1/4 Time Expectations
6 replies to this topic
#1 Osman_m
Osman_m
    GTRLIFE Newbie
  • 20 posts
Posted 27 June 2020 - 12:48 AM
Hey guys,
Took my car out to  drag strip to put down  some times for the second time  and  didn't get the results I was hoping for. I know a lot of folks with similar mods as mine are pulling way better numbers as I read through the forums. The car is pretty much flex fuel tuned FBO with slightly upgraded turbos over stock.
I did manage to log my first pass on Cobb and have attached the log to this post.
Conditions:
  • Tire: R888's with 24 psi all four corners
  • RCR mode
  • launch rpm: 4100
  • running a mix of e98 and 94 pump gas with ethanol content around e40
First pass:
1/4: 10.987
MPH: 128.79
60 ft: 1.857
1/8: 7.210
Second pass:
1/4: 10.979
MPH: 134.31
60 ft: 1.812
1/8: 7.238
Here are the mods:
  • stock motor
  • stock transmission
  • Cobb tuned
  • Turbos:
    • upgraded custom turbos that basically have bigger housing to allow for more flow
    • Turbosmart wastegate actuators
    • Tial BOV's
    • ETS Street Intercooler
  • Fuel:
    • 3-Bar Map Sensor
    • Speed Density Conversion Kit
    • 1D1300 Injectors
    • Twin  DW300 Fuel Pumps
    • Hardwired, relayed pumps
  • SBD downpipes
  • GTHaus non-resonated mid pipe
  • HKS Legamax catback
  • SB intakes
  • Tire setup: Rohana 20 inch wheels with R888's [285 front, 325 rear]
I am thinking the car needs a re-tune but any advice is appreciated please!
Thank you in advance.
Edited by Osman_m, 27 June 2020 - 01:31 AM.
#2 livinlrg05
livinlrg05
    GTRLIFE Newbie
  • 48 posts
Posted 27 June 2020 - 01:42 AM
Get your E content up. Most ramping tables max at 70-75% if you are in a flex tune. If you are tuned for E 40 then higher E will do nothing. I cut better 60' on the street on 300 treadwear tires. Play with tire pressures and launch rpm. Make sure your clutch isn't slipping.
Edited by livinlrg05, 27 June 2020 - 01:43 AM.
#3 livinlrg05
livinlrg05
    GTRLIFE Newbie
  • 48 posts
Posted 27 June 2020 - 01:55 AM
A couple things I noticed from your log... is your content goes from E40 to E30 by the end of log and your car seems to have a 28lb boost spike in the end of 4th gear. Im not a tuner but i would ask my tuner why if it was my car.
#4 L.L.
L.L.
  • 1463 posts
Posted 27 June 2020 - 08:06 AM
Since you're using Celsius for temperature in your other thread, I'm assuming you're overseas. Is 94 octane RON or AKI?
2015 Nissan GT-R Premium (SOLD)
AMS Alpha 9+ Turbochargers | AMS Alpha Induction Kit | AMS Alpha Front Mount Intercooler
AMS Alpha 3" Intakes | AMS Alpha 90mm Downpipes  | Litchfield 102mm Triple Silenced Exhaust
AMS 4.0 BAR Map Sensor | AMS Alpha Coolant Expansion Tank | AMS Alpha Splash Shield
Speed Density on Cobb AP3 | ID1300 Injectors | Tial Q BOV | DW300C Fuel Pumps | GotBoost Flexfuel Kit | GotBoost Fuel Pressure Monitoring Kit
Stock Block/Transmission | Tuned by Chris Black & ACG Automotive | Built by JohnWigs @ Pacific Nissan
2017 Acura NSX (SOLD)
130R White on Red/Alcantara
2016 Nissan GT-R Black Edition (Current)
Cobb SF 2.75" Intakes w/Green filters
#5 Osman_m
Osman_m
    GTRLIFE Newbie
  • 20 posts
Posted 27 June 2020 - 09:37 AM
Just north of the border in Canada. Toronto Canada to be specific.
#6 jlefebvre123
jlefebvre123
  • 107 posts
Posted 30 June 2020 - 04:22 PM
Hit up sjlcustom auto.
Edited by jlefebvre123, 30 June 2020 - 04:25 PM.
#7 Osman_m
Osman_m
    GTRLIFE Newbie
  • 20 posts
Posted 30 June 2020 - 09:53 PM
Steve at SJL did the turbos for me. Very familiar with his shop.
