Dude, this is one Bad Ass Build!!!! Much respect!!!!!
Can you share any info on the power adder?
Thanks man, I cannot tell you how much I have enjoyed this DIY build. Full disclosure, I had PLENTY of support.
Speaking of support, next phase is tuning. As I mentioned, I purchase the Motec M150 ECU from T1 with base tune loaded for startup, I can check that box off. Wayne Potts remains the primary tuner and is a pro with Nitrous. Wayne shared a dyno with and without the juice, enough said, I want it. I’ll install the nitrous system when I fabricate the new charge tubes for the Vibrant clamping. I’ll also install the new AMS throttle bodies that incorporate Vibrant adapters. The Magnus mechanical pump will provide plenty of fuel so, only time will tell, to be continued…
