2009 headlight retrofit
3 replies to this topic
#1 Tosh
Tosh
    GTRLIFE Newbie
  • 29 posts
Posted 05 January 2016 - 04:40 PM
I'll be honest, the headlights are absolutely terrible on the GT-R. I put new Morimoto 6k bulbs in the lows and a 6k hid kit for high beam, and all that did was focus all the light right in front of the car. HIDs in the high beams are just terrible on this car..
Flash forward a few months, I decided to open the headlights and order some Mini H1 bi-xenon projectors for the old high beam housings, and replaced the low beam projectors fresnel lens with a clear lens. I then modified the wiring to allow all 4 projectors illuminate on low beam. I also added a few LED light bars.. (I'm afraid of the dark)
Step one: take off front bumper. You do not need to remove the lip or the wheels to take out the headlights.
The standard low beam projector with fresnel lens and 6k bulb
The low beam with a clear lens installed, and same 6k bulb. The cutoff is much bluer which I like, and the light appears crisper and not so 'washed out'.
Right headlight powered on with both projectors illuminated. The steps are slightly different as the projectors aren't the same. The OEM projectors also bow down on the sides which made aligning the rotation somewhat difficult.
Now for paint. I just couldn't make this part look good. I spent way too much time messing around with painting and how to seal in the new projector so it didn't bleed light through behind the lens. I'll probably go with new shrouds in the future and redo this part.
I decided to go with a satin black to match the wrap on the car, along with a satin red 'eyebrow' above the projectors. I didn't paint the squirrel spotters or turn signal housing because I wanted it to remain bright and functional. The more light the better.
I also installed some led strips for a demon eye effect (it's very dim). They illuminate with the park lights.
Finished product. A million times better than the standard GT-R headlights, and crazy color at the cutoff too!
So, I figure that with 4-35w HID projectors, 2-13" spot light bars (60 Watts), and 1-22" hyperspot light bar (144 Watts), totals 344 Watts of total lighting and a theoretical output of 32,000 lumens. I'm happy now!
Edited by Tosh, 05 January 2016 - 05:01 PM.
2009 GT-R, Satin Black wrap, JacksTrans RR700 build, Cobb AP, Password JDM Mid, Meisterschaft Exhaust, Gotboost 3" intakes, GFB bov's, front & rear cameras, quad projector headlights
2009 Yamaha FZ6R, Bi-Xenon headlight retrofit
#2 Lambo Joe
Lambo Joe
    R35 member
  • 3086 posts
Posted 05 January 2016 - 11:33 PM
Nice writeup. I want to paint inside my headlights someday.
Joe
2014 Deep Blue Pearl "Lucy" - Pink Prototype Elite Prime 58s/ Shep 1K+/ MoteC/ 3.8L Fast Forward Racing Motor from IP/ Tuned by Taylor @ Cicios.
#3 BPG
BPG
  • 258 posts
Posted 12 January 2016 - 10:02 PM
Awesome! Where did you order the projectors from?
- 2009 Titanium
#4 Tosh
Tosh
    GTRLIFE Newbie
  • 29 posts
Posted 13 January 2016 - 06:24 PM
http://www.theretrofitsource.com
I have bought from them over the past 5 years. They're based in Atlanta. I'm always happy with the quality of their products.
