20 inch drag radials
76 replies to this topic
#1 carlos-gtr Posted 25 May 2011 - 02:24 PM
carlos-gtr
  • 239 posts
I was wondering if someone has tried running nittos 20 inch drag radials, I know Mickey Thompson wil be coming out with an et street drag radial 20 inch, guess that could be an option to running 18's
#2 awesome Posted 25 May 2011 - 02:37 PM
awesome
  • 1,833 posts
I believe nitto makes one currently, but i am unaware of how they perform...r555
Iveytune Built GTR - with timeslips to back it up
#3 Sean@Iveytune Posted 25 May 2011 - 05:00 PM
Sean@Iveytune
  • International Vendor
  • 1,300 posts
Hing ran 9s on them eons ago.
Sean
WWW.IVEYTUNE.COM ............Results based.
DYNOJET AWD ON PREMISES!!!
ECUTEK PRO Dealer, RaceROM!
Cobb Protuner "Live Data!
Dodson Pro Dealer, repairs and all upgrades to the GR6.
Customers:
Sean I 8.23 @ 178.1 Iveytune stage 3 engine, Iveytune stage 5 trans with Promax, Iveytune fuel system, AMS Alpha16 turbos, Iveytuned with Motec M1.
Joe C 8.81 @ 165.3 Iveytune stage 1 Engine, Iveytune stage 4 trans with Promax, Iveytune fuel system, Iveytuned with Cobb AP (Ran Sept 2012).
MikeAWD 8.61 @ 166 Iveytune stage 1 Engine, Iveytune stage 1.5 trans, Iveytune fuel system,AMS Alpha10 kit Iveytuned with Cobb AP
Juan F 8.76 @ 164 Iveytune Stage1 Engine, Iveytune stage 4 trans w promax, Iveytune fuel system,AMS Alpha 12 kit, Iveytuned with Cobb AP.
Jimmy 8.9 @ 168 AMS Longblock, stage 4 trans w promax, AMS fuel system, ETS HTA86 kit Iveytuned with Cobb AP.
PJ#2 8.93 @ 157 Stage 2 engine, Iveytune Stage 2 trans with Sportsman, Ivey fuel system, Iveytuned with Cobb AP.
DJ Reversal 9.49 @ 156 Built engine, Stage 2.5 trans, AAM fuel system, BL turbo kit, Iveytuned Cobb AP .
PJ#1 10.05 @ 139 Stock turbo, stock trans, FULL Weight GTR, Fastest full weight GTR with stock turbo/engine/trans, Iveytuned Cobb AP. E85 Ran in 2011.
1st East Coast 8 Sec GTR 8.81 @ 165.xx (Sept 2012)
Quickest East coast GTR 8.23 @ 178.1 (Oct 2014)
Quickest 3.8 liter, Quickest Alpha 9,10 and 12 simultaneously, first 8 sec car on motec.
#4 VEGASGTR Posted 25 May 2011 - 05:02 PM
VEGASGTR
  • 8,279 posts
Sean
so did I  :)
nitto555R are  the best DR for street driving... MT are nice but handle like a broken shopping cart..
current: 2014 Z51 A&A supercharged 608whp on 91.
past:
2009 GTR 9.5@150 4.38 60-130
2006 S/C Z06
2002 Twin Turbo Z06
#5 carlos-gtr Posted 25 May 2011 - 05:12 PM
carlos-gtr
  • 239 posts
View PostVEGASGTR, on May 25 2011, 07:02 PM, said:
so did I  :)
Did you used 20 or 18?
#6 NVRENUF Posted 25 May 2011 - 06:02 PM
NVRENUF
  • 1,159 posts
Just put Nitto 555r on front, Nitto 05r on rear yesterday.  Haven't driven it yet, but Eugene @ SPE said he liked it and gripped awesome.  20" both, but only 1 size option and they are a lil taller tire.
Edited by NVRENUF, 25 May 2011 - 06:03 PM.
#7 VEGASGTR Posted 25 May 2011 - 06:26 PM
VEGASGTR
  • 8,279 posts
20's on stock Rims  , MT were on 18's
past:
2006 S/C Z06
2002 Twin Turbo Z06
#8 carlos-gtr Posted 25 May 2011 - 06:51 PM
carlos-gtr
  • 239 posts
Did you liked the way they performed on the track the 20's
#9 cranberry Posted 25 May 2011 - 07:33 PM
cranberry
  • 1,033 posts
so did I  :lmfao:
So are the 555R's better than the R888's? I will need to buy one or the other once my car gets finished.
Posted Image SPE1200R
Posted Image SPEGodzilla
#10 VEGASGTR Posted 25 May 2011 - 07:46 PM
VEGASGTR
  • 8,279 posts
never tried the R888 .. but from what i have seen the nittos are alot better then R888's  .. a few cars have run 1.7-1.8 with R888 @ the track..   Nittos have gone 1.52 (not my car)
On the street with my setup 800/800 and ONLY nittos DR 555R in the back and invos in front , my car puts the power down in every gear :lmfao:
past:
2006 S/C Z06
2002 Twin Turbo Z06
#11 sjj31 Posted 26 May 2011 - 07:43 AM
sjj31
  • 1,504 posts
On the street with my setup 800/800 and ONLY nittos DR 555R in the back and invos in front , my car puts the power down in every gear :burnout:
Where did you get yours.  Been looking all over and cannot find the 285/35/20 for the OEM rims.  What size did you use to fit the OEM rims.  Just so I understand these are great at the drag strip but also acceptable for street driving and track use.  The reason I ask is I have a set of 21's I run on the street with seperate rims but occassionally when doing a track event swap out my for my OEM rims with Dunlops and typcially street drive until I get a chance to swap the 21's.  Would love not to have 3 sets of tires :-)
2010 Nissan Super Silver GTR – New Build April, 2014 @ 32,000 Miles (After 3 years of Bolt-On Fun!)
Engine:
Jack’s Transmissions Engine Refresh (Forged Manley Rods & Pistons,Gaskets, Bearings, Seals etc.) + Heat Shielded Engine Bay
Turbo’s:GTC Stock Frame Spec V Turbos,Ported Upper/Lower Manifold,GTC 60mm Inlets,AMS 4Bar MAP Sensor
Tune:EcuTek – Ben Linney SD Flex Fuel Tune using Gotboost SD Kit and Visconti Flex Fuel Kit
Fuel/Injectors:Walbro 485 Pumps with AMS Hobbs Switch & Hardwired and Jack’s Seals,SIR 1150cc Injectors
Bolt-Ons:HKS Legamax Catback,HKS Non-Res Midpipe,GTC 90mm DP’s,Gotboost 3" Intakes w/Green Filters
Tranny:Built Stage 2+ - Billet Dodson Baskets A&B+PPG 1st Gear,Jack's 16 plate Clutch & Bell Housing Upgrade (drives like stock)
Cooling: ETS Intercooler/GotBoost IC Piping,SSP Tranny Cooler,Dodson Oil Thermo, AAM Oil Catch Can
Brakes: Alcon HD 396mm/JHook Rotors,Forged SS Lines,Hawk DTC 70/60 Pads,Upgraded OEM Painted Calipers (RB Stainless pistons/blue melt-proof seals/boots)
Fluids:Shell Rotella T 15w40 Engine (Jack's recommended), Castrol Diff, Jack’s Special Tranny Mix, Castrol SRF Brake
Wheels:Yokohama AVS F7 20x10+30,20x11+25,TSM Track Spacers (10/15mm),Toyo R888 285/35/20,315/30/20
Suspension:Full Penske 2 Way Coilovers with Eibach GTR Sway Bar Front and Rear, Corner Balanced, Track Aligned
Track:SFS Strut Bar,APR100-7718 Studs 12x1.5,Muteki Lugs,Sparco Harness Bar,Shroth 4PT,Difflow 5E Diffuser,Forged SW Lock
Look:DF CF Side Sills,Spats,ExShrouds,Rexpeed CF-M Splitter,OEM DRL's,SP LED Kit,GTMotoring Tow Hook
Extras:Hushmat Ultra (rear&trunk),Front Clear Bra,Full Tint,Clear JDM markers,Escort 9500ci Custom,VBOX
#12 NVRENUF Posted 26 May 2011 - 07:49 AM
NVRENUF
  • 1,159 posts
I just bought mine.  VERY hard to find due to crisis in Japan.  I spent 1.5 days searching. There were literally only 3-20" NT05r's left in the country, and they were not easy to track down.  The 555r's are just as tough to find. Luckily, I only needed 2.  For now, I found that Jeg's keeps them in stock and is the best option. There are a ton of online dealers, but they don't really stock them. They pull from some distant central warehouse that everyone goes to.  Try Discounttiredirect.com, Jegs, VividRacing.com.
#13 Kisco Posted 26 May 2011 - 08:29 AM
Kisco
  • 1,531 posts
On the street with my setup 800/800 and ONLY nittos DR 555R in the back and invos in front , my car puts the power down in every gear :)
This.  I am very happy with my Invo/555R set-up.  :burnout:
Underground Racing LP560 2R - (For Sale…pending)
#14 FATNSLO Posted 26 May 2011 - 08:49 AM
FATNSLO
  • 432 posts
I'm not saying that one is better than the other because I have never tried the Nittos but I'm running 20" R888's and I have smoked everything I've run on the street and ran 9.88 with a 1.67 60' at the track.  I have been told more than once by guys a lot smarter than me that the Nitto's are best for the drag strip and the Toyo's are best for the road course. Built my car primarily for the road course so it's Toyo's for me.
Switzer R900 GTR Package on 2009 – 828hp, 829tq
IMRA 200mph Standing Mile Club & 9 Second 1/4 Mile Club Member
Switzer Stainless Steel Exhaust w/ Back Pressure Relief System
Switzer Transmission Upgrade W/ Sheptrans, PPG & Dodson components
Stillen Carbon Ceramic Brake System (W/Pagid Pads)
Stillen Max 5 Way Adjustable Sway Bars W/ Adjustable End-links
HKS DCT Transmission Cooler, Front & Rear Electric Brake cooling kits
Forged-Alloys AMT 20" wheels / Toyo R888's - JRZ RS Pro Adjustable Suspension
AMS Carbon Hood, Roof & Trunk - Zele Carbon, grill, front, side & rear lowers
Aeromotions S-2 Active Wing, Hush Mat Sound & Heat Suppression
JL Audio Clean Sweep & Amplifiers, Morel Speaker Systems Front & Rear
JL Audio 10W6 10" Woofer in Serious Autosport custom plexy enclosure
K-40 RL360 front & rear radar detector & laser diffusers
Video VBOX Lite 4 Channel / Nav-TV Factory Video kit with Backup Camera
Zele Front Bumper - Drive Shaft Shop 1000HP Axles front & rear...
#15 NVRENUF Posted 26 May 2011 - 08:55 AM
NVRENUF
  • 1,159 posts
Fatnslo. That is exactly my understanding also.  Why I went Nitto. I'll never be on a road course (or not frequently at least).
#16 VEGASGTR Posted 26 May 2011 - 09:07 AM
VEGASGTR
  • 8,279 posts
Yep, R888 are a lot better handling tires for sure! Nittos 555 are made for straight line . The only other draw back to the R888 is very pricey..
And to the guy looking for nittos ..they don't make OEM size you have to go to the 275 /20 in the front and 305/20 in the rear
past:
2006 S/C Z06
2002 Twin Turbo Z06
#17 FATNSLO Posted 26 May 2011 - 09:27 AM
FATNSLO
  • 432 posts
VEGAS you gotta tell me where you've been shopping because so far everything I've ever bought for this car has been pricey!!!
#18 sjj31 Posted 26 May 2011 - 01:43 PM
sjj31
  • 1,504 posts
View PostKisco, on May 26 2011, 10:29 AM, said:
This.  I am very happy with my Invo/555R set-up.  :irock:
OK as a newb here, I think I got this figured out!  Found four Nitto 555R in stock, however since the main slip will be the rear, put those in the back and then put the Nitto Invo's in the front and I would have a good hybrid of drag strip and track use (just want to confirm why you don't go 555R all around).  The sizes to confirm to go on the OEM rims would be 305/35/20 rear and 275/40/20 front is this correct?  And need to confirm these will fit the OEM's if so want to pull the trigger.
Engine:
#19 VEGASGTR Posted 26 May 2011 - 02:49 PM
VEGASGTR
  • 8,279 posts
YES , that is the setup im running
305/35/20  -555R  Rear ( 28.58 ) and INVOS 275/40/20  Front  (28.62) height is near perfect.
past:
2006 S/C Z06
2002 Twin Turbo Z06
#20 VEGASGTR Posted 26 May 2011 - 02:50 PM
VEGASGTR
  • 8,279 posts
R888 are around 400 each?  and Invos were 224.00 each , and 555r 260 each
past:
2006 S/C Z06
2002 Twin Turbo Z06
