There's a module that looks for three lock signals on the canbus then tells the starter module to fire the car.
My iPhone remote start works perfectly but the new module cannot read from the canbus as it needs to.
This is odd because I used to have a viper alarm from directed that would be armed/disarmed by sensing the lock signal on the canbus generated by the standard key, dok didn't need to use the viper remote.
Now I just use my iPhone start, but I'd love to be able to use the stock key as the hardware is supposed to allow.
Directed's technical people are in Romania, not the us, and they think there's a difference us to edm, but I don't think so. I figure if soe figures it out stateside I stand a chance of making it work in the uk.
You guys got the kit from XpressKit.com right? That's from Directed DEI, and it said it will work with GT-R, even have all the installation manual and stuff, looks promising.
Hmmm, been reading about this for the past hour or so trying to figure it out. Seems most solutions require a bypass system with an aftermarket remote start system (2 boxes). iDatalink supposedly makes the better bypasses, but as mentioned they require a remote starter. They have one bypass system called RS Firmware which doesn't require the remote start system, but Nissan isn't listed. For Directed (or xpresskit) it appears that the DB-ALL RSR works for the GT-R. Thus you get a bypass and don't need the separate remote starter as the programming for it (using an oem keyfob) is already in the bypass. See link ==> http://xpresskit.com/DocumentDownload.aspx?documentid=7534&productid=461&firmwareid=3266
Hmmm, been reading about this for the past hour or so trying to figure it out. Seems most solutions require a bypass system with an aftermarket remote start system (2 boxes). iDatalink supposedly makes the better bypasses, but as mentioned they require a remote starter. They have one bypass system called RS Firmware which doesn't require the remote start system, but Nissan isn't listed. For Directed (or xpresskit) it appears that the DB-ALL RSR works for the GT-R. Thus you get a bypass and don't need the separate remote starter as the programming for it (using an oem keyfob) is already in the bypass. See link ==> http://xpresskit.com...firmwareid=3266
This is what I have - the RSR from directed, but I know for sure I have two distinct modules. the second one I assume being the iphone remote module with the sim card built in.
i hate car alarms and just would love to have a remote starter with just lock and unlock. i love the viper system where you car start the car with your phone and or from a computer.
I've ditched the Viper part of my install, but I still have the remote start, monitoring and diagnostics via the directed iphone app.
My next step is to get the remote start to work on the standard key, but ultimately I don't need it as I always have my iphone with me. The iphone takes about 8 seconds to start the car, the three button press would be instant.
To the guy who asked me what I have in my car already, I have asked my installer by text message, and several days later, I'm still waiting to hear.
Wait a sec, I thought even with the DB-ALL you still need the remote start module for the remote start portion, the DB-ALL is just for connection to the CANBUS, if you read the installation manual, it seems like DB-ALL is tying into the remote start module somehow, which means, you still need to get a basic remote start system even if you want to use your OEM fob. Correct?
^^^ you definitely need a seperate module for smart phone connectivity, but DB-ALL supposedly able to remote start using OEM key without a full alarm system.
Honestly I am still a bit confused on what is definitely needed to make it work, and what function/features comes with what unit. The more I read, the more I am confused, even the installation manual itself is ambiguous. DB-All is not expensive at all, I will just bite the bullet and try it out, the worst part of this whole thing is that I might need to cut some OEM wires, that's the most I hate, unless I can find some OEM connectors.
DB-ALL with RSR firmware will do remote start via 3 lock press. Can additionally add Smart Start module. So you could start with short range via remote or unlimited range with app. we installed both on our 2010 works great
Thanks for the info and confirmation. Did you install yourself? If you did I would be interested in talking if you are willing, as I'm looking to make it easier for folks to install with some plug and play harnesses.
ok so i figured out that i just need the db-all and the programming module to make it work on the gtr. the wiring doesnt look too complicated and easily reversible
does anyone have an account to activate the smartstart module? it appears that you need a dealer account to do that =(
Would really like to avoid all the wire issues. There's some guy that installs it into his Dodge Ram on youtube in like 10 mins and he's done... Seems like Directed has harnesses for a few companies (Chrysler for the Ram), but not Nissan
Related Threads
Nissan GT-R Forum
1.7M posts
66.9K members
Since 2004
