Ecutek with SD tune passing NY emissions?
#1
Posted 05 February 2016 - 07:48 PM
2015 Black Edition SS GTR
4.1L HKS 1000+
Shep 1k Transmission
Fore Triple 12 injector Setup [ID 1000cc primary / ID 2000cc secondary]
E85 Flex Fuel
#2
Posted 05 February 2016 - 11:18 PM
What's your setup ?
If your just FBO stay on MAF, don't see any advantage.
Edited by droptopp, 05 February 2016 - 11:18 PM.
Old setups : Alpha 9 w/ AMS 3.8, GTX3582R Gen II w/ AMS 4.1 billet crank, GTX3582R Gen II w/ AMS 4.0 big bore billet crank and of course FBO E85.
#3
Posted 05 February 2016 - 11:22 PM
STM said they would only tune with an SD kit on mine. Are you running it or MAF?Definitely not on Cobb. Need to run through MAF sensors as pass through. Probably sand on Ecutek.
What's your setup ?
Not trying to have an issue passing emissions.
Sent from my SM-G920V using Tapatalk
MK6 GTI 3xxwhp 4xxwtq
2500HD SLT 4x4 Duramax 6" lift, 4xxwhp 9xxwtq
#4
Posted 05 February 2016 - 11:27 PM
What's your setup ?
Im currently FBO on a SD tune with cobb and i pass nys emissions. Had my tuner make me a MAF map and running o2 fowlers. When the time comes i swap to the MAF map and baby the car to inspection. Pass then swap maps. No problems.
05 Subaru WRX STi - 04 Porsche 996 TT Cab (Sold) - 93 GMC Typhoon (Sold) - 2011 Triumph Daytona 675
2012 GT-R Deep Blue Pearl BE Alpha 10x
Instagram: UrbanGTR
#5
Posted 05 February 2016 - 11:35 PM
Sent from my SM-N910T using GT-R Life mobile app
4.1L HKS 1000+
E85 Flex Fuel
#6
Posted 05 February 2016 - 11:57 PM
Surprised, no need for SD on FBO E85, I passed NYS inspection easy on MAF. My problem with the A9 is I don't have MAF sensors I can use as a pass through for inspection only.
Khary's was on MAF and ran 9.9's @ 138 and also passed inspection.
#7
Posted 06 February 2016 - 12:27 AM
4.1L HKS 1000+
E85 Flex Fuel
#8
Posted 06 February 2016 - 02:23 AM
Sent emery an email. Might sell my SD kit if thats the case. Not sure why he told me SD only.
#9
Posted 06 February 2016 - 03:35 AM
Edited by dLad, 06 February 2016 - 03:36 AM.
White (Now Blue Chrome Wrapped) 2013 GTR
10.890 @ 122.11mph (stock)
#10
Posted 06 February 2016 - 07:39 AM
No. the purpose of the SD kit is to relocate the intake air temperature sensor to post-charge/intercooler which allows for more accurate representation of the temp at the throttle bodies. A side effect of this is that it simplifies the tuning process because airflow is adjusted via 1 table (the volumetric efficiency table) as opposed to a combination of several to correctly represent the MAF and pipe size characteristics.I think SD kit helps hold boost better to redline. In other words, once boost hits it's peak..it doesn't taper off as much. Correct me if I'm wrong.
Other benefits of SD include the ability to run Vent-To-Atmosphere BOVs without issue as the volume of air is accounted for, and also if you blow an intercooler pipe the car will run normally in vacuum, whereas on MAF it won't.
Edited by Bullitt 2496, 06 February 2016 - 07:41 AM.
- Cobb Protuner / EcuTek Master Tuner / MoTec Calibrator
[email protected]
Our Online Store
East Coast Location Durham, CT - West Coast Location Monroe, WA
#11
Posted 06 February 2016 - 09:18 AM
I've had several people tell me that recently they passed NY inspection
#12
Posted 06 February 2016 - 09:31 AM
4.1L HKS 1000+
E85 Flex Fuel
#13
Posted 06 February 2016 - 09:52 AM
They definitely can be, assuming the tuner takes the time to make sure the VE table is smooth in the drivability areas.This is exactly what I heard people tell me as well. I want to pass emissions with a SD tune. SD tune cars tend to be smoother or maybe it's just my imagination.
MAF tunes also suffer on drivability when the airflow is erratic, such as when the car has a big cam or in transitional areas such as tip in or quick liftoff and re-throttle, when the cooling fans kick on or off, or when the piping design creates turbulence.
I remember back in the day my Evo 8 with a big HKS suction open intake would stall at a stop light if something big revved it's engine next to me haha.
For a bit of legalese... On the subject of emissions passing... people need to remember that products like aftermarket tunes, downpipes, etc are installed for off-road use and the responsibility to pass emissions with these modifications is your own. I've been to shops where the tuners refuse to disable codes, etc., to protect themselves from the significant liability an EPA inspection could bring.
On another note, depending on your local criteria for readiness testing quantity pass/fail, the presence of flex fuel can also cause a fail because it typically disables the secondary air injection monitor.
Most of the Cobb cars that I've seen fail are typically because the injector settings aren't quite perfect and long term fuel trims aren't working as well as they should (or at all), which is a criteria for test readiness, and/or the tests won't ready if the injector scalar is over 1000cc.
Edited by Bullitt 2496, 06 February 2016 - 09:54 AM.
[email protected]
Our Online Store
#14
Posted 01 May 2016 - 08:33 AM
Reviving thread... this is good info right here -- thanks! Did a quick check with my scanner for readiness after I got my car home from Switzer (SD tuned) and saw that I had 3 not ready.
2014 F-150 Crew Cab XTR 4x4 Ecoboost (daily driver)
2015 BSM X5d M-Sport pkg (wife's)
2007 Alpine White M6 convertible (wife's)
2007 Ducati 1098s
2014 BMW HP4 Competition
2017 Yamaha R1M
#15
Posted 03 May 2016 - 10:58 AM
