LC 4 Software.
LC 4 transmission software.
176 replies to this topic
#1 neels Posted 12 January 2012 - 06:06 AM
neels
  • R35 Member
  • 74 posts
I am considering updating my LC 1 software on my 2008 JDM R35 to the LC4 software. I have done the Willall Racing upgrade on the transmission.
Has anyone upgraded their software from an older version to LC 4? Is it a good idea on an older model?
Thank you.
2008 JDM R35
Cobb AP with Willall Tune and 600HP
Custom Targa Mid-pipe
Willall Transmission Upgrade with Dodson Sensors , Dodson filter and Clips TSB
Willall 10W60 Engine oil
Jacks 800nm clutch (including welded baskets) and forward drive upgrade
Willall transmission fluid
HKS transmission cooler
Boostlogic Engine oil Cooler
#2 JoeGr Posted 12 January 2012 - 09:52 AM
JoeGr
  • COBB Tuning Firmware Engineer (Hacker)
  • 1,615 posts
It can be done, but you have to use the AccessPORT to do it. The EcuTek stuff can do it for you too. There are a number of users out there with the AccessPORT that are running LC4 on older GT-Rs and from I've heard they love it!
Joe
MBA Class of 2012
#3 M O N S T E R Posted 12 January 2012 - 02:20 PM
M O N S T E R
  • Knowledge is recession proof!
  • 3,134 posts
Does this mean that the LC4 is offered as an OTS map from Cobb?
#4 max_R35 Posted 12 January 2012 - 02:23 PM
max_R35
  • ME MODERATOR
  • 1,788 posts
I believe it is still in Alpha stage, available to download but not available OTS
1st Series II Gulf Spec GT-R Black, Black/Red
Engine/Drivetrain:
Cobb AP-NIS-006, Custom Dyno Tune: Ben @ GTC, GTC 4" Ti Exhaust, GTC Turbo Inlet Pipe, GTC 80mm Intake, AMS catless DP, AMS Intercooler, Injector Dynamics 1000cc Injectors, HKS spark plugs, HKS Actuators, Cobb Silicon Hoses, Cobb XLE BPV, GBP SD Kit B, SIR 265LPH pumps, Castrol Engine Oil, Dodson Transmission and Diff Fluid, Willall Transmission Cooler + Sump, Willall Engine Sump, Willall Diff Coolers, AAM Engine Oil Cooler, CBRD Radiator, Carbing Coolant Overflow Tank, Samco Radiator Hoses, Dodson 60C Thermostat, Dodson Sportsman Kit + Extras, Michelin PSS 295/35/20 Square
Visual:
Stillen Front License Plate Bracket, Yoshi/RevoZport DN Duckbill CF Trunk, GT-RR CF Steering Wheel, Fringe XVO Afterburner tips, SMS Design & Performance Spec Mi CF Engine Cover # 9of10, Carbon Dry AC surround and door handles, Rexpeed Mirrors, Emblems, Carbon Side Emblem Cover and Carbon Hood Dampers, Matte Black VR G2 F20x10 R20x11
View PostAMS, on May 18 2010, 04:52 PM, said:
We rarely are the first to market on the product but in our eyes we always produce the best product when we do finally release it :)
#5 Visconti Posted 12 January 2012 - 03:06 PM
Visconti
  • EcuTek Tuner
  • 4,498 posts
Thank you.
Yes - many people have gone from LC1 --> LC4
Car drives around a lot smoother with LC4.
LC4 has launching back to back to back to back limitations - after 3 or 4 launchs you need to drive the car around for a mile.
Do some reading/searching and you'll see a lot of good feedback form people.
-John
#6 JoeGr Posted 12 January 2012 - 03:09 PM
JoeGr
  • 1,615 posts
-John
We've taken care of that :)
Joe
MBA Class of 2012
#7 Visconti Posted 12 January 2012 - 03:12 PM
Visconti
  • EcuTek Tuner
  • 4,498 posts
Joe
awesome!
#8 JoeGr Posted 12 January 2012 - 03:26 PM
JoeGr
  • 1,615 posts
That is correct it is still in ALPHA testing until we finish adding the gear learning and touch point adjustments.
Joe
MBA Class of 2012
#9 Dave@GotboostPerformance Posted 12 January 2012 - 04:39 PM
  • SpecV Member
  • 4,519 posts
-John
Yes LC 4 is much much smoother on take-off. I had to remove it and switch back to LC 2 because my clutches were slipping under hard acceleration. There is no way to adjust clutch capacities, so I feel it is very limited in cars with over 600wtq until gear learning and capacity adjustments can be made.
'09 GT-R titanium:
Follow My Build Here: http://www.nagtroc.o...he-gbp-900-kit/
www.gotboostperformance.com
dave@gotboostperformance.com
email and paypal
#10 Church Posted 12 January 2012 - 06:15 PM
Church
  • Sophisticated
  • 2,179 posts
And get the launch rpms down to 4100 AND get it to work on the 2010's.... right?
Edited by Church, 12 January 2012 - 06:15 PM.
#11 rutiger Posted 12 January 2012 - 06:40 PM
rutiger
  • 1,088 posts
how can you tell they're slipping?  as you know i'm making 600/600 and currently running the lc4 code.
'13 GTR USE-FF
'15 M4
#12 Dave@GotboostPerformance Posted 12 January 2012 - 11:28 PM
  • SpecV Member
  • 4,519 posts
Ryan, I can hear it and feel it on full throttle shifts going into 3rd and 4th. It never did this until I loaded LC4.
'09 GT-R titanium:
email and paypal
#13 neels Posted 13 January 2012 - 02:57 PM
neels
  • R35 Member
  • 74 posts
Thank you to everyone. This is very helpful.
I have a Cobb AP and after I had my transmission upgraded, they used it to reinstall the software (LC1) and adjust the touch points because the clutch packs aren't stock.
I may have to wait until touch points can be adjusted in LC4 before I upgrade.
Thans again.
2008 JDM R35
#14 Goonthree Posted 13 January 2012 - 04:38 PM
Goonthree
  • 6,137 posts
One way is while in gear you hit fuel cut aka rev limiter because the clutch couldn't hold.
#15 CornedOutVR38 Posted 13 January 2012 - 06:29 PM
CornedOutVR38
  • Banned
  • 1,199 posts
Just so you guys know, you can adjust the touch points and clutch capacities with LC4. What you need to do first is uninstall and reinstall the Cobb AP; then load just the ECU map. Now you'll be able to adjust the TPs and CCs. And finally, you load the LC4 map. Works like a charm.
9.870 @ 140.47
Bone Stock 3.8L
#16 neels Posted 13 January 2012 - 08:06 PM
neels
  • R35 Member
  • 74 posts
Thank you very much!
2008 JDM R35
#17 neels Posted 13 January 2012 - 09:28 PM
neels
  • R35 Member
  • 74 posts
Does anyone know where the LC4 software can be obtained? Is it from Nissan or Cobb?
2008 JDM R35
#18 SCCAForums Posted 13 January 2012 - 10:24 PM
SCCAForums
  • 291 posts
Still waiting for LC4 for 2010... :(
Current Car: 2010 GTR Premium SuperSilver
RaceCars:
'01 Pontiac Firebird Formula PTB/TTB #34
'89 Chevrolet Camaro 1LE CMC2/TTC # 75
'09 CMC2 NASA National Champion
'08 PTB NASA National Champion
'05 T2 Runoffs Qualifying Track Record Holder
'05 F-Stock Pro Solo Nat'l Champion
'04 F-Stock Solo 2 Nat'l Champion & '04 F-Stock Pro Solo Nat'l Champion
'03 ESP Solo 2 Nat'l Champion & '03 ESP Pro Solo Nat'l Champion
'97 G-Stock Solo 2 Nat'l Champion & '97 G-Stock Pro Solo Nat'l Champion
#19 Church Posted 13 January 2012 - 10:49 PM
Church
  • Sophisticated
  • 2,179 posts
Not true….
Once you load the LC4 the CC and TP changes won't work anymore. It shows the values but they don't take effect. Try it, you will see.
Even if you set your CC and TP’s before you load the LC4 they will be overridden by the 2012 data.
There is still no way to adjust the settings with LC4 loaded.
2010 owner dreaming of a 4100 LC4 launch made possible by Cobb.
#20 Dave@GotboostPerformance Posted 13 January 2012 - 11:03 PM
  • SpecV Member
  • 4,519 posts
View PostChurch, on 13 January 2012 - 10:49 PM, said:
Not true….
+1 this is true
'09 GT-R titanium:
email and paypal
