Is my Tune safe?
  • This topic is locked This topic is locked
62 replies to this topic
#1 GenghisGTR
GenghisGTR
    GTRLIFE Newbie
  • 45 posts
Posted 18 January 2013 - 12:19 AM
Got a custom etune from a vendor here, car runs great but friend look at my log said im running too Rich and aggressive boost
Car have midpipe and exhaust only
Can anyone chime in
Thanks!
#2 Bill@SprayItRacing
Bill@SprayItRacing
  • 2,069 posts
Posted 18 January 2013 - 12:30 AM
Fueling wise on a car with Stock Downpipes, that's about what I like to be tuning at.
You are OUT of fuel and air metering. 120 injector duty cycle, and over 5V on the MAF sensors
If you want to be safe, I would run a bit less boost. But thats up to you and your tuner.
Tell him you want something a bit more conservative.
#3 Visconti
Visconti
    --- EcuTek Master Dealer --- COBB Authorized ProTuner
  • 5,170 posts
Posted 18 January 2013 - 12:32 AM
Can anyone chime in
Thanks!
What year car do you have?
Unless my ipad is showing this log incorrectly yout missing a few important things from your dsts log.
I would add waste gate duty to your datalog and ignition timing
91 or 93 octane ?
John
Edited by Visconti, 18 January 2013 - 12:34 AM.
#4 Bill@SprayItRacing
Bill@SprayItRacing
  • 2,069 posts
Posted 18 January 2013 - 12:39 AM
91 or 93 octane ?
John
14-15 degrees of timing, 100% WGDC
Look at the last 2 logs
#5 changstr
changstr
    Nova Uniao
  • 1,336 posts
Posted 18 January 2013 - 12:44 AM
Who tuned this?
#6 GenghisGTR
GenghisGTR
    GTRLIFE Newbie
  • 45 posts
Posted 18 January 2013 - 03:55 AM
Tuner said the map was conserative but I did request more conservative map from tuner
car ran very awaked full throttle on second gear felt like boost cut .am scare to even do 3rd gear pull :( on this map
Thanks for the advise
Ill leave the tuner's name undisclosed for now
#7 changstr
changstr
    Nova Uniao
  • 1,336 posts
Posted 18 January 2013 - 04:52 AM
Who tuned it?
#8 Visconti
Visconti
  • 5,170 posts
Posted 18 January 2013 - 05:05 AM
I'm gonna send you a PM
#9 Cicio@TopSpeed
Cicio@TopSpeed
  • International Vendor
  • 2,572 posts
Posted 18 January 2013 - 08:29 AM
Can anyone chime in
Thanks!
Who tuned it?
Chang I love how you just wanna know the truth and what is real! I'm the same way!
To the OP. The answer to the question in your title is no. 100WGD, 22+psi on pump gas is crazy aggressive with stock turbos. Your fuel system is beyond maxed out as Bill said and your STFTs are not consistent with what I would call an acceptable tune if I was doing it.
Depending on what year your car is you also may want to check out this thread
http://www.gtrlife.c...__fromsearch__1
Because based on your timing numbers, boost and AFRs I find it hard to believe the car isn't actually knocking.
Personally I would ask your tuner to please tune your car at 19-20 PSI and if he did touch the knock sensitivity tables to please put them back.
If I can be of more help let me know.
~Cicio
-OneLap of America Overall 1st Place - 2010, 2011, 2012, 2013
-Shootout 2015 Overall 1st Place & 2nd Place
-TX2K13 Overall 1st Place | TX2K13 Class 2 1st Place
-TX2K15 Class 4 2nd Place | TX2K15 Roll Race 1st Place SS
-FL2K15 Overall 1st Place
-Fastest Stock Frame Turbo GT-R In the World @ 8.14@170
-Standing Half Mile Stock Frame Record @ 206 MPH
-TopSpeed Motorsports Shop Car @ 7.594 & 189.51
-Fastest Customer ETS Pro1900 @ 7.70@180
-Standing Half Mile 218MPH ETS Pro1900
Call: 678-297-7770
cicio@topspeedmotorsports.com
TopSpeedMotorsports.com
**AWD Dyno Tuning
**Parts, Sales, Service
#10 Visconti
Visconti
  • 5,170 posts
Posted 18 January 2013 - 11:25 AM
We also don't know what year it is.. If its a 12-13 then it has the wrong firmware and likely a CBA tune.
#11 BoostCrzy
BoostCrzy
  • 1,351 posts
Posted 18 January 2013 - 01:16 PM
boost looks lower in the last logs.....one thing you also want to be aware of....when running the car rich you will see higher injector duty...as they are passing more fuel. Richer is conservative....but the injectors will need to be changed to lower duty cycle while maintaining the safer/richer AFR.....you could get more aggressive and lean the car out to lower duty cycle but that would be counter intuitive.
best bet is to get larger injectors if you want to see lower injector duty cycle. Your Air Fuel ratio looks very safe at 11.1...... injectors seem to be having no problem providing enough fuel at this point....the injector duty cycle (as well as a few other parameters in the cobb logging) arent 100% accurate and are really more of a baselining tool than anything. dont hold them to task on accuracy. I have seen injector duties as high as 130+% while maintaining commanded AFR's .....the calculations these computers spit out are influenced by many other scales so its not going to be perfect.
Edited by BoostCrzy, 18 January 2013 - 01:18 PM.
- Jack Cecil -
#12 Goonthree
Goonthree
  • 8,071 posts
Posted 18 January 2013 - 04:25 PM
Have mas voltage and injectors all over 100% is not a safe practice on a tune. There are reasons why no oem cars do that. Upgrade your injectors and get 3" intake and retune would get all parameters under equipment maker limits. Basically when mas voltage is over 4.91v it is saturation region, it cant tell how much more air is coming in.
I would think if you do a pull to top speed or hard into 6th the car will cutout based on my experience.
#13 Church
Church
    Sophisticated
  • 2,978 posts
Posted 18 January 2013 - 04:40 PM
Update your Cobb AP. The last version had problems with showing zero knock. Especially in 2010's. After the Jan 2013 update they fixed the problem.
#14 achenator
achenator
  • 2,741 posts
Posted 18 January 2013 - 05:04 PM
As in not showing knock or too much?
#15 BoostCrzy
BoostCrzy
  • 1,351 posts
Posted 18 January 2013 - 09:08 PM
not showing....good point James...yes everyone should check to make sure they are using the newest firmware please!
- Jack Cecil -
#16 Visconti
Visconti
  • 5,170 posts
Posted 18 January 2013 - 10:20 PM
Yeah he should be all set now ;)
#17 achenator
achenator
  • 2,741 posts
Posted 18 January 2013 - 10:27 PM
Never had a problem with mine showing on my 2010 lol.
#18 GenghisGTR
GenghisGTR
    GTRLIFE Newbie
  • 45 posts
Posted 18 January 2013 - 11:31 PM
Did send the datalog to the tuner but he never mentioned about the new firmware he just sent me another reviesed map, log 12 and 13 was done in the new firmware
I have 5 maps total from this tuner and one of them are corrupted car wont start
Just upset with the service and excuse he kept telling me .. this should be a pretty straight forward simple process sigh...
#19 GenghisGTR
GenghisGTR
    GTRLIFE Newbie
  • 45 posts
Posted 18 January 2013 - 11:36 PM
John was kindly enough to send me a map to try out , really apprecaite his help and going through datalog set list with me
#20 Wicked
Wicked
    R35 Owner
  • Site Moderator
  • 6,771 posts
Posted 19 January 2013 - 02:07 PM
Ya John is a good guy.
Switzer Stage 1 Motor Build
Switzer Stage 1 Tranny Build
