Best Tire for GTR
#141
Posted 07 September 2020 - 10:03 PM
#142
Posted 07 September 2020 - 11:05 PM
Yes, it is possible to use the combination you suggest. Tire diameters are OK
295/35-20 $388 each, fits wheels 10-11.5" wide, perfect for 10.5" wide rim, tire diam 28.1", 30 lbs. each, XL load rated (stiffer sidewall)
305/35-20 $377 each, Limited Stock, fits wheels 10-12" wide, perfect for 11" wide rim, tire diam 28.4", 31 lbs. each, Standard load rated
A note on load ratings, the XL load rated tires are constructed with a stiffer sidewall to carry more load which gives the tire as slightly firmer ride and better handling responsiveness. 35 series sidewall is relatively stiff.
Using a 295 mm wide tire on the front OEM wheel will work, the tire will fit on a 1/2" more narrow rim but may require a little more technique by your mechanic. An experienced person should be OK but if it is their first time then it could be a struggle. I think you may find that the wider tire sizes are slightly better for what you want. Some owners report that an extra wide front tire size makes the steering feel sluggish and heavy but I think that is mostly with slower driving.
#143
Posted 06 October 2020 - 10:52 PM
Looking at getting one of the following Nitto tires:
- NT555
- Invo
- Motivo
I try and find them on the tire websites, but it doesn't seem like they show up when a GTR is selected. I'm trying to fit these on a 2015 GTR with OEM wheels and suspension. What sizes should I be searching directly and what is the best site to purchase? I take it that a normal shop would not normally install these (since they don't show up through the normal search) and I'd have to take them to my tuner? Thanks in advance.
#144
Posted 07 October 2020 - 01:37 AM
- NT555
- Invo
- Motivo
This are the ones you need.
NT555 G2
275/40/20 ZR
315/35/20 ZR
#145
Posted 07 October 2020 - 02:12 AM
Now they suck, the whole setup doesnt fit right. Circumference etc you know the ets problems.
Come on
#146
Posted 07 October 2020 - 03:25 AM
This are the ones you need. NT555 G2 275/40/20 ZR 315/35/20 ZR Sent from my iPhone using Tapatalk
Awesome, thank you!
#147
Posted 07 October 2020 - 08:35 AM
New R888R are horrific, the olde gen R888 was perfect for the R35
Come on
This is not true at all. I and many others run them in 285/35/20 and 325/30/20 and there aren't any issues at all. I have them on stock DBA wheels as well. On my second set now.
#148
Posted 07 October 2020 - 07:30 PM
American Tire Depot was having a deal on B3G1 on all tires. Thought I'd be coming up with getting the Motivos from there. Called for a quote and the extra "mandatory fees" and taxes almost doubled the price. Should be going to a place like American Tire Depot to get the tires installed or someplace else? Called another place down the street from me and they quoted about $60 less than ATD. However, trying to see if I can really come up on the promotion they have or if it's just some gimmick.
#149
Posted 07 October 2020 - 08:18 PM
#150
Posted 08 October 2020 - 01:38 AM
This setup is not available in Europe.
Calm down soya man
#151
Posted 08 October 2020 - 04:39 AM
You seem to be the one who needs to calm down from your previous post. Seemed really worked up about the toyos causing you issues :(This setup is not available in Europe.
Calm down soya man
Edited by Lordkevin, 08 October 2020 - 04:39 AM.
#152
Posted 22 February 2021 - 07:46 AM
19" rims for winter? has anybody used 19"
#153
Posted 22 February 2021 - 04:55 PM
Yes, it is possible.
Problem is GTR wheels are staggered so it might be hard to find one wheel size with an offset that works for both front and rear. What fits the rear will stick out more in the front. It is posible to choose an offset for the front and add a wheel spacer for the rear.
No need to go with extra wide wheels 19x9 to 19x9.5" could work and it might be harder to find wheels in that diameter that are wide enough.
Example of wheel
Work Emotion M8R Deep concave (Bronze, Matte Black, White, Gloss Black) listed at Vividracing.com
19x9.5" offsets from 12mm, 25mm, 38mm, about $500 each
Compared to OEM wheels these will fit-
Front with 38mm offset - rim will poke out 7mm farther, tire will poke out 17mm farther, otherwise clearance is good
Rear with 12mm offset - rim is same as OEM, tire will poke out 8mm farther, clearance is good
These wheels with different offsets would work with 275/40-19 tires for front and rear tire diameters to be equal.
Tire sizes need to be close to OEM tire diameter of 28" for both front and rear. If you have the same wheels on front and back you can choose a tire size that fits that wheel and should be ok for front and back clearance if you have OEM suspension.
If you want wider wheels then one option is to select the same wheel in 19x10.5" et 22 which will fit like an OEM wheel and still accept the 275/40-19 tire.
Or you can run the same wheel but wider in front wheel like 19x10.5" et 32 but the wheel will poke out
26mm more which is slightly beyond flush.
in general wider wheels in deep snow won't cut through as easily- consider your winter conditions and see-
http://racetrackdriv...wide-vs-narrow/
example winter tire-
Bridgestone Blizzak LM-32
275/40-19 $320 each, fits wheels 9-11" wide, perfect for 9.5" wide rim, tire diam. 27.7"
or
Pirelli Winter Sottozero 3
275/40-19 $387 each, standard load rated, tire diam. 27.7"
or in a Runflat
Pirelli Winter Sottozero Serie II runflat
275/40-19 $438 each, XL load rated, tire diam. 27.8" for extra safety of flat tire in winter or traffic
Tirerack winter tire test
https://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=181
#154
Posted 23 February 2021 - 12:49 AM
Come on
Was this ever confirmed to be a Valid point?
What size was this statement talking about? This post is lacking facts and specifics.
Are we even compare apples to apples here ?
285/35/20 and 325/30/20 Has been said to work for many owners.
#155
Posted 23 February 2021 - 03:56 PM
Yes, more details would be helpful.
Toyo R888R are the current model of streetable Track race tires while R888 was the older model.
R888 isn't available at tirerack.com in 20" sizes, selection is very limited.
R888R
325/30-20 fits rims 11-12" wide, perfect for 11.5" wide rim so not good fitment for OEM rear wheel 20x10.5".
For OEM wheels
Front 285/35-20 fits 9.5-11" wide rims, perfect for 10" wide rim, tire diam. 27.9"
Rear 315/30-20 fits 10.5-11.5" wide rims, perfect for 11" wide rim, tire diam. 27.5"
Tire size and fitment could be a factor as well as intended use and on what track surface.
Condition and age of tires as well as track and environment conditions are relevant.
Comparison of R888 vs R888R
https://www.turnolog...mpetition-tire/
https://dsportmag.co...ire-evaluation/
Tirerack owner survey for track tires
https://www.tirerack...play.jsp?type=C
#156
Posted 26 February 2021 - 06:56 PM
Unfortunately, the reality is you will never be able to confirm unless you try it yourself. On paper, those sizes are very close that you would think it shouldn't cause any issue, but there are people saying this set up fry the ETS. The general "rule of thumb" is the front/rear circumference needs to be within 3%, but there is no scientific proof on this. On the other hand, those that had problems with the R888 in those sizes, who knows what they have done to the car and what kind of abuse the car goes through (i.e. the problem may not actually be caused by the tires, but something else and just a coincidence the last things changed on the car were the tires).
At the end of the day, you are just left with information that are all over the place. So you either try it yourself or run square or OEM sizes just to be safe.
Edited by White_turbo, Today, 08:42 AM.
2018 SCCA Solo National Super Street 3rd Loser
Always looking for sponsorship to help out on events entry (autox/hpde) and such. Please PM me if interested. Super Street 09 GTR #924 / A Street Prepared 06 Evo #924
Follow me on Instagram: @garytsuikk
Subscribe to my youtube channel: https://www.youtube....LHxYspyZZxJZdYA
