Payment methods accepted:
- Wire transfer
- Cash
- Bank issued cashiers check (title will be transferred upon cashiers check clearing)
This car is more than I need since I don't drag race, or track race the car and don't care to, I'm honestly more into the tuning/building then selling and then starting a new project/ and car shows than tracking my car, has never been launched with the new trans and only been launched once ever on the original transmission.
Build motor/transmission has 1200 miles on it and runs flawlessly, if you are looking for a reliable street destroyer this is your car. Also capable of running mid to high 8's in the quarter mile. Clean title in hand, Zero accidents, Zero races.
Engine Build
AMS Spec Shortblock 1500hp capable
- Precision AMS spec machine work on block & crank
- Alpha Spec Extreme-Duty Manley Pistons w/skirt coating
- Alpha Spec Extreme-Duty Manley I-Beam rods
- Connecting rod, main & thrust bearings $6,999.99
Alpha Performance R35 GT-R Race X One Piece Billet Flywheel $900.00
AMS Fuel Rails / T1 FP sensor / regulator $1,350.00
AMS Carbon Intake Manifold $7,000.00
Paul Coggeshal Stage 2 heads
- Port and Polish $800.00
- Ferrea Springs/retainers $1,100.00
- Kelford Cams $2,195.00
Spray It Racing Stage 2.5 Turbos
- Garett GTX 3071r G2 quick spool turbos 1200 whp capable $7,250.00
AUS Injection 1600 cc injectors $815.00
Tial QR BOV $450.00
Rampage Fab Catch Can (largest on market) $800.00
Rampage Fab Race intercooler/ Hard piping red annodize IC $3,084.00
ATI Super Dampener Pulley $480.00
Paul Coggeshal Labor R/R $1,250.00
Linney Tune on Ecutek $1,200.00
Speed Density Kit $300.00
AWP Deep Oil Pan $800.00
3" Intakes $400.00
4 bar map sensor $150.00
Aluminum Coolant tank $400.00
ECUTEK BT Dongle $200.00
Powder Coat valve covers and timing covers $500.00
Trans Build
"Kozmic Built Stage 3.5 Transmission
- 1200lb ft torque rating"
- Kozmic 10/10 disc clutch
- Dodson Forged Baskets
- Dodson Extreme 1-6 Gearset
- Full Dodson Gear Lock set
- Dodson FWD Retainer
- Pan Magnet Kit
- FWD Output Seal
- OEM Axle Seals
- OEM Pan Gasket
- GT1R Rear Differential Brace
- Dodson Internal Canister filter
- Selector Piston Shims
- Dodson Thrust Bearing Retainers
- Dodson Surge Baffle Plate
- Sheptrans ETS Ball retainer
- ETS Clutch Rebuild
- ETS Fluid $18,330.00
DSS 1000 axles and stubs $2,866.00
Other Cool Shit
Visconti Fueling
- Walbro 485/525 Basket $1,200.00
- Visconti Harness $450.00
- Visconti Flex Fuel Kit $650.00
Tomei Expreme Ti Exhaust $3,000.00
AMS SS break Lines $150.00
Powdercoat Calipers $350.00
VRSF Catless 90mm Bellmouth Downpipes $450.00
Variant Alloy Custom Lightweight 20" 3 piece wheels (20x12 weighs 28lbs) $8,097.10
Toyo R888r $1,300.00
Full Vinyl Wrap Ghost Flip Pearl $2,000.00
Full Nose PPF Under wrap $350.00
Ceramic Coating $200.00
Carbon Hood Vents $150.00
Carbon Nismo Lip $1,200.00
Carbon Emblems $150.00
Carbon Steering Wheel $1,200.00
Carbon extended Paddle shifters $450.00
Carbon duckbill trunk $800.00
Install labor for all of the above $2,000.00
TOTAL TO BUILD NEW WITH CURRENT MARKET RATES ON 16' GTR's ~ $157,917.09
