T1 GTR Fuel Rail kit
2 replies to this topic
#1 Tony1 Posted 02 May 2011 - 03:41 PM
Tony1
  • T1 Race Development
  • 1,264 posts
We've been busy at work trying to get these rails to release as soon as possible and they're finally ready to go!
The release of the ID1600 is what prompted me to build these rails.  There are more and more situations where the ID1000's aren't enough fuel, yet the ID2000's are tricky to get right with the stock ecu.  The ID1600's really do run like stock injectors.  Hard to believe, but it's 100% true, i've been running them in my GTR for over a month now with these rails.   Check this link out for some good reading on the topic.
http://www.injectord...wPulseTech.html
Anyways, the ID1600's are too long to fit the GTR.  The factory rail can be modified for height but then it hits the intake manifold.  Our rails are designed for the longer injector (12mm longer than stock).
These rails are all 1 piece, no secondary mounting brackets or adaptors for the fuel damper and regulator.  It made machining them a lot more work, but at the end of the day it's a better way to do it and it eliminates any possibility of mounting brackets coming loose or anything.   The factory damper and regulator bolt on and in the same position as the stock rails, so these rails are 100% bolt on.
Fuel temperature is another issue that is often overlooked.  The cylinder heads are hot and a lot of heat gets transfered from the heads, to the rails, to the fuel.  We've incorporated 1/4" phenolic spacers between the heads and rails.  Phenolic has excellent insulation properties, keeping as much heat out of the fuel rail as possible.
The kit also includes Goodridge fittings and line to connect the two rails behind the timing cover.  Goodridge's top of the line components were used, the 'G Line XF' line is constructed of woven super light Aramid braid, with a PTFE inner bore - smooth inside for increased flow and convoluted outside for amazing flexibility.  The hose is fully compatible with all fuels, including methanol.  The lightweight crimp on hose ends ensure a leak free seal and light weight.
The complete rail kit is $799.95 and consists of both fuel rails, all Goodridge black anodized fittings and hose, SS mounting hardware, and phenolic spacers.
http://t1racedevelop.../t1-r35-fr.html
T1 Race Development
Injector Dynamics
214-607-9022
Tony@t1racedevelopment.com
Building GTR's and supplying injectors, one day at a time...
#2 HighlanderD Posted 31 January 2013 - 08:59 PM
HighlanderD
  • SpecV Member
  • 3,540 posts
Running T1 Rails on our shop build!
First Person to Ever Remove a GT-R Drivetrain in their own garage
#3 AWD Motorsports Posted 31 January 2013 - 11:25 PM
AWD Motorsports
  • MOST H8D
  • 682 posts
Nice looking setup.. The 1600s are discontinued also for anyone who didnt know..
  • AWD 09' GTR "Most H8D" World's Quickest / Fastest 30r. Alpha 10 Powered- 8.61 & 166+mph(Tuned by: Sean Ivey)
  • AWD 09' GTR "Most H8D" World's Quickest Stock Manifolds GTR. Alpha 9 Powered- 9.02 & 154+mph(Tuned by: Sean Ivey)
  • AWD 09' GTR "Most H8D" World's Quickest / Fastest Stock Turbo, Engine, Trans- 9.73@142mph & 5.85 60-130 (Tuned by: Sean Ivey)
  • AWD 12' Deep Blue Pearl GTR. STOCK
  • AWD Evo 8 GSR "Most H8D"- 8.75@163mph
  • AWD Evo 8.5 RS "Bastard" 8.98@156mph
  • AWD E60 M5 World's Quickest / Fastest 10.57@130mph
  • Posted ImagePosted Image
