ETS - Extreme Turbo Systems GT-R R35 Turbo Kit - Introductory pricing! - $9950.00 (Plus Cash Back Incentives)
ETS Extreme Turbo Systems
53 replies to this topic
#1 ETS Michael Posted 10 May 2012 - 06:43 PM
ETS Michael
  • Premier International Vendor
  • Extreme Turbo Systems
  • 2,161 posts
For serious power upgrades on the Nissan GTR look no further than an ETS GTR Turbo Kit. Packed with features like our high flowing 1.5" runner ETS manifold, true Merge Collector, full 3” Downpipe, Recirculated waste gate, high flow large diameter intercooler piping, Tial 44mm MVR Wastegates, Heat Shields, and a wide range of turbochargers, these kits will get the job done, street or track. Along with great performance, Features such as an exhaust flex, T-Bolt Clamps, 4ply silicone, and braided oil lines, will help make sure that you do not have to use the ETS Life Time Warranty!
Recently the GTX3076R was dyno'd at 32psi on C16 and put down 1087/901 @ 32psi (Low Boost) and ran 9.30@157mph in full street trim.  (Ivey Tune - Dyno)
Features:
  • 1.5" Runners over competitors 1.25" Runners
  • S Covers (4.0" Inlet) vs competitors E Cover (3.0" Inlet)
  • Fits Garrett 30R, 35R, GTX30R, GTX35R, HTA30R, HTA3582R, HTA3586R Turbochargers.
Includes:
  • 2x Manifolds
  • 2x Turbochargers
  • 2x Wastegates
  • 2x Downpipes
  • 2x Dump Tubes (Recirculated)
  • 2x Heat Shields
  • 2x 44mm TiAL MVR Wastegates
  • 2x Inlet Tubes
  • Lower Intercooler Piping
  • Oil Lines
  • Water Lines
Large runners – At 630cc per cylinder, the vr38 is 21% per cylinder than most 3.0l 6cyl and 2.0l 4cyl. On a cylinder to cylinder basis. To put a small runner on such a large cylinder is like putting a restrictor plate on the engine.
S Cover Turbos – Most kits on the market use what’s called a “Compact” cover turbo, or a hybrid turbo with either a Subaru, or Mitsubishi 20g housings. At low flow rates these housings work OK, but on anything over 800whp we feel that they are less than optimal compared to a true Garrett or  “S”  cover. The reason the S cover performs so much better is that they have a much larger diffuser area. This is the area where the air leaving the compressor wheel has time to slow down before leaving the compressor housing of the turbo. As the larger the area that the air is allowed to slow down in, the higher the pressure ration that the turbo can operate in.  Also the lower the outlet temps will be.
Heat Shields – As the front of the GT-R is Aluminum, an unshielded kit can distort or weaken the front end of the vehicle. Also on the passenger side, the fuel lines must be kept cool for both the obvious fire reasons, but also to avoid tuning issues with a varying fuel density.  Also if the fuel is allowed to get too hot, it can cause vapor lock issues at the inlets of very high flow pumps.
Pre-Assembled – Because of the very tight fitment of the R35 engine bay, we feel that the alignment of the kit must be perfect.  The V-Band connections allow for a multitude of clocking positions,  if not clocked perfectly, there could be many in and out attempts for install. This will cost either the shop or the customer excess money. To minimize this confusion, our kits come pre-assembled, with all water and oil lines installed. This will be a major labor savings at time of install.
Equal length runners – All cylinders, front to back and side to side have runners of a mean length of 12” =/- .300 This allows for precise tuning, crisper throttle response and less individual cylinder trimming. Also to compliment the 12” length which will work best 6500-8000 rpm, we use a moderately angled merge collector so there is a powerful scavenging effect to adjacent cylinders at the collector. This creates less back pressure at the exhaust valves and better overall breathing of the engine.
Wastegates in line with flow – With the very high flow rates of the new billet wheel turbo's, we have found the wastegate system must be very efficient, or else boost creep could be induced. As well a keeping run away boost under control, a very efficient wastegate system will allow tuners to start a tune at a much lower boost pressure, ensuring that the whole tuning process is done safely.
Factory Intake, IC pipe positions – Both the intakes and intercooler pipes terminate in factory positions, allowing the turbo kit to bolt up to your existing stock turbo intakes and Intercooler kits.
Down Pipes to factory locations – The High flowing 3” v band downpipes terminate at factory location allowing perfect connection to factory or aftermarket Y pipes. Downpipes are also bracketed to help locate the correct clocking outside the car
Critical Lines Away from heat – All of the Oil/Water lines are routed away from heat, down and around the turbos, instead of over and across the turbos. This will ensure a lifetime service life for these lines, while also lowering the temperatures of the fluids within the lines.
Support Brackets for Critical Lines – All Oil / Water lines are bracketed to prevent vibration or failures. This is extremely important for track vehicles, where high vibration and G forces can cause premature failure of unsupported lines.
Fully ported at every transition – From the head flanges to the exhaust flanges and even the PCV barbs in between, we pride ourselves on the best craftsmanship and attention to detail in the industry.  This means that all flanges are surfaced, all transitions ported, and all pieces are clean. These details may not make any major power differences, but it can be the difference in numbers such as 998 vs 1002 whp.
Lifetime Warranty – Full Lifetime warranty on all fabricated parts, and manufactures warranty on turbo's.
ETS GTR Bounty
Extreme Turbo Systems has allocated a six figure budget for the advertising of our new GT-R turbo kit. After careful consideration of various marketing avenues, we feel that in addition to promoting the performance of our own shop vehicle, one of the best things that we can do is to get our products in the hands of first hand customers. To accomplish this we will heavily discount the kit until the end of this year (2012). In addition to the discount, we will offer a Bounty for customers who wish to push their vehicles to the limits. So without further ado, the pricing will be as follows;
• After Jan. 1 2013, the kit will sell for the regular price of $12,450, although the bounty will stay in effect until all 12ea 9sec and all 6ea 8sec positions are filled.
How to collect
  • Base Price for 30r & 35r kits will be $9950
  • The first 12 people to run a 9sec pass will receive $1000 cash back
  • The first 6 vehicles to run an 8sec pass will receive $5000 cash back
  • ** If you run a 9 second run previously, you will receive $4,000 ($5,000 Total)
    • Video of your 9 second or 8 second run with engine bay shot showing the ETS GTR Turbo Kit.
    • Scanned time slip
    • Engine bay shot for promotional use on our website
    • No Nitrous, No Downhill Tracks or anything else that could take away from the credibility of the run
More Info -> Check out our site at: ETS GT-R R35 Turbo Kit
Thanks!
Michael
E: Michael@extremeturbosystems.com
P: 360-896-3000
F: 360-896-3100
AIM: ETS MichaelR
Web: http://www.extremeturbosystems.com
Facebook: http://www.facebook.com/ExtremeTurbo/
Michael Roark - Extreme Turbo Systems - 360-896-3000 - Sales@extremeturbosystems.com
Facebook: http://www.facebook.com/extremeturbo
WORLDS FASTEST R35 GT-R! - 7.49 @ 189 mph (ETS Top Mount Kit, ETS 4.1L Motor, ETS CNC Heads, ETS Race Air/Air Intercooler, ETS Race Exhaust)
Worlds Fastest/Quickest Stock ECU 7.49 / 189mph (ETS Super Silver - Top Mount Kit)
Worlds Fastest 30-130 on Stock ECU - 3.57
Worlds Fastest 60-130 on Stock ECU - 2.28
Worlds Fastest 100-150 on Stock ECU - 2.21
Quickest Car in the Middle East 7.92 (FPerformance in Dubai)
Worlds Quickest 60' 1.28
1/2 Mile (Vbox) - 214.X
First company to put multiple GT-R's into the 7's.
#2 135Hoser Posted 10 May 2012 - 06:58 PM
135Hoser
  • 335 posts
Pure Sex.
With the 4" Intake on the turbo, which intake would you reccomend? Or should one just run a 3" to 4" coupler/reducer
Edited by 135Hoser, 10 May 2012 - 07:02 PM.
I has car. It go fast.
Soon to has built motor
#3 JMH-GTR Posted 10 May 2012 - 07:37 PM
JMH-GTR
  • Resident Dickhead
  • 746 posts
Like I stated in the other thread, the rebate is cool and all, but ONLY if it applies to customer cars and not shop cars. Just wanted to make sure someone sees this. :)
2009 GT-R SS GT1R
"Tell me about it! F this warranty. If it breaks it breaks. The worlds supposed to end in 2012 anyway."
Member: GTARRR
#4 celsius Posted 10 May 2012 - 09:32 PM
celsius
  • 6,612 posts
Awesome kit!  Great job ETS! :thumbsup:
#5 MrJimi Posted 10 May 2012 - 11:08 PM
MrJimi
  • 376 posts
dam i need a trans and engine build before this ...
#6 Chipster Posted 11 May 2012 - 07:57 AM
Chipster
  • 115 posts
Beyond this kit what else is needed to "safely" make those power levels?
#7 Bulldogmike Posted 11 May 2012 - 08:09 AM
Bulldogmike
  • Bulldogmike
  • 609 posts
i LOVE this system and love ETS, but.... as MrJimi states - I too learned that I would need significant upgrades to tranny and Engine to run this system,. Im sure for those in the financial position, this would be excellent as i am totally impressed with the quality of ETS systems (I have their intercooler)
The Topspeed Motorsports big block Flex fuel Track edition, GTC Racing Technology, ETS 3586 turbos, Shep Stage 4 Transmission, Custom HRE wheels, Cobb Flex Fuel Tuned, ACGautomotive, Aerocatch, Sparco EVO II seats, Heigo, Carkit Company, SSP. EI Racing, Got Boost, Carbon Wraps Orlando, Cool Suit, Custom TSM Aero including Custom Fixed Wing
#8 ETS Michael Posted 11 May 2012 - 09:44 AM
ETS Michael
  • 2,161 posts
Quote Below.
Quote
View Post135Hoser, on 10 May 2012 - 07:39 PM, said:
For the rebate, Can I drop a wrecked R35 a quarter mile from a crane?
No :)
View PostJMH-GTR, on 10 May 2012 - 07:33 PM, said:
The rebate thing is cool and all, but ONLY if it applied to customer cars and not shop cars.
We designed the program to work for customers and shop cars.  Our car will not count towards the rebate program.  One thing I have learned about our industry is most shop cars are the customers cars.  The car can be driven by the owner or the shop.  We are more focused on showing how the kits perform.
View PostBlkdragn, on 10 May 2012 - 09:32 PM, said:
I think they only have 1 shop car, and it goes without saying that they are speaking of customer cars. Unless I missed something?
Hellauva deal by the way! If I can't reach 8s with my new set-up, I'll definetly look into this! :clap:
Thanks man!  I've talked to several customers on the phone already who have plans on building an 8-sec gtr.  This should be an interesting last half of the year for the GTR community.
Thanks again everyone!  If you have any other questions, let me know!
Thanks!
#9 ETS Michael Posted 11 May 2012 - 09:45 AM
ETS Michael
  • 2,161 posts
I'm also looking into adding the option of a GT28 if anyone is interested in that turbo setup as well.
Thanks!
Michael
#10 Mike@TopSpeed Posted 11 May 2012 - 10:01 AM
Mike@TopSpeed
  • International Vendor
  • 579 posts
Depends on what power level you're after.  For the kind of power you would need to go 9s or 8s you would need a built shortblock & transmission as well as the typical supporting mods (intercooler, fuel system, full exhaust, etc).  I have it all in a line item estimate if you'd like to see it.
Mike Adams
Call: 866 / 94 SPEED
mike@topspeedtuned.com
TopSpeedTuned.com
**AWD Dyno Tuning
**Parts, Sales, Service
#11 GTRcHaRgEr Posted 11 May 2012 - 01:05 PM
GTRcHaRgEr
  • LiMiTLeSs
  • 3,154 posts
Thanks!
Michael
Would it be cheaper if you did the gtx28 option?
09 Black Premium DBA Conversion ..... ALPHA 12 Powered TSM Tuned.....
#12 ETS Michael Posted 11 May 2012 - 01:48 PM
ETS Michael
  • 2,161 posts
Yes, it would be about 300 cheaper if we go with the GTX28 option over the GTX30 option.  I'm going to get the GTX28 put on the site shortly.
Thanks!
#13 ETS Michael Posted 16 May 2012 - 02:54 PM
ETS Michael
  • 2,161 posts
If anyone is interested in making a lot more power we have the option of the HTA 3794.
http://store.forcedp...&Category_Code=
Edited by MichaelRoark, 16 May 2012 - 02:55 PM.
#14 ETS Michael Posted 22 May 2012 - 04:11 PM
ETS Michael
  • 2,161 posts
3794 is now on the website.
#15 ETS Michael Posted 25 May 2012 - 02:47 PM
ETS Michael
  • 2,161 posts
Have a great weekend everyone.  Any questions, don't hesitate to ask.
#16 ETS Michael Posted 22 June 2012 - 11:46 AM
ETS Michael
  • 2,161 posts
Happy Friday!
#17 Force-Fed Performance Posted 23 June 2012 - 02:25 PM
  • 88 posts
These are probably the most complete well put together kits available for the GTR thus far. We have been using and dealing with ETS for some years now on customer evos, subarus, and toyotas and have yet to encounter a problem with a single product. Cant wait to get our hands on one of these kits for a customer GTR
#18 ETS Michael Posted 09 July 2012 - 03:10 PM
ETS Michael
  • 2,161 posts
Thanks man!  If anyone has questions, let me know!
#19 ETS Michael Posted 17 July 2012 - 12:19 PM
ETS Michael
  • 2,161 posts
GET PAID! :)
#20 ETS Michael Posted 19 July 2012 - 04:43 PM
ETS Michael
  • 2,161 posts
$1,000 and $5,000 bounty still available!!
HTA3794 Kit has been added to the website.
