ALPHA 10 and 12 turbo kit **OFFICIAL RELEASE** PIC HEAVY
51 replies to this topic
#1 ALPHA Performance
ALPHA Performance
    AMS Performance
  • Validating
  • 6565 posts
Posted 05 December 2012 - 12:26 PM
I know for some you are probably wondering why we are calling this a release after it has been on the market for so long. The truth is up until this point we have been selling our 10 and 12 kits using a quick casting method that while effective was quite expensive and worse... time consuming. Today however we finally have our production manifolds done and we will now be able to supply our kits in a much more timely fashion.
Could we have gone the route we and so many others in the past have taken with a tubular welded manifold? Sure, we could have and this would of been a cheaper route to take. However when it came to R35 development we really wanted to put a part on the car that was not only better performing than its stock counterpart but of the same quality, reliability and fitment than the piece we were taking off. After all an upgrade should not just be an upgrade in power but an upgrade overall.
The ALPHA 10 and 12 kits have been proven to perform more so than any other existing R35 Turbo kit. Not only was the ALPHA 12 the first Turbo kit to dip into the 8's but it has powered more 8 second GT-R's than any other competitor's turbo kit.
The ALPHA 10 and 12 kits are hands down the best fitting, best performing and most complete turbo kit on the market for the GT-R.The following information and pictures should help to clearly show the immense amount of R&D, testing and work that went into creating our ALPHA 10 and 12 turbos kits.
For any other information please feel free to post, PM, email or contact the ALPHA dealer in your area.
A Turbo System Proven By World Record Setting Results!
Now the same record setting results are available for your GT-R. The Alpha Series Turbo System has powered us to every record for the Nissan GT-R platform. From quarter mile to standing mile to top speed, the Alpha Turbo System has been behind every World Record we have broken and still hold today.
Quick Spooling, Yet Produces Massive Power; The Best Of Both Worlds
The Alpha GT-R Turbo System is no one-trick pony. Often bigger turbos require you to give up much of the low and mid-range power. While others might use the "bigger is better" approach to turbo kit "design", we set out to properly engineer a system that yields maximum power across the WHOLE power-band to keep you ahead of the competition.
By applying the latest in billet wheel and V-band turbo technology we set the bar even higher. Billet compressor wheels are not only lighter, which helps quicken your turbo spool time, they also have superior aerodynamic profiles that compress more air efficiently: less heat = more power. When Motortrend http://blogs.motortr...a-12-22571.html tested our Alpha 12 they were blown away by the throttle response. They felt "The quickness with which the turbos spooled was breathtaking."
The Strongest, Most Advanced Design On The Market
By applying cast stainless steel construction, we eliminated the restrictive design geometry and the possibility of cracking found with hand-fabricated headers. Hand-fabricated, equal length tubular manifolds perform well but are prone to cracking because they have many joints that can easily become points of failure. These manifolds are typically found on purpose-built race cars where consistent disassembly and inspection are the norm and are not well suited for a street vehicle.
Built To Last The Life Of Your GT-R
There is a reason OEM manufacturers use only cast construction; it is much stronger and has an almost indefinite life span. Given the labor intensive job of removing the engine to change your GT-R turbos, it is simply not worth the risk of having to do the job twice to make repairs down the road on hand-fabricated, tubular manifolds.
Computer Designed, Large Runner, Equal Length Manifold For Maximum Results
When it comes to casting, those aftermarket companies who are willing to make the investment, choose a log-style manifold due to its simplicity and smaller size. These are much easier and cheaper to produce because little effort is spent in the "design" of them. While log manifolds are much stronger than a hand-fabricated design, they disturb exhaust flow and hurt performance.
Our team of engineers designed the Alpha manifolds with a cast AND tubular design giving you the best of both worlds. By implementing CAD (computer aided design) methods our turbo system offers you even better performance benefits than an equal length, hand-fabricated manifold with the strength of a cast manifold; something not offered by our competition. By casting a computer designed, tubular manifold, we were able to maximize exhaust flow with massive 1.5" exhaust runners while utilizing the small space available in your GT-R's engine compartment. To top things off, we even Extrude Hone each manifold to ensure you unmatched performance.
Safety Through Proper Engineering… Often Overlooked By The Competition
With the cramped GT-R engine bay, the added heat associated with higher power output becomes an issue. Not only does our cast tubular exhaust manifold design give off less heat, it gave us the necessary space to offer the most comprehensive heat shielding found on any GT-R turbo kit on the market. In addition, all of the oil and coolant lines are shielded in protective sleeves making the Alpha GT-R Turbo System the safest and most reliable available. When it comes to your GT-R, why chance it?
Click here for more info: http://www.amsperfor...-turbo-kit.html
ALPHA 10 power output numbers:
93 octane: up to 900whp (dynojet) with a 3.8L motor (1050-1100 engine hp)
Race fuel: up to 1100whp (dynojet) with a 3.8L motor (1300-1350 engine hp)
ALPHA 12 power output numbers:
93 octane: up to 1000whp (dynojet) on a 4.0L motor (1150-1200 engine hp)
Race fuel: up to 1250whp (dynojet) on a 4.0L motor (1500-1550 engine hp)
Kit includes:
ALPHA 10 or 12 turbochargers (2)
ALPHA Turbo Kit cast tubular exhaust manifolds (2)
TiAL MVS Wastegates in black (2)
ALPHA Turbo Kit Stainless Steel downpipes (2)
ALPHA Turbo Kit intake pipes (2)
ALPHA Turbo Kit cast turbo outlet pipes and custom silicone couplers (2)
ALPHA Turbo Kit turbo support bracket system (2)
ALPHA Turbo Kit heat resistant Oil and water line set (2)
ALPHA Turbo Kit Heat protection / shielding system (2)
ALPHA Turbo Kit Boost Control Solenoid
ALPHA Turbo kit complete hardware system for seamless install.
ALPHA 10 Turbo Kit pricing: $15500.00
ALPHA 12 Turbo Kit pricing: $16500.00
Order yours today through AMS performance or any one of our ALPHA dealers: http://gtr.alphaperf...m/alpha-dealers
For more information on our full ALPHA performance packages featuring components like the ALPHA turbo kit please visit our site: http://gtr.alphaperformance.com/
Downpipe and cast Intercooler pipe pictured below:
Edited by AMS, 06 December 2012 - 08:13 AM.
Ty Curtin
[email protected]
World's First Nissan R35 GTR in the 9's, 8's, 7's and THE 6's!!!!!!
Alpha Queen - 6.87 @ 216 mph
Alpha G 6.93 @ 196 | Alpha 22 (Prime Cuts) 7.06 @ 206 | Alpha 22 (CMC) 7.32 @ 184 | Alpha Omega 7.48 @ 193 | Alpha W (a10x) 7.56 @ 189 | Alpha X (Curtis) 7.66 @ 187
#2 spdbydesignChris
spdbydesignChris
    8.3 @ 175mph (Gen 3 SBD1400R)
  • 8562 posts
Posted 05 December 2012 - 12:49 PM
Nice, congrats!
#3 [email protected]
[email protected]
  • 4610 posts
Posted 05 December 2012 - 12:58 PM
Very nice Eric!
Yeah I always wonder how long most of those fabricated tubular manifolds will last.
'09 GT-R titanium:
Follow My Build Here: http://www.gtrlife.c...__fromsearch__1
www.gotboostperformance.com
[email protected]
email and paypal
#4 GTRcHaRgEr
GTRcHaRgEr
    LiMiTLeSs
  • 3211 posts
Posted 05 December 2012 - 12:59 PM
Beautiful kits! What size are the DP that come with these kits?
09 Black Premium DBA Conversion ..... ALPHA 12 Powered TSM Tuned.....
#5 HighlanderD
HighlanderD
  • 3540 posts
Posted 05 December 2012 - 01:02 PM
The shielding looks top notch. Are you including a boost pressure source on the turbo compressors?
First Person to Ever Remove a GT-R Drivetrain in their own garage
#6 ALPHA Performance
ALPHA Performance
    AMS Performance
  • Validating
  • 6565 posts
Posted 05 December 2012 - 01:15 PM
No we get our boost / vacuum source from the intake manifold. We like this better when working with higher hp cars.
Eric
Edited by AMS, 05 December 2012 - 01:19 PM.
Ty Curtin
[email protected]
#7 ALPHA Performance
ALPHA Performance
    AMS Performance
  • Validating
  • 6565 posts
Posted 05 December 2012 - 01:22 PM
These kits use a 76mm dp. We have thought of going to a 90mm but space and heat restrictions kept is from investigating any further. We might revisit this down the road. They are supporting a decent amount of power now though.
Ty Curtin
[email protected]
#8 str8blst
str8blst
  • 573 posts
Posted 05 December 2012 - 01:24 PM
On top of the price of this kit what would one have to budget in for a trans and engine build? The quality of this kit is fantastic and obviously the results speak for themselves!
2019 G63
2018 Mclaren 720Mantis Green
2018 AMG GTR
2018 Ford Raptor
2012 Audi Q7 SCV6 S-line
2011 Porsche Cayenne Turbo
1997 993 Turbo S
1991 GMC Syclone
2019 600LT (inbound)
2019 G63 (inbound)
2020 Taycan (inbound)
Gone but not forgotten: 2013 GTR BE BL750X, 12 GTR BE P600, 2007 Audi RS4, 2001.5 WB Audi S4 Avant GT28RS (635hp), 01 996TT Proto 24/18G, 05 CTT Techart Magnum, 04 Cayenne Turbo Proto Stg2
#9 ALPHA Performance
ALPHA Performance
    AMS Performance
  • Validating
  • 6565 posts
Posted 05 December 2012 - 01:28 PM
That would really depend on what build you are looking to go with. If you like I can pm you some prices or you can call my direct line 630 549-8903
Thank you for the kind words :)
Eric
Ty Curtin
[email protected]
#10 TheHitman™
TheHitman™
    The World Warrior
  • 7254 posts
Posted 05 December 2012 - 01:30 PM
We've been ripped AMS!!!! When are we going to see a 7 second GT-R????!!!!11111!!??!!! :furious:
JK :thumbsup: Keep up the awesome work guys! The new products look awesome! :irock:
2016 Audi RS6
Violent Blue 2012 GT-R Black Edition (SOLD)
2009 GT-R Premium (Gone but not forgotten)
#11 [email protected]
[email protected]
    ACG Automotive
  • Validating
  • 2588 posts
Posted 05 December 2012 - 01:31 PM
I'm salivating. Beautifully done as always guys.
San Diego's GT-R Aftermarket and Service Center
7884 Ronson Road | San Diego, CA 92111 | 877-422-4736 x 2 | www.acgautomotive.com | [email protected]
AMS ALPHA Preferred Authorized Installation Facility in Southern California
- AMS | Akrapovic | iPE | HKS | COBB | Meisterschaft | Amuse | Aeromotions | WALD International | Zele | Password:JDM | Technocraft | C-West -
- Volk | Advan | ADV1 | HRE | BBS | Forgestar | Klassen | DPE | KW | JRZ | AP Racing | Alcon | Brembo | Endless | AutoTecknic -
#12 TeesGTR
TeesGTR
  • 544 posts
Posted 05 December 2012 - 01:33 PM
Nice looking manifolds! Well done AMS.
2013 GTR Gunmetal BE SOLD!
AMS Alpha 9+ Turbo kit/AMS Forged Motor, AMS Alpha Cams & Ferrea springs/retainers, AMS Alpha Induction kit w/TiAl Q BOV's, AMS Race I/C, AMS 90mm Catless DP's, Amuse R1000 No.2 90mm Mid-Pipe, Amuse R1000 GT-RR SPL STTI 90mm catback, AMS Alpha Fuel Rail Kit, ID2000's, Walbro 485 Fuel pumps, ShepTran Stage 2.5 tranny
ADV5.0 20x10.5/20x12.5, Zele carbon sideskirts & fender vents, Rexpeed K Style front Lip, Mines Carbon NACA Ducts, Front grill & Antenna cover, Carbon rear valence, KW Sleeves, SPL rear camber/toe arms, Whiteline front CA bushings, Custom Red Painted Brembo Calipers, Endless MX72's, Stillen Sways and Stainless Brake lines
Finspeed 18x12 F10 monoblock rears w/Nitto NT05R drag radials for track
EcuTek tuned by [email protected]
2012 Lexus ISF - SOLD! Matador Mica Red on Black - JoeZ Exhaust/PPE Headers/BC Coils w/Swifts/D2 Forged Wheels/Lexon Carbon Lip
2015 Audi RS7 - Daytona Gray Pearl, Milltek exhaust, lowering links, Strasse Forged Monoblocks 21x10.5
#13 GTRheritage
GTRheritage
    THAT GUY
  • 4744 posts
Posted 05 December 2012 - 02:22 PM
You know I love my Alpha 12 and Hitman it's gonna take a LOT to get to 7's
#14 Kaizen Tuning
Kaizen Tuning
  • 782 posts
Posted 05 December 2012 - 02:46 PM
Great stuff from a great company.
Kaizen Tuning LLC
Phone - 978 266 9900
Email - [email protected]
HKS Pro Dealer GT1000 Turbo Kits, GT800 Turbo Kits, Legamax Exhausts , Spec R Ti Exhausts, Midpipes, Downpipes - IN STOCK
AMS Performance Center / Alpha Installer
HKS Super sale! Check it out here:
http://www.gtrlife.c...-tuning/</span>
#15 Rguy
Rguy
  • 783 posts
Posted 05 December 2012 - 03:16 PM
Flat out amazing. You can make 1000 WHEEL horsepower these days for the cost of a honda civic.
#16 changstr
changstr
    Nova Uniao
  • 1336 posts
Posted 05 December 2012 - 03:39 PM
No you can't. Minimum I would say is $50k if you are bone stock. Even that's pushing it. I'd say $60-70k bare minimum.
Edited by changster, 05 December 2012 - 03:47 PM.
#17 changstr
changstr
    Nova Uniao
  • 1336 posts
Posted 05 December 2012 - 03:46 PM
#18 [email protected]
[email protected]
  • 12530 posts
Posted 05 December 2012 - 04:01 PM
Those things look amazing!!
Edited by [email protected], 05 December 2012 - 04:03 PM.
[email protected]
#19 HighlanderD
HighlanderD
  • 3540 posts
Posted 05 December 2012 - 04:02 PM
. $50k will get you close on race gas w/ Alpha10s.
#20 [email protected]
[email protected]
  • International Vendor
  • 1378 posts
Posted 05 December 2012 - 04:06 PM
Top notch kit from a top notch company. When you hold it in your hands vs the competition you see why it costs what it costs.
With the GTR being such an investment itself, it would be unfortunate if a GTR got heat damage in the Aluminum chassis areas near the front of the car. The AMS kit fully addresses this and ensures the long term health of your GTR.
Sean
WWW.IVEYTUNE.COM...………Results based
DYNOJET AWD ON PREMISES!!!
ECUTEK PRO Dealer, RaceROM!
Cobb Protuner
Motec USA dealer
Customers:
Sean I 7.54 @ 192.22 Iveytune stage 3 engine, Iveytune stage 5 trans with Promax, Iveytune fuel system, ETS Pro2100, Iveytuned with Motec M1.
Crystal R 7.66 @ 188 Iveytune Stage 3 4.1 Engine, Iveytune Stage 4 Trans with Promax, Iveytune fuel system, AMS Alpha X 6870, Motec M1
Eric S 7.74 @189 Iveytune stage 3 4.1, Iveytune Stage 4 Trans Promax, Iveytune Fuel system, AMS Alpha X 6870, Motec M1
MikeAWD  7.77 @ 182 Iveytune stage 1 Engine, Iveytune stage 4.5 trans, Iveytune fuel system,AMS Alpha16XR kit Iveytuned with Motec (2019)
Juan M 8.01 @ 177 Iveytune 4.1 Engine, Iveytune stage 4.5 trans w promax, Iveytune fuel system, AMS Alpha 12X kit, Iveytuned with Motec m1
Crystal R 8.01 @ 177 Iveytune stage 1 Engine, Iveytune "One G" trans, Iveytune Fuel system, Ams Alpha 12x Turbos, Iveytuned with Motec M1
Joe C 8.01 @179 Iveytune stage 3 Engine 4.1, Iveytune stage 4.5 Trans with promax, Iveytune fuel system, AMS Alpha 16 turbo kit, Motec M1
Dino T 7.92 @ 182  Iveytune stage 3 4.1, Iveytune stage 4.5 trans with Promax, Iveytune fuel system, Iveytuned on Motec m1
Luis 8.36 @ 168 Stage 1 engine, Iveytune "one G" trans , HKS GT1000, Ivey fuel system, Iveytuned with Cobb AP
Juan F 8.68 @ 168 (MH radials) 8.59 @ 162 slicks Iveytune Stage1 Engine, Iveytune stage 4 trans w promax, Iveytune fuel system,AMS Alpha 12 kit, Iveytuned with Cobb AP.
