Two Post Lift Use
7 replies to this topic
#1 UnCitizen
UnCitizen
    GTRLIFE Newbie
  • 13 posts
Posted 08 June 2021 - 07:15 AM
Hi.
I have a two post I use on my other vehicles for maintenance and was wondering if anyone has some input on the GT-R. I am aware of the lift pad adapters but seeing as reverselogic is unable (due to no fault of their own) to supply the adapters I'm curious if the standard "hockey puck" pads will suffice. Has anyone used flat pads to lift this car?
Thanks for any insight.
Nick
#2 gtrbillet
gtrbillet
  • 603 posts
Posted 08 June 2021 - 10:40 AM
I have a two post and just use the standard pads to raise the car.
Gregg 2013 gtr premium
#3 JohnnyTSi
JohnnyTSi
  • 138 posts
Posted 08 June 2021 - 01:49 PM
I use these: https://www.amazon.c...duct/B07HJ4YBJ9
Beautiful Blue Built 2013 R35 GTR
????/????tq Daily Driven street thrasher!
New OEM Block, stock crank, Manley/Manley
Ferrea valve train
ARP 625+ & ARP main studs
Kelford 231-A cams
SBD900 g25-660 turbo kit
Rampage/SBD 3.5" Intakes
Rampage/SBD Race Intercooler with TiAL BOVs
3.5" mid pipe with resonator
MAP Muffled 3.5" cat back
Visconti/CB ported 12 injector intake manifold
id1050 primary & id1300x2 injectors
Visconti Flex Fuel kit
Omni 4bar Map sensor kit
Cobb Fuel Pressure sensor kit
Torque Solution and Air Injection Plates
Radium fuel pump basket with asnu 330 primary and Ti BKS1000 secondary pumps
Radium FP regulator and Rails.
Jack's built transmission Linney gearset & 18 plate clutches
Built it Myself!
#4 L.L.
L.L.
  • 1723 posts
Posted 08 June 2021 - 03:54 PM
I tried the BMW adapters and thought they were too thin for my liking. At the suggestion of a few friends who already went through the dilemma, I ended up with 4 hockey pucks at a cost of less than $10.
2016 Nissan GT-R Black Edition Cicio/Xona 55mm Turbochargers | AMS Alpha Induction Kit | AMS Alpha Race Intercooler | ETS 3.5" Intakes
AMS Alpha 90mm DP | HKS Resonated Midpipe | HKS 45th Anniversary 2-Stage Exhaust
TIAL Q BOV | OMNI 4.0 BAR Map Sensor | AMS Alpha Coolant Expansion Tank | AMS Alpha Splash Shield
ID1300 Injectors | Fore FC3 Fuel Pump Controller | Walbro 485 Fuel Pumps x2 | GT1R Flex Fuel Kit | Visconti FP Monitoring Kit
2021 Nismo wheels | Toyo R888R Tires 285/35/20F / 325/30/20R
Stock Block/Transmission | Speed Density on EcuTek | Tuned by Taylor @ Cicio Performance  | [email protected] (7,637 DA)
#5 JohnnyTSi
JohnnyTSi
  • 138 posts
Posted 08 June 2021 - 09:21 PM
On my lift (Danmar M6), the pad alone is so low the arm would crush my side skirt as the arms come up. Hockey pucks are too tall to slide in without driving up on a board, anndd my final try was the BMW style adapters I linked to above, I've used them for a year and a half now without issue.
John-
Ferrea valve train
Kelford 231-A cams
Built it Myself!
#6 UnCitizen
UnCitizen
    GTRLIFE Newbie
  • 13 posts
Posted 09 June 2021 - 09:37 AM
Thanks so much for all the replies! I'll give the pads above a try as I suspect I will have the same issue with the side skirts.
Thanks again!
Nick
#7 L.L.
L.L.
  • 1723 posts
Posted 09 June 2021 - 10:13 PM
Good info. Sounds like side skirt clearance is a consideration regardless of the lift. Us guys with Challenger lifts & 2-stage rear arms (such as on the VLE10) in the narrow configuration need the hockey pucks to gain additional thickness/clearance so the skirts aren't sitting directly on the rear arms. The Danmars need thinner adapters so the pads on the arms can clear the skirts.
#8 UnCitizen
UnCitizen
    GTRLIFE Newbie
  • 13 posts
Posted 11 June 2021 - 07:49 AM
Ordered the pads. I'll see how it works out. I'm using a Bendpak LC7. Have a friends Lotus Esprit on it without problem, and I originally worried the skirts would be an issue there so...
Thanks again.
Nick
Edited by UnCitizen, 11 June 2021 - 07:49 AM.
