Best Tires for 18x10+35 / 18x12+27
#1
Posted 07 April 2021 - 06:13 PM
#2
Posted 07 April 2021 - 07:33 PM
#3
Posted 07 April 2021 - 08:00 PM
What are you using your GTR for?
Street driving, track, drag racing, time attack, autocross, high performance driving school/events?
What suspension are you using- if lowered, how much drop
In general, front and rear tire diameters need to match. One way to select a tire size is to find one that will fit on both front and rear wheel widths but with 10" front and 12" rear this would be more difficult.
OEM tire diameter is 28" but you can use smaller tire diameters down to under 26". However for ground clearance it is good to keep it from 26.3" to 27.5". With a smaller tire diameter you would be increasing wheel gap with OEM suspension so some drop in suspension about 0.5" to 0.7" is OK. However the more drop the less clearance you have for extra wide tire sizes especially in front.
Using your new wheels vs OEM
Front 18x10" et35 will be 3.6mm further from the inner suspension and poke out 16.4mm more which is fine.
Rear 18x12" et27 will be 21.1mm closer to the inner suspension, and poke out 17.1mm more. A 10-15mm wide wheel spacer would offer more space on the inside, rear tire if wide will poke out quite a bit.
#4
Posted 07 April 2021 - 08:10 PM
So for limited street use and some street drag or limited track duty here is an example:
Toyo R888R Streetable Track R compound tires Treadwear 100
Front 305/35-18 fits rims 10-12" wide, perfect for 11" wide rim, tire diam. 26.4"
Rear 335/30-18 fits rims 11.5-12.5" wide, perfect for 12" wide rim, tire diam. 25.9"
Or use 305/30-18 for both front and rear wheels- this makes them match on tire diameter. Wheel widths will pinch or stretch tires to fit, the front wheel will limit the wide tire size and the rear wider wheel will allow the tire to stretch out wider. Should work fine and gives a 26.4" tire diameter which is usable for minimum ground clearance, not really good for OEM suspension due to wide wheel gap.
#5
Posted 07 April 2021 - 08:21 PM
If you are looking for drag tires on a budget and for street use here is an example:
Toyo Proxes TQ Drag Racing tires treadwear 0
Rear 315/35-18 fits rims 10.5-12.5" wide, perfect for 11" wide rim, tire diam. 26.8" , note on Backorder
Front Toyo Proxes R888R 305/35-18, tire diam. 26.4"
Also check out Nitto tires
#6
Posted 07 April 2021 - 09:10 PM
#7
Posted 08 April 2021 - 06:28 PM
#8
Posted 08 April 2021 - 09:55 PM
#9
Posted 09 April 2021 - 06:03 PM
