Will Eibach Sway Bars make a big difference?
11 replies to this topic
#1 gtrstve
gtrstve
  • 236 posts
Posted 19 April 2021 - 02:05 AM
I'm planning to buy Eibach sway bars because I want to have sharper handling FEEL.
will they really make a big difference?
I'am on stock suspension/ stock camber
wheels are
20x10, 20x12
285/345 Ps4s
I rarely go to track, but I always do spirited driving/ mountain roads
and for those who are using Eibach Sway bars,
do you guys use the stiffest setting to have the sharpest handling feel?
Edited by gtrstve, 19 April 2021 - 02:08 AM.
2019 GTR Premium FBO
#2 Maxikeem
Maxikeem
  • 851 posts
Posted 19 April 2021 - 09:03 AM
Swaybars will help, I have the stillens ones.
Mpss is too soft compared to the oem rubber which gives a sharper handling due to runflats and stiffer sidewalls
Even with swaybars I can still feel the car moving around.
Also stock suspension is pretty soft starting from 2015 upwards.
Best is to get stiffer sidewall tires like R888R or change out rubber bushings for superpro ones. Or change the suspension.
I'm Currently in the process of replacing the oem rubber bushings.
#3 AutoXGTR
AutoXGTR
  • 6688 posts
Posted 19 April 2021 - 10:49 PM
How much understeer and oversteer do you get now? If not either then swaybars aren't the first thing to consider.
If you get a lot of understeer then you need to consider corner entry speed, you may be entering turns too fast for the tightness of the corner. If you get a lot of oversteer then you may have not enough rear tire grip or have too much weight transfer forward.
Swaybars can reduce either understeer (stiffen the rear bar relative to the front) or oversteer (stiffen the front bar relative to the rear bar). Most GTR swaybar sets give both adjustable front and rear bars so you choose the settings that work best for you. Stiffest settings aren't the best choice for everyone, the correct settings are the ones that work for your suspension and tire setup and for your driving skill level.
Sharp handling as mentioned can also be related to the feel of the tires, stiffer sidewall construction and shorter sidewall height or XL load rating construction does help. GTRs come with OEM runflats which are very stiff sidewalls.
Michelin Pilot Sport 4S is a Max summer tire meant for daily driving and street use so it's built for lower noise and ride comfort not really crisp handling. If you go for tires that have better handling such as extreme Summer tires or race tires then you get more noise, firm ride and faster tread wear.
Changing bushings usually result in a much firmer ride, more noise and less comfort but usually better handling.
#4 gtrstve
gtrstve
  • 236 posts
Posted 20 April 2021 - 06:23 AM
Sorry, are you pertaining to the bushing of the sway bar?
#5 gtrstve
gtrstve
  • 236 posts
Posted 20 April 2021 - 06:25 AM
Thanks for the reply
I don't really experience understeer or oversteer cause I rarely track my car
However, I do feel body roll which I want to lessen
so on fast cornering, it will be low and flat. Like Mclarens/ Ferraris
will sway bars solve this?
#6 Maxikeem
Maxikeem
  • 851 posts
Posted 20 April 2021 - 07:46 AM
Yes, the front lower rear bushing. You can start with the swaybars and go from there. Get a superpro one over the whiteline. If that's not enough then maybe a stiffer springs.
I have the nismo suspension on mine, it corners very flat with very minimal roll, night and day compared to my 2015 suspension.
Visually comparing the 2017 Nismo suspension to the 2015, the nismo springs are much bigger and stiffer that regular GTR springs. Also about half inch lower.
Hated the way my 2015 was soft and body rolled. Changing suspension totally worth it. I Can take corners with confidence now.
#7 aroonkl
aroonkl
  • 70 posts
Posted 21 April 2021 - 07:18 AM
These were the steps I went. My car came with 285/345, Swift R springs, Stock shocks and Sway Bar. Car was understeer.
1. Rear Eibach Sway Bar in. From middle setting first and to stiffest at the end. Car was mild oversteer under power and neutral/understeer when lifted. That was a good improvement.
2.Handling still not so good in straight line and corner. I changed to coilover set with spring rate 900 and 550 and got rid stock shocks. (I don't think spring are stiffer than Swift R) I use my car daily so I did not go stiffer spring. Shock upgraded is the key here. Good improvement. Car was stable and confident in turns.
3.While in processed of 2., I changed tires to R888R which were stickier than PS4. When in turns, car still leaned pretty good. I changed to Whiteline  sway bars. Right now Rear only with middle setting. Whiteline is stiffer than Eibach. Middle setting is stiffer than Eibach stiffest. After some miles I will try Whiteline in the front, I think front at softest setting should be good enough.
Reference car that I try to make GTR come close a bit. My garage queen, 996 turbo with 2wd conversion. GT3 suspension upgrade. KW Clubsport Coilover. AKA poor man GT2.
If you want to stay with PS4 and stock shock, Eibach might be ok and cheapest route.
Edited by aroonkl, 21 April 2021 - 07:24 AM.
#8 gtrstve
gtrstve
  • 236 posts
Posted 22 April 2021 - 03:22 AM
Did you experience installation problems with whitelines? cause I've read a couple of posts saying whitelines dont fit properly
#9 aroonkl
aroonkl
  • 70 posts
Posted 22 April 2021 - 09:05 AM
I did not put the front in yet. Will let you know. From what I read, one reported mounting hole was off. Later someone pointed out he did not let the wheel free from all load. One wheel was on ground something.
And I think even if there was the problem, manufacturer should address it by now.
#10 White_turbo
White_turbo
  • 2425 posts
Posted 22 April 2021 - 10:03 AM
Put the biggest front bar you can find if all you concern is body roll on a daily driver. It will turn like crap when you start driving it at the limit but will solve your specific concern. This is the cheapest way to do it IMO.
2018 SCCA Solo National Super Street 3rd Loser
Always looking for sponsorship to help out on events entry (autox/hpde) and such. Please PM me if interested. Super Street 09 GTR #924 / A Street Prepared 06 Evo #924
Follow me on Instagram: @garytsuikk
Subscribe to my youtube channel: https://www.youtube....LHxYspyZZxJZdYA
#11 franc01
franc01
    GTRLIFE Newbie
  • 30 posts
Posted 26 April 2021 - 09:46 PM
@Maxikeem, from where did you source your Nismo suspension?
#12 Maxikeem
Maxikeem
  • 851 posts
Posted 27 April 2021 - 07:11 AM
Bought it from a guy that "upgraded" to a JRZ. One of the best mod. Totally transformed the car.
