Agency Power Electronic Valve Controlled Exhaust Muffler Nissan R35 GT-R 09+
Agency Power set out to produce the best exhaust system to appeal to the entire market. The solution is simple, create a high performance, quality built product with variable exhaust sound and performance. That is where this electronic valve controlled system thrives. The Agency Power muffler gives the user the ability to control the performance and sound of the exhaust with the push of a button.
Valves mounted near the muffler allow exhaust gases to either pass straight through for performance and a louder sound or be diverted into the muffler for a quieter sound. Constructed with 304 stainless steel and tig welded ensure a quality fit and durability that is an Agency Power standard.
Capable of producing ~50 whp with supporting mods, the Agency Power electronic valve controlled exhaust is a must for both the street and the track.
Included:
Included:
- Muffler with Valve System and (4) Powder Coated Matte Black Tips
- Electronic Control Box
- 2 Remotes
- Vacuum Lines
- Clamps and Gaskets
Check out the video for the exhaust system!!!
AGENCY POWER GTR ELECTRONIC CONTROLLED EXHAUST SYSTEM!!
Agency Power High Flow Cat Downpipes Nissan R35 GT-R 09+
Since its release, the Nissan R35 GT-R has been in need of high flow downpipes with cats. Enter Agency Power with the new Stainless Steel high flow cat downpipes to fit either the stock or any aftermarket exhaust system. Constructed of durable, high quality 304 stainless in a full 3" diameter. The improved flow from the larger diameter catless pipes produce more power, keep boost pressure up and provide improved throttle response for you R35 GT-R. Each downpipe has oxygen sensor bungs, thick flanges and sturdy hangers.
Agency Power Mid Y Pipe Nissan R35 GT-R 09+
Agency Power's mid pipe is a great exhaust upgrade for the Nissan GT-R. The increased diameter pipes allow exhaust to flow more freely through the entire system. This free flowing exhaust is what allows your GT-R to produce more power. The mid Y pipe upgrade can be used with a stock system or with the aftermarket options available today.
The 304 stainless steel is durable and utilizes two mesh sections that bend and flex while preventing exhaust leaks.
