Brake job labor cost at a dealer?
35 replies to this topic
#21 shawnhayes Posted 25 April 2013 - 06:13 PM
shawnhayes
  • NISMO Member
  • 5,359 posts
View PostDoug@WGP, on 25 April 2013 - 05:40 PM, said:
Typically it's 4hrs @ 90.  the 6hrs comes into play when we have to assemble hats, bleed, etc.
Four hours at $90 CHARGE is reasonable to make sure the job is done perfectly well, but I certainly don't think your techs are really taking four hours.  That is reasonable at $90 per corner.
Disassembly and reassembly of hats is indeed tedious, so if that's what you mean by taking that long okay, and I take any meanness I projected back.  But, if at $100/hour, 6 hours for a rotor/pad changeout and a brake bleed (without hats) seems excessive.
#22 HighlanderD Posted 25 April 2013 - 08:52 PM
HighlanderD
  • SpecV Member
  • 3,540 posts
I don't think overpriced and WGP have ever been used in the same sentence ;)
First Person to Ever Remove a GT-R Drivetrain in their own garage
#23 theeddie Posted 25 April 2013 - 09:24 PM
theeddie
  • The
  • 383 posts
I just did all 4 of mine in 40 min.   brake pad swap only. would of been 30 min but i couldn't get to the center jack point on the front
super easy to change.
Edited by theeddie, 25 April 2013 - 09:27 PM.
EB 3" INTAKES | EB 90mm midpipe | LC5 | RED | ID 1000cc | EB DOWNPIPES | AAM R-MAF (not installed) | GFB BOV | COBB 006 | STILLEN LIP |
Total of $3194 in mods :) the c-cup 600 kit
10.53 @134
#24 ty423 Posted 26 April 2013 - 04:05 AM
ty423
  • 366 posts
Just doing pads is a lot easier than doing a full on brake job.   This car is a little different.   There are a few more bolts than your regular caliper bolts you need to take off especially in the fronts.   I think it took me about 1hr a corner and then add on the procedure to lift the car with floor jacks and jackstands.  Bleeding would be atleast another hour.  so 6 hours doesn't seem too off to me.
Edited by ty423, 26 April 2013 - 04:06 AM.
#25 STIITS Posted 26 April 2013 - 01:52 PM
STIITS
  • R37 Member
  • 671 posts
The removing of the calipers I believe is the most time consuming....
#26 theeddie Posted 26 April 2013 - 02:01 PM
theeddie
  • The
  • 383 posts
an hour per side with hats.
2.5/hr with bleed, rotors -no hat change
hour for pad only swap.
would seem like a fair deal in my mind, but i'm a very efficient wrench-er,
shops can make up time because of the use of lifts, air tools and efficiency. If a shop tried to charge me 6 hours for a brake job, i would laugh at them turn around and walk out laughing as i went to my car.
Edited by theeddie, 26 April 2013 - 02:02 PM.
10.53 @134
#27 shawnhayes Posted 26 April 2013 - 03:16 PM
shawnhayes
  • NISMO Member
  • 5,359 posts
Two bolts, 10 mm hex driver.  Unless you don't have strength/torque to do it, or if it's your first time, it takes very little time.  Maybe 10 min max. First timers, 30 getting down the details.
#28 bhk1004 Posted 26 April 2013 - 03:23 PM
bhk1004
  • 1,859 posts
hmmmm just went to my shop to see how many hours of labor itll take to swap in steel braided lines, possibly resurfacing my rotors, pads, and new fluids. they said 3 hours tops. but should be finished in 2-2.5 hours. the bleeding was the longest at around 1 hour by itself. lets hope they keep to the timeline next week.
#29 djpathfinder Posted 26 April 2013 - 03:29 PM
djpathfinder
  • Gojira driver
  • 929 posts
I'm for hire...and will provide the beer prior to punching you randomly in the balls. LOL!
2012 GT-R Black Edition (Jet Black)
#30 Tim1137 Posted 29 April 2013 - 09:30 AM
Tim1137
  • 369 posts
Doug do you pay your tech(s) hourly or flat rate?
At my dealership, we charge 2 hours per axle so 4 hours is fair in my book, although us technically inclined people know it doesn't take that long, its not only about the physical time it takes.
#31 HighlanderD Posted 29 April 2013 - 10:21 AM
HighlanderD
  • SpecV Member
  • 3,540 posts
I pay them hourly.  I find they work more carefully when I do it this way as opposed to them slapping something together in a couple hours so they can get "something for nothing."
#32 TheHitman™ Posted 30 April 2013 - 04:27 AM
TheHitman™
  • The World Warrior
  • 7,186 posts
I do it with my friends. It takes about 3 hours to do all 4 rotors and pads. Also if you just daily drive the car you do not need to change to stainless steel brake lines and depending on your mileage and look of your rotors you shouldn't need rotors either.
Violent Blue 2012 GT-R Black Edition
2009 Audi A4 Avant S-Line
Burn Unit Original Member
Join the R35 GT-R owners group. Exclusive closed owners only group on facebook:
https://www.facebook.com/groups/GTRLOG/
#33 shawnhayes Posted 30 April 2013 - 04:16 PM
shawnhayes
  • NISMO Member
  • 5,359 posts
The 2009's had soft brake lines by comparison to the later models.  Even Nissan upgraded them.
#34 TheHitman™ Posted 01 May 2013 - 02:47 AM
TheHitman™
  • The World Warrior
  • 7,186 posts
For a daily driven car it shouldn't be that much of an issue.
#35 shawnhayes Posted 01 May 2013 - 05:55 AM
shawnhayes
  • NISMO Member
  • 5,359 posts
1000% agree, but if you're going to track it, I'd suggest at least the later Nissan lines.  Somebody on here who has upgraded to stainless will have some laying around.
#36 ModFreaksGTR Posted 01 May 2013 - 06:04 AM
ModFreaksGTR
  • SpecV Member
  • 3,960 posts
FML!!!! There's always something to be upgraded on my 09. Thanks for the info Shawn. I had had no clue about the brake lines being updated on later models. Only makes sense as the car evolves I guess.
ModFreaksGTR
2013 FBO E85 GT-R "El Diablo Blanco"
