How to Video for Resetting TPMS sensors on GT-R R35
1 reply to this topic
#1 gforever
gforever
    RED GT-R
  • 534 posts
Posted 27 June 2020 - 08:42 PM
Hey guys, this topic has been mentioned on the forum but I haven't found a video or a quick guide to complete the process. I happened to need to do this and decided to make a video to help other owners if they come across this. Hopefully this helps and all of us can swap wheels, change to summer or winter tires without having annoying TPMS Malfunction Light turn on. Check out the video here:
https://youtu.be/MUTctaYV0ig
In this video, I will show you how to reset the TPMS light on a 2009 Nissan GT-R R35. This same method should work on all GTR CBA & DBA model years (2009 - 2016) and most likely 2017+ models as well. (DBA and EBA owners can correct me if I'm wrong).
You will need 2 tools, either Cobb AccessPort or Ecutek.
Link to Cobb AP3: https://amzn.to/3dEiaRU
Link to Ecutek: https://amzn.to/31m11ts
You will also need a TPMS Activator tool.
The one from the video is VXDAS GL-50448 TPMS Relearn Tire Pressure Sensor Reset Activation Tool OEC-T5.
Link to TPMS Relearn Tool: https://amzn.to/31pmXUv
  1. Hook up your COBB AP or Ecutek device to your vehicle's OBD-II port.
  2. Push the start button on your car twice where it is on but engine is off.
  3. Then on your Cobb or Ecutek device, find the TPMS relearn mode. For Cobb APV2, go to Tune, select the TPMS Relearn.
  4. Then follow the order with the Relearn tool to activate each sensor. For the COBB APV2, the order is Front Left, Front Right, Rear Right, Rear Left.
  5. Take the TPMS relearn tool and place it by the sidewall of the 4 tires one by one. The turn signals will flash or your car will horn twice to inform you that the TPMS sensor has been picked up.
  6. Repeat the process for all 4 tires.
  7. Check your dash to see if the TPMS light is gone and on your COBB or Ecutek device to see if relearning is complete.
2009 GT-R Premium Solid Red A54ID 1000cc injectors, SFS Downpipes, SBD Intakes, SBD Race Midpipe, SBD 700 Tune, COBB AP V2, Michelin Pilot Super Sport tires 285 x 35 x 20 (Square Setup), '12 Transmission,  DBA 5000 Slotted Rotors, BF Goodbridge Stainless Brake Lines, Hawk HPS Brake pads, LED lighting, Mines Gunmetal GT-R Center Caps, '12 DBA Premium Rims,  Hexomats, '14 Black Edition Shift Knob, Carbon Fiber Door switch overlays,13 Black Edition Door Handles, '16 NISMO Engine Cover, '16 NISMO Shift Indicator Gate, GTC Inlets (60mm), Amuse Overtake 100mm Valvetronic Saikou Exhaust, AMS 90mm casted downpipes, Tuned by Kaizen Tuning LLC, '13 DBA Radio Climate Control Unit, N-Tune Carbon Fiber Front Bumper & Lip, DBA Upper & Lower Grilles, DBA LED DRLs, N-Tune Carbon Fiber Side Skirts, N-Tune Carbon Fiber Spoiler, OEM NISMO Striping, Xpel Clear Bra Full Front & Skirts installed by Luxury Details. Depo LED Thunderbolt Headlights, OEM Clear Front Sidemarkers, '18 NISMO Seats, '16 NISMO Rims, OEM Clear Rear Sidemarkers, DarwinPro Diffuser with fog light, OEM 2020 Taillights, N-Tune Carbon Fiber Rear Bumper,  SOON: Michelin Pilot Sport 4S, Ceramic Coating
www.gforever.net
#2 idrnkenmonkeyi
idrnkenmonkeyi
  • 70 posts
Posted 28 June 2020 - 02:13 AM
Any way to do this without a cobb or ecutek?
