Nankang AR1 tire
10 replies to this topic
#1 13blackedition
13blackedition
    GTRLIFE Newbie
  • 10 posts
Posted 14 June 2020 - 02:20 PM
Anybody  hear about this tire? It's supposed to be real good. Some nice reviews on it from guys that use it on the Nurburgring.
#2 AutoXGTR
AutoXGTR
  • 6568 posts
Posted 14 June 2020 - 02:38 PM
See
https://www.audiboos...-vs-Maxxis-RC-1
https://www.youtube....h?v=hKXaOU6wfWE
Mentioned Toyo R888R may be good for less experienced drivers
It's a tire comparison of Treadwear 100 road race tires for track.
AR-1 comes in:
265/35-20 about $345 each
Fits wheels 9-10.5" wide, perfect for 9.5" wide rim, tire diam. 27.3"
285/35-20 about $359 each
305/30-20 about $360 each
Fits wheels 10.5-11.5" wide, perfect for 11" wide rim, tire diam. 27.2"
2009-2021 Season Points and Runoff Champion(ASP 2009-12/SSP 2013/Street Modified 2014-20/2nd Points 2019, 2nd Runoff SM 2016-17)
#3 13blackedition
13blackedition
    GTRLIFE Newbie
  • 10 posts
Posted 14 June 2020 - 05:00 PM
Made in Taiwan quality should be good.
#4 hunter
hunter
  • 2138 posts
Posted 14 June 2020 - 06:14 PM
I never would own 888R because of the  NOISE ...................... If these are nice and quiet.......... Might have a new week end warrior..........
GTR GUY IN AZ
#5 *14TrakEDN*
*14TrakEDN*
  • 568 posts
Posted 14 June 2020 - 07:34 PM
Is that as wide as they make them?...I run R888r's and R7s my stage 4 Shep Trans is louder than my tires.....Looks like a decent tire to look into though....Thanks
2014 TE
AMS Alpha 7
Cobb tune
E85 Flex
Sheptrans 2.5
Ported polished intake and turbo inlets
AMS oil cooler
Titek Race exhaust
AMS downpipes
Spec V tips
Gotboost 3" intakes
#6 AutoXGTR
AutoXGTR
  • 6568 posts
Posted 15 June 2020 - 12:00 AM
Limited tire sizes, only 4 possible for 20" wheels. I left out the 245 size.
Not much better with 18" and 19" wheel sizes.
27.3" tire diameter is small so larger wheel gap with OEM suspension. With lowered suspension you get less ground clearance and more risk to damage front lower lip and spoiler.
Yes, R compound tires can be firm riding and noisy, some are better than others. R888R noted for being loud when driven at the limit and will give some warning you can hear. Other race tires may not give much notice they are about to loose grip then they break loose.
#7 7racer
7racer
  • 1199 posts
Posted 25 June 2020 - 09:49 PM
they generated 2g of lateral grip on the Donklevort car.  Couple fast 720s user running them and seem as fast as the 3rs but cheaper.  Plan to try them on the 720s after I burn thru my current 3rs.
#8 M3AP1
M3AP1
    GTRLIFE Newbie
  • 34 posts
Posted 15 July 2020 - 11:33 AM
I run AR1 305 square. They have lots of grip. IMO, far better than R888r since they don't grease when hot.
They do run slightly narrower. They do howl but not as loud as R888r.
#9 Jojogts
Jojogts
  • 97 posts
Posted 19 July 2020 - 06:55 PM
Where can you get them?
#10 Maxikeem
Maxikeem
  • 767 posts
Posted 26 July 2020 - 03:59 PM
Do they fit under front stock fender?
Planning on running them too.
" timestamp="1594834431"]
They do run slightly narrower. They do howl but not as loud as R888r. [/quote]
#11 M3AP1
M3AP1
    GTRLIFE Newbie
  • 34 posts
Posted 27 July 2020 - 08:41 PM
I'm on stock rolled fenders. SPL front camber arms.
Track set up is 20x10.5 +25 on 305 square. 25mm spacer in the rear.
