Fbo e85 dyno chart, horsepower too low?
36 replies to this topic
#21 Godzilla_GT-R
Godzilla_GT-R
  • 152 posts
Posted 01 August 2020 - 06:43 AM
Map 1 is lower boost daily driving. Map 2 is pops and bangs. Map 3 is flames. Map 4 is kill mode/highest boost. Sent from my iPhone using Tapatalk
#22 Foss
Foss
  • 212 posts
Posted 01 August 2020 - 06:59 AM
Then yea go to Ivey at this point if you think there is something wrong with the tune. I thought it would be something simple like having it on the wrong map, or maybe the boost toggle Cruise button on the steering wheel is set to low. Hopefully it isn’t something serious. I know pops/bangs/flames can cause compression issues if used too much.
#23 Godzilla_GT-R
Godzilla_GT-R
  • 152 posts
Posted 01 August 2020 - 07:49 AM
I don’t use map 2 and 3 often. Only when I want to put on a show :D I’m really familiar with all the ecutek features so it’s nothing simple like the boost turned down via cruise control toggle. I’m going to run a couple passes on the strip. That will confirm if I’m low on power or if the car only put those numbers down on the dyno because of the heat, elevation, etc... I’ve emailed Sean Ivey to get a quote on a dyno tune to get an idea if it’s confirmed my tune is the issue. Sent from my iPhone using Tapatalk
#24 240Z TwinTurbo
240Z TwinTurbo
  • 1914 posts
Posted 01 August 2020 - 09:13 AM
http://cloud.tapatal...31 18-43-33.csv
Boost is significantly limited in 1st and 2nd gear and once you hit 3rd boost is still soft, which explains your torque curve.  This is purely a function of the commanded WGDC.  Ignition timing is not bad, but intake cam timing can be ramped out sooner so it flows better on the topend.
2006 EVO IX (663hp/527tq @ wheels Shell 93 pump gas)
2009 GTR Premium (707hp/628tq @ wheels Shell 93 pump gas / [email protected])
1971 Datsun 240Z (Let the restoration begin!)
DIY700 - 700hp on a Budget
BW S366 SX-E (6668) TwinScroll Experiment
CURT BROWN 2.15L S362 vs S366 Results - 93 Pump
#25 Godzilla_GT-R
Godzilla_GT-R
  • 152 posts
Posted 01 August 2020 - 09:52 AM
So your saying theres definitely way more power to gain from the tune? Sent from my iPhone using Tapatalk
#26 droptopp
droptopp
  • 8235 posts
Posted 01 August 2020 - 11:13 AM
You won’t pick up 100wheel like you mentioned before. Only so much the stock turbos put out and they fall hard towards redline. But, you will have more in all your gears.
TSM Billet Crank 4.1 w/ CP billet pistons, TSM Elite Prime turbos, TSM Wet Sump Oling upgrade, flex fuel, ETS mid and down pipe, STM titanium axle back, STM race FMIC, ID2000s, Shep One K with drop gears and all the goodies., DS Axles, Volk Saga 18 10/12 (MT ET Streets), Advan GT Premium 20 R888. 1450+ hp / 1210+ tq
Old setups : Alpha 9 w/ AMS 3.8, GTX3582R Gen II w/ AMS 4.1 billet crank, GTX3582R Gen II w/ AMS 4.0 big bore billet crank and of course FBO E85.
#27 240Z TwinTurbo
240Z TwinTurbo
  • 1914 posts
Posted 01 August 2020 - 04:20 PM
Yes, should be able to get consistent with what others have obtained.  Tune is not necessarily bad except for the intake cam timing needs adjusting, but conservative on how boost is ramped in and how much boost is run.  Additionally, E% increase (E65 to E85) should net another ~1-2deg of ignition timing, which will also increase torque.
Edited by 240Z TwinTurbo, 01 August 2020 - 04:21 PM.
#28 BlueGTR
BlueGTR
    GTRLIFE Newbie
  • 44 posts
Posted 01 August 2020 - 09:33 PM
Who tuned it?
#29 Godzilla_GT-R
Godzilla_GT-R
  • 152 posts
Posted 02 August 2020 - 02:45 PM
My tuner made a video of my car on the dyno ;) Sent from my iPhone using Tapatalk
#30 IPAlpha
IPAlpha
  • 800 posts
Posted 04 August 2020 - 02:27 AM
Run a 1/4 and your trap will tell you if itâs low or not. Trap speeds are a more accurate reflection of hp. Every dyno reads different, but if that tq blip is exacerbated when your not heat soaked I would get it pulled out. Probably best to jump back on the dyno when it is cooler. Good luck.
:clap:
#31 majj35
majj35
    MAJJ
  • 1611 posts
Posted 05 August 2020 - 05:10 AM
seems a bit too low. check my e85 on fbo (all parts in my signature) - Dynojet 335ft e85 -> 646whp/661wtq
2014 GT-R Black Edition | Alpha 7
Engine:   Alpha Street FMIC | Sakura 3" intakes | Asnu 1100cc | Asnu 330lph | HKS M45HL | HKS SSQV4 FlexFuel v2
Exhaust: Alpha catless Downpipes | HKS Resonated Midpipes | HKS Legamax titanium
Exterior: Rexpeed K Splitter | Rexpeed Z Skirts | Difflow fins | '15 Lights | 3M Trunk wrap | Stealth Plate
Interior: DCT Custom Steering wheel | Shiftkoncept Shift Paddles COBB ApV3-005
Wheels: Advan RS-D 20x9.5/20x10.5 | Titek lugs | Eibach spacers 15mm/20mm | Pzero 285/295
646whp/661wtq (e85) - Kaizen Tuning
603whp/605wtq (93 Aki) - Kaizen Tuning
540whp/540wtq (95 Ron) - Kanoo Performance
if_Instagram_1298747.pnggwynethbluepearl
1968 Camaro SS LS2/T56 (Build)
#32 droptopp
droptopp
  • 8235 posts
Posted 05 August 2020 - 09:22 AM
All dynos read different - I dyno’d 580/600 and trapped 135-136 as FBO. Stock 320/328 lol.
#33 Godzilla_GT-R
Godzilla_GT-R
  • 152 posts
Posted 05 August 2020 - 10:07 AM
That torque tho.....
#34 WholeGrainHomie
WholeGrainHomie
  • 247 posts
Posted 05 August 2020 - 10:57 AM
:clap:
When are you coming back to NY? Might have my GT-R waiting!
BTW Forum Folks, this guy Alpha is the man to tune your car. Spent a half day in 90 degree weather fine tuning our Supra on ProEFI with 3 customers waiting. Car ran flawlessly. Didn't rush or anything, took his time and ironed out all the kinks.
#35 Freddy5613
Freddy5613
    GTRLIFE Newbie
  • 28 posts
Posted 05 August 2020 - 06:09 PM
I will be getting mine on the dyno this Friday with same mods I will let you know how I do. Sent from my iPhone using Tapatalk
#36 IPAlpha
IPAlpha
  • 800 posts
Posted 05 August 2020 - 08:32 PM
:biggrin:
Very soon. I'll shoot you a message. Don't want to side track his thread :thumbsup:
#37 IPAlpha
IPAlpha
  • 800 posts
Posted 05 August 2020 - 08:34 PM
Well said again :thumbsup: People get too caught up on dyno numbers. It's one thing to be down 100+whp but it's another to be down 20, 30, 40. I've been on plenty dyno and dyno rooms the car dyno "low" per Internet standards and went to the track only to trap what it should or higher
1 user(s) are reading this topic
    Bing (1)
