Status Harnesses install
64 replies to this topic
#1 vividracing Posted 12 February 2009 - 04:33 PM
vividracing
  • 6,654 posts
A few members were quick to jump on the bandwagon and order the new 4 point harnesses from Status Racing. With the GT-R being a special animal, we decided to get a set for our project and help out with a step-by-step install. Installation went fairly smooth and just requires standard hand tools and a drill with a 1/2 inch bit for the inner lap mount.
After removing the lower seat cushion the shoulder harness mounts are right out in the open. After removing the seat belt mounts from the floor, replace the hardware with the supplied eye bolts included in your kit.
For the outer lap belt mount, the pillar seat belt mount is removed and replaced with an eyelet, the OEM retaining clip, nut and bolt will need to be removed:
With the seats forward, remove the rear seat mounting bolts, the two front mounting bolts, and unplug the seat control harness and remove the seat from the vehicle. This is where the drill comes in. Remove the inner side trim of the seat to access the seat buckle mount, once removed you will need to drill the 1/2" hole through the panel and run the eyelet thru into the mount:
Attach the lap harness to the inner eyelet before remounting the seat in the vehicle, as the space between the seat and center console is fairly tight. Remount the front seat, drop in your rear seat cushions, clip in the the corresponding eyelets and voila! Ready for the track!
Email, PM, or call me directly for aggressive NAGTROC / GTRlife member pricing!!!
480.966.3040 ext 249
james@vividracing.com
Vivid Racing : Complete list of current sale threads - CLICK HERE!
#2 Gdzilla_ Posted 12 February 2009 - 07:06 PM
Gdzilla_
  • 963 posts
wow.. never installed one before but it sounds simple enough...
i think i read somewhere that the shoulder straps after they pass through the back of the front seats are or should be crossed before they are attached to the rear mounts when a support bar or roll cage is not installed?..
does that sound right?
2009 GTR R35 Premium... Ivory Pearl / Black... Delivered September 8th 2008...
1999 GTT R34 Skyline... White / Ebony & White... scheduled delivery January 31st 2015
#3 AutoXGTR Posted 12 February 2009 - 07:37 PM
AutoXGTR
  • SpecV Member
  • 4,807 posts
Correct. After adjustment the waist lap belts should be horizontal not raised. Shoulders snug.
Tighten the waist belts first then shoulders to snug.
After use you can remove the harness and leave behind the right console side waist belt and use the standard belts for street driving.
Thanks Sean for the pictures.
Posted ImagePosted Image
#35 SM Class Solo SCCA Hawaii Region 2014-2015
2009-2014 Season Points and Run Off Champion (ASP 2009-12/SSP 2013/SM 2014)
#4 Gdzilla_ Posted 12 February 2009 - 10:05 PM
Gdzilla_
  • 963 posts
thanks 'auto' ... that's good info...
cheers...
#5 AutoXGTR Posted 15 February 2009 - 02:17 AM
AutoXGTR
  • SpecV Member
  • 4,807 posts
This harness comes in black red or blue.
I will try to get a picture of my red harness on my black interior.
#6 Godzilla35 Posted 15 February 2009 - 07:10 PM
Godzilla35
  • 854 posts
sorry for my noobness... but i'm still a bit confused as to how this looks in the rrear seats. this is without a roll bar in the back, nor a cage right? so this is safe or just for looks?
09' GT-R... extra Slow But Klean...
#7 AutoXGTR Posted 24 February 2009 - 02:25 AM
AutoXGTR
  • SpecV Member
  • 4,807 posts
Yes, it is safe.
You install the four eyebolts to anchor the four belts- two lap one right and one left and two shoulder, right and left that attach to the rear seat's lap belt anchoring bolts.
The front seat has the harness but the shoulder belts cross and cover the rear seat so that no one can sit behind the person that has a harness on.
If the driver has a harness then no rear passenger is possible behind him. If you install two harnesses for the front seats then the rear seats are unusable.
No roll bar or cage needed.
When done with the harness simply remove the clips on the eyebolts on all except the belt that is attached to the lap facing the driver's right near the center console. The fit is tight but I have reached in to remove the belt clip with a little effort. Simply place the belt backwards along the console and out of the way so that the OEM seat belts can be used.
I was trying to download pictures but the gallery is not working for me.
#8 AutoXGTR Posted 25 February 2009 - 04:17 PM
AutoXGTR
  • SpecV Member
  • 4,807 posts
Here are pictures of red Status harness installed with Black interior
Front seat with four point red harness installed
Rear seat shoulder belts crossed and anchored into rear seat lap bolt areas then rear seat cushion put back into place
Edited by AutoXGTR, 25 February 2009 - 04:51 PM.
#9 vividracing Posted 25 February 2009 - 04:38 PM
vividracing
  • 6,654 posts
http://i706.photobuc...pg?t=1235589241
http://i706.photobuc...pg?t=1235589368
Great job on the install Brad! The red on black came out really nice
#10 White_turbo Posted 25 February 2009 - 04:54 PM
White_turbo
  • 1,351 posts
Thanks for the install pics.
Two questions:
1)  Does the inner seat trim get reinstalled after you drill and attach the eyebolt?  Or is that piece now unusable?
2)  Are the rear seat cushion installed with some sort of adhesive or can they just be simply pulled out?
Thanks.
#11 vividracing Posted 25 February 2009 - 05:20 PM
vividracing
  • 6,654 posts
Two questions:
Thanks.
1) inner seat trim just gets drilled and is reinstalled.
2) rear seat cushion easily slips in and out
#12 AutoXGTR Posted 04 March 2009 - 02:10 AM
AutoXGTR
  • SpecV Member
  • 4,807 posts
For me,
1) Inner seat trim was left in place and the location of the seat belt lap bolt was estimated and a hole was drilled to expose the bolt. I used a slightly oversized drill bit in case I was not exactly over the bolt. 1" hole will work fine. Vivid suggested a 1/2" hole. In any case once the eyebolt replaces the stock bolt then the seat can be repositioned and fastened down. I did not remove my seat or unplug the wire harness under the seat, I just tipped the top of the seat to the outer side of the car and worked near the console.
The trim piece for me did not need to be removed and when the seat is put back the eyebolt and hole cannot be easily seen. The lap belt needs to be fastened/clipped on the eyebolt before you put the seat back in- it's tight to put on the lap belt otherwise. However I was able to.
2) rear seat cushion bottom has a small ring pull to remove the latch that holds down the front of the rear seat cushion and the back of the cushion has a white tab that fits under the back seat cushion. So the rear seat bottom has two points to hold it in place. Only the latch in the front is secure- the other point works on passive friction. Once the rear shoulder belts are fastened to the eyebolts in the back you can replace the rear seat cushion bottom and it will look like my picture. You can't sit there though.
#13 Discoragno Posted 28 June 2009 - 05:02 PM
Discoragno
  • R35
  • 276 posts
Sabelt 4 point procedure By Club GT-R Italia
Da 2009_06_21_Montaggio Sabelt per GT-R
#14 ShahulX Posted 10 April 2010 - 01:24 PM
ShahulX
  • Who Dat !
  • 7,797 posts
maybe I should get harnesses........
Current car : 2011 Boxster Spyder- (6MT, cf sport buckets, sport chrono, pagid yellows, gt3 brake ducts, fabspeed race) Audi B6 S4 cab (sprint blue), 2010 Highlander Hybrid Limited
Former cars: 2009 NISSAN GTR PREMIUM ( Delivered !! 8/05/08 Ivory Pearl with Black leather )
2010 Evolution X, MK6 VW Gti, Subaru Outback and Forester XT 5mt, evolution 8 gsr, 94 supra, tsx 6mt, 2 preludes, rsx type S, 99 & 01 miatas, ridgeline, passport, integra, 06 accord, 07 crv, 00 eclipse gt
[/b]
[/color]
#15 Jergens Posted 11 April 2010 - 02:24 PM
Jergens
  • 120 posts
Hmmm, after just leaving Homestead yesterday, I was wondering if there was any way to put in a functional harness without chopping up my interior. This looks like it could be ok... not sure that I trust myself on the install though or how well it would actually work in road race application.
Edited by Jergens, 11 April 2010 - 02:30 PM.
2010 Obsidian Black GT-R "Cortana"
COBB Custom Tune by PROS
Harman Motive Catless Downpipes
Harman Motive Y-Pipe
HKS Legamax Exhaust
Stillen SS Brake Lines
AP Racing J-Hook Rotors
CL RC8 Brake Pads
Dunlop SP Sport 600
Carbotech XP12 Brake Pads
Toyo R888 F: 285/35/20 R: 315/30/20
#16 DocNrock Posted 11 April 2010 - 04:13 PM
DocNrock
  • SpecV Member
  • 3,626 posts
I will be having HB Speed fabricate a true harness bar solution that can be trusted at 150+ mph.  Once this has been done, hopefully they will offer duplicates to others on this board.
2009 Obsidian Black Nissan GT-R Premium. 550 awhp, 544 awtq (Mustang dyno, 91 octane). Dyno tuned by Jon at Cobb SoCal
Auto Club Speedway ROVAL 1:51.450, Willow Springs (big Willow) 1:34.457, Buttonwillow 13cw 2:02.858, SMMR 3.1 2:41.811
Go: Akuma BM intakes with Outerwears prefilters, AMS FMIC, Harman Motive intercooler piping, iD 1000cc injectors, dual Walbro fuel pumps, NGK racing plugs, AAM decatted downpipes, Cobb catted Y-pipe, HKS Legamax exhaust, and Cobb AP with custom tune.
Stop: AP Racing J-hook rotors, Endless ME20 pads, Stillen stainless brake lines, Endless RF-650 fluid.
Handling: Stillen sway bars, Dunlop SportMaxx 285's x 4, KW Coilover Sleeve kit, custom track alignment.
Accoutrements: Traqmate Complete/Chase Cam, GT Motoring tow hook, ARP studs, Project Kics R40 lugnuts. Passenger seat mount Halon extinguisher.
#17 baileyrx Posted 11 April 2010 - 04:19 PM
baileyrx
  • 735 posts
in lieu of a harness, i use a clip that locks the oem seat belt in place.  you basically pull yout belt as tight as you can/want & it doesn't loosen up until you release it...
#18 EWD Posted 11 April 2010 - 05:58 PM
EWD
  • 168 posts
Great! Would like see an alternative to the EVO bar.   I contacted BBI about both their harness bar & 6 pt, but after an initial email exchange I'vee never heard back.  Doesn't PWJDM have something in the works also?
Edited by EWD, 11 April 2010 - 05:59 PM.
#19 SEVox Posted 11 April 2010 - 08:36 PM
SEVox
  • 67 posts
What clip is this and where did you get it?
#20 Goodwood Posted 11 April 2010 - 08:46 PM
Goodwood
  • Caretaker of GODZIRA!
  • 2,675 posts
This could be what he means. I have this CG Lock. It's a bit of a pia when not tracking but it works as advertised.
CG Lock
09 GT-R Ti/Black
Greddy FMIC, Forge DCT Cooler, Cobb SF Intakes, Cobb Swaybars
SSP Catless Downpipes, Cobb Catted Midpipe, 5Zigen SP Tune Catback
AP Racing J-Hook Rotors, Endless MX72 Pads, Stillen SS Brake Lines
Michelin PSS 285/35/20
Tires x4 on 2012 OEM wheels
My Pbase Photo Gallery
