Companies to Change Tires?
6 replies to this topic
#1 starnes
starnes
    GTRLIFE Newbie
  • 5 posts
Posted 16 May 2017 - 09:48 AM
Could anyone share their experience in tires?  I.E.  what to shops charge you to change tires?  Can most tire shops change these or do you need a special shop?  We do not have a lot of great options here locally and I have thought about getting some high quality tire servicing equipment but wonder if these tires are really that difficult to work with?  Do you really need/want tools like corghi equipment to mount and balance?
#2 L.L.
L.L.
  • 788 posts
Posted 16 May 2017 - 01:04 PM
I go to my preferred Discount Tire location here in San Diego. My friend is the manager at the location and he takes care of all the high end mounts/dismounts on difficult tires such as the RFTs for the GTR. I just had a new set of Dunlop AS 7010 tires mounted two weeks ago in under an hour with absolutely no issues.
Most Discount locations should have the correct equipment to mount/balance the tires properly. Request the person with the most experience to avoid any complications. If you're planning to purchase a new set of factory Dunlops, be sure to order far in advance. The full set took ~3 months to arrive. I wasn't charged for installation nor the TPMS rebuilt kit.
2015 Nissan GT-R Premium
AMS Alpha 9+ Turbochargers | AMS Alpha Induction Kit | AMS Alpha Front Mount Intercooler
AMS Alpha 3" Intakes | AMS Alpha 90mm Downpipes  | Litchfield 102mm Triple Silenced Exhaust
AMS 4.0 BAR Map Sensor | AMS Alpha Coolant Expansion Tank | AMS Alpha Splash Shield
Speed Density on Cobb AP3 | ID1300 Injectors | Tial Q BOV | DW300C Fuel Pumps | GotBoost Flexfuel Kit | GotBoost Fuel Pressure Monitoring Kit
Stock Block/Transmission | Tuned by Chris Black & ACG Automotive | Built by JohnWigs @ Pacific Nissan
FS: AAM Full Intercooler Pipe Kit
#3 starnes
starnes
    GTRLIFE Newbie
  • 5 posts
Posted 16 May 2017 - 01:34 PM
Thanks
#4 AutoXGTR
AutoXGTR
  • 5,754 posts
Posted 19 May 2017 - 01:56 PM
You might check with your local SCCA autocross group and ask where members change tires and inquire at that shop how much it would be to mount tires.
Since track and autocross drivers have many wheels and tires they use they often partner with tire or wheel shops to mount and dismount tires on a regular basis. As a result the rates are negotiable and usually quite good. I pay about $20 per wheel while the going rate at outside shops is more like $35 per wheel.
Posted ImagePosted Image
#35 Street Modified Class Solo SCCA Hawaii Region 2017-2018
2009-2017 Season Points and Run Off Champion (ASP 2009-12/SSP 2013/Street Modified 2014-17/ 2nd Runoff SM 2016-17)
#5 bvdawg13
bvdawg13
    GTRLIFE Newbie
  • 43 posts
Posted 19 May 2017 - 02:40 PM
I've used discount tire as well. Although they had their "best man" on the job, one tire was mounted backwards so I went to a different discount tire location to get it fixed.
#6 AutoXGTR
AutoXGTR
  • 5,754 posts
Posted 19 May 2017 - 11:48 PM
the skill of the mechanic plays a big role in how well and trouble free tire mounting can go. Know your mechanic.
#7 Geno88
Geno88
  • 221 posts
Posted 20 May 2017 - 06:31 AM
A total suggestion for you, and from what I went through, it's NOT overkill at all.
When you get there, call the mounter, manager over to inspect the rims and tires. Agree on any and all prior
knicks/damage, if any. Put it all in writing.
Agree that any extra damage will result in replacement, then have them do the work.
Check each and every rim thoroughly before you leave. If there's any damage, it must be called out.
I had a very bad experience and i'm going through this now.
I'll post after the DM makes his decision.
