full Intercooler Pipe Kit
#8 GTRHOLIC
GTRHOLIC
  • 236 posts
Posted 12 March 2017 - 10:40 PM
No sir .. nothing like that.
it's like a sudden change in frequency/sound ( Deep annoying rasp with heaviness in TB sensation ) then it goes away once passes that area.
#9 240Z TwinTurbo
240Z TwinTurbo
  • 955 posts
Posted 13 March 2017 - 11:13 AM
resonance in the pipe has nothing to do with a physical resonator or cat.  Resonance is a frequency where the vibration in the pipes get amplified and create a noise.
#10 celsius
celsius
  • 6,835 posts
Posted 15 March 2017 - 01:53 AM
Make sure that you don't have an exhaust leak. I did a DP install on someone's GTR that exhibited similar issues that you're describing and it turned out to be a slight leak that was audible at certain RPMs.
#11 GTRHOLIC
GTRHOLIC
  • 236 posts
Posted 21 April 2017 - 05:46 AM
Problem solved!
#12 Geno88
Geno88
  • 177 posts
Posted 21 April 2017 - 06:08 AM
what was it?
#13 Jason13
Jason13
  • 238 posts
Posted 21 April 2017 - 06:36 AM
You mean droning around the 2-2.5k rpm mark?
Edited by Jason13, 21 April 2017 - 06:36 AM.
#14 GTRHOLIC
GTRHOLIC
  • 236 posts
Posted 21 April 2017 - 07:47 AM
what was it ?
Mid pipes to oem catback poor gasket line up job! ( part of it was blocking the flow)  .. that explains the pressurized flow sensation I was referring to!
Hope pistons/rods didn't suffer from that back pressure's resonance!
I put SBD adapter/reducer now and the flow is super smooth!
Lesson learned: Never ever mate your bigger after market Y-pipes to OEM Catback without a reducer/adapter!
Edited by GTRHOLIC, 21 April 2017 - 09:42 AM.
