For those that have them or those that sell them, I am looking at the Fore Innovations triple module. I am trying to understand the connections and requirements.
https://www.foreinno...ct_p/34-900.htm
What I would like to do is buy the module, the FC3 controller and install all 3 pumps, however I will not need the 3rd one for some time, is there a way to not wire in ( I understand the controller uses an aux input signal for the 3rd pump, like a hobbs or something so I assume just dont give it signal) the third pump externally (I dont much enjoy playing around in the fuel tank so I want to put it in once and forget about it) but keep it all ready to go in tank.
Also what is needed if I get the FC3 controller plus wiring (+$249 option) I see other options for pigtails for the FC3, do I need those to or does the "kit" come with it?
Also I see that the hat uses -6 and -8 AN fittings, my understanding is that for a while the stock lines will be fine (motor and turbos wont come till probably april) so can I just get a -6 and -8 AN to fuel fitting adapter (what size? 3/8?, 5/16?) and use the stock lines for now?
Edited by Bit_Pirate, 28 July 2020 - 12:34 PM.
