Ferrari California Carbon Rotors
4 replies to this topic
#1 Jd223
Jd223
    GTRLIFE Newbie
  • 43 posts
Posted 21 May 2020 - 11:48 AM
Anyone using these rotors in their GTR? And what modifications to get them to fit? Just fronts not rears
15 BE GTR Stock Engine/Trans GTX30R E85 [email protected] 5.14 60-130
#2 DUTCHGT-R
DUTCHGT-R
  • 178 posts
Posted 28 May 2020 - 02:58 PM
Send you a PM
#3 Warren-RB
Warren-RB
    Member
  • 70 posts
Posted 05 June 2020 - 03:50 PM
The F458 front OE measured as 398x36mm but the actual pad contact is 394mm.
ZR1 is measured as 394x36mm but the actual contact dia is only 390mm, GTR OE rotor nominal size is 390mm but the actual pad contact is only 387mm.
So for anyone who is planning to use those non OE CCM rotors to for retrofit, it all depends on how your rotor suppliers would spec the caliper spacers to correctly fit the pad to rotor without adverse effect i.e. pad overhang or set back (rotor is not fully contacted) resulting rotor stick up too much and interfere with OE caliper/hardware.
www.RacingBrake.com
#4 Wicked
Wicked
    R35 Owner
  • Site Moderator
  • 8501 posts
Posted 09 June 2020 - 09:01 AM
That's some good info.
Thanks Warren.
#5 Warren-RB
Warren-RB
    Member
  • 70 posts
Posted 30 June 2020 - 11:12 AM
Thanks Warren.
No problem. Those info are in our database and design table so they can be identified quick and easy.
By the way our CCM brake offer just kept expanding including the most recent release for Mustang GT500 (stock replacement) and the newest Corvette C8 (Complete system)
www.RacingBrake.com
