Best budget CCM brake kit?
104 replies to this topic
#21 Dntlvet
Dntlvet
  • 4034 posts
Posted 08 May 2018 - 04:52 PM
ST rotors are amazing on my GT3 and I would expect the same on my GTR.
2019 GT3RS
2018 Porsche GT3
2016 Porsche GT4
2015 Porsche 991 GT3
2016 Porsche Cayenne Diesel
2010 BMW M3
2013 BE GTR (SOLD)
#22 dexterkatt
dexterkatt
  • 406 posts
Posted 21 May 2018 - 09:25 PM
GTRBillet, where do you buy C7 ceramic rotors for $1350 each?
#23 gtrbillet
gtrbillet
  • 563 posts
Posted 22 May 2018 - 06:52 AM
I may have mispoke.  This is the rotor i was referring to.  All you care about is the carbon "ring".  This is the 390x32mm "ring" that basically drops into the GTR with the correct "hats".
These guys sell them for the corvette as well.
https://www.ebay.com...fffff2ceb|iid:1
Gregg 2013 gtr premium
#24 gtrbillet
gtrbillet
  • 563 posts
Posted 22 May 2018 - 06:55 AM
Check this out.  This is a good deal I think.  You get the full set of rotors and then just need to buy the hats to adapt them to the GTR.
https://www.ebay.com...nwAAOSwFUxa7Iiu
#25 GTRick
GTRick
  • 396 posts
Posted 22 May 2018 - 11:49 AM
I had carbon ceramics on my ZR1 and I wouldn't want them on my GT-R.  At first, I was in love with them as they stop great and don't produce brake dust.
First, I found out the freeway vibration I couldn't get rid of with multiple attempts at tire balancing was due to the large CC rotors being out of balance.  This is a very common issue with ZR1s.  There is a procedure to balance the rotors and wheels together where they add weights to the rotors, but not many shops can do it properly or even understand what you are requesting.
Also as gtrbillet mentioned, they aren't great in the rain.  The rotors need heat to work properly.  Driving home on the interstate in the rain, they would cool down considerably.  When braking getting off a curved exit-ramp, there was very little stopping power to where it would make my heart skip a beat.  Subsequent stop and go traffic would be OK, but it's just that first time you hit them after cruising in the rain that can catch you off guard.
The final straw was when I took the car in for an oil change and they noticed chunks missing from the inside of the rotors.  They recommended I replace them at $5k for just the front pair. While racingbrake.com sells them a little cheaper, I found the whole ordeal disappointing as the car had less than 30k miles and was street driven.  If you track the car hard you reportedly only get a few sessions out of them.  A lot of Porsche and Corvette guys that frequent track events will convert to steel rotors as they are cheaper for consumables.  They hang the carbon ceramics on the wall in their garage and put them back on when it's time to sell.
For my GT-R, I plan to swap to slotted or j-hook rotors and call it a day.
#26 gtrbillet
gtrbillet
  • 563 posts
Posted 22 May 2018 - 02:52 PM
Thanks for the input GTRrick. I was actually saying that the factory iron rotors had More of a delay in the rain than the ccm’s. Also, I had read about the vibration/balance issue with the corvettes. I believe that problem was solved years ago by changes to the rotor mfg process. These things have been in the production world for awhile and are really starting to proliferate. From my experience, my car runs so nice and smooth down the highway. Right now I’m on black ed wheels and mpss. 80 in the highway in 6th is so smooth compared to the run flat blizzaks I was on for the winter. At this time I have 2k miles on my z28 ccm front rotors and really liking them. Can’t wait to get them on the rear.... Sent from my iPhone using Tapatalk
#27 GTRick
GTRick
  • 396 posts
Posted 22 May 2018 - 07:56 PM
My zr1 was a 12’ and had the dreaded vibration issue. Maybe it’s been sorted since then, but it was a pinned / frequent topic on the corvette forum.
My zr1 was autocrossed a bit by the prior owner so that may have contributed to the early degeneration. Up until that point, they were the best brakes I’ve ever had. Just not something you want to replace often due to cost.
I’ve heard CC brakes should last the life of the car if street driven exclusively, but track days take their toll quickly and CC aren’t as economical to replace frequently.
I’ve had 3 Porsches and 2 corvettes and it seemed all the hard core track guys swapped out the CC rotors for conventional. There were plenty of aftermarket conversion options to ditch the CC. Hence, I find it a bit funny when crossing over to GT-R world that people are swapping the other way. The grass is always greener on the other side I suppose.
#28 condaGTR
condaGTR
    GTRLIFE Newbie
  • 38 posts
Posted 23 May 2018 - 09:41 AM
Please update when you make a decision on the kit you go with...thx
#29 gtrbillet
gtrbillet
  • 563 posts
Posted 23 May 2018 - 09:45 AM
Agreed, if I was tracking and had to replace a lotta brakes, I’d prob stick with iron. My motivation was weight savings, longevity (street only) and a bit of the “cool” factor too. Sent from my iPhone using Tapatalk
#30 RacingBrake
RacingBrake
  • 111 posts
Posted 24 May 2018 - 12:09 PM
Where are the disc un-balanced weight coming from? just take a look behind the surface:
All rotors below are built with RB hardware exclusively designed for easy assembly and disassembly of CCM rotors.
Brembo (Chopped Fibers)
brembo_disc_5ee945661736b194611494c8283b
Surface Transforms (Continuous Fibers)
other_brand_89e2b09472d054ebeaa945e8eb37
RB (Continuous Long Fibers)
rb_1_6365b821ec585267a4de4d0551d1a07e10e
Edited by RacingBrake, 25 May 2018 - 09:23 AM.
#31 RacingBrake
RacingBrake
  • 111 posts
Posted 24 May 2018 - 12:28 PM
Design Difference:
Traditional Straight Vane Design (Brembo & ST): Rotor are non-directional (Left and right are the same, less efficient in cooling)
straight_vane_20780bf7651edcf5ad52f743bb
RB's Angle Vane Design: Rotors are directional (More efficient in cooling air circulation and can keep braking temperature lower)
angle_vane_a7d617126fa4d9873958b1278b244
#32 gtrbillet
gtrbillet
  • 563 posts
Posted 25 May 2018 - 06:51 AM
Can you fix those links?  I wanna see what you're trying to show us.  Thanks for the info as always.
#33 hunter
hunter
  • 2249 posts
Posted 25 May 2018 - 07:17 AM
Full CCM brakes drop 50 plus pounds of weight and that is a big improvement........ Porsche guy's do take off their CCM rotors etc. and store in garage if they track lots........ Then just re- install at time of sale......
GTR GUY IN AZ
#34 houstonT
houstonT
  • Event Organizer
  • 1832 posts
Posted 04 June 2018 - 02:49 PM
Doug at Weapons Grade Performance has a FULL BOLT ON, NO MODIFICATION set of CCB and pads coming my way this week.  I'll post pics and reviews once I get them...
Peter
2017 Nissan GTR - White/Black
2017 Huracan Performante - White/Black
1994 Supra -White/Black, 13k original miles
#35 Daddy21
Daddy21
  • 1646 posts
Posted 04 June 2018 - 04:32 PM
Peter
How much is the kit?
#36 houstonT
houstonT
  • Event Organizer
  • 1832 posts
Posted 05 June 2018 - 09:41 AM
Doug will need to chime in....
How much is the kit? Sent from my iPhone using Tapatalk
#37 hymas283
hymas283
  • 82 posts
Posted 05 June 2018 - 09:52 AM
Sub'd
#38 hymas283
hymas283
  • 82 posts
Posted 05 June 2018 - 10:01 AM
Not to hijack this thread, but what kind of life are people seeing when going to CCM? I'm looking to replace my brakes; my car has only 24k miles and i feel the stock brakes wore excessively quick. (only street driving, no AutoX or track use).
#39 Daddy21
Daddy21
  • 1646 posts
Posted 05 June 2018 - 10:15 AM
^^ That is a good question about the life of the rotors and pads. Sent from my iPhone using Tapatalk
#40 houstonT
houstonT
  • Event Organizer
  • 1832 posts
Posted 05 June 2018 - 01:48 PM
All CCB kits I've had (non GTR) lasted for the life of ownership (up to 40k miles) with less than 1/2 the wear.  I would anticipate in normal daily driving 100k-125k miles on a set.
Peter
