SpeedBleeders - Check them out
11 replies to this topic
#1 pi-man
pi-man
    OnTrack Maniac
  • 1654 posts
Posted 04 October 2010 - 08:36 PM
I just put my new SpeedBleeders on the car today and they're awesome. A spring-loaded ball bearing automatically opens to let fluid out when you pump the brakes and the returns to seal the bleed screw when you let the pedal back out. Turns brake bleeding into a 1-man job anyone can do. They also sell bleed bags (like a little I/V bag for brake fluid) that can just lay on the garage floor instead of having to keep them upright like a bleed bottle. And, if you order a pair of the bleed bags, you can bleed both screws on each caliper at the same time... :cheers:
Attached File  sbani_1_.gif   41.2KB   65 downloads Attached File  sb1010s_2_.jpg   20.23KB   66 downloads Attached File  bleeder_bag_combo_1_.jpg   56.89KB   50 downloads
At only $7/ea, you should really check these out:
http://www.speedbleeder.com/
(and, if you tell them that pi-man sent you, they'll say "who the hell is that" since they don't know me...) :lol:
#2 35R
35R
  • 862 posts
Posted 05 October 2010 - 03:25 AM
those look great! can you confirm which part number works with the r35? same as the pic above?
#3 thesimones
thesimones
    SuperFly TrackGuy
  • 475 posts
Posted 05 October 2010 - 06:21 AM
Looks like something I need for sure.
2009 Super Silver --Daily Driver & Track Car
Major Upgrades:
SPE750 Turbos
Full Exhaust
Intercoolers
Active Wing
JRZs
(You get the idea...)
#4 descartesfool
descartesfool
  • 2595 posts
Posted 05 October 2010 - 09:14 AM
I've used them on lots of cars, and they work great. I once had an issue with one leaking at the threads when unscrewed to bleed the brakes. They sent me a new one for free, and I didn't even have to send the old one back, and new one worked fine. Never had an issue with spongy brakes when using them either. Some people have reported not being happy with them, but for me they have been just fine.
Looks like SB1010S is the Speed Bleeder model for Brembo calipers as shown in the picture above, Metric M10 x 1.0 x 32.35 long.
http://www.custom-pe...;IDCategory=115
Other choice is from Russell, model 639630, Metric M10 x 1.0 x 33 long
http://www.russellpe...ed/import.shtml
Edited by descartesfool, 05 October 2010 - 09:24 AM.
#5 pi-man
pi-man
    OnTrack Maniac
  • 1654 posts
Posted 05 October 2010 - 08:50 PM
Yes, the one in the picture is the correct model for this caliper.
I also picked up a little bottle of sealer that you can apply to seal the threads if the original wears out after doing a bunch of bleeds. I guess it's not that uncommon if you loosen/tighten them often.
#6 jbmnsx
jbmnsx
    jbmnsx
  • 346 posts
Posted 06 October 2010 - 06:59 AM
Nice find Robert! Don't think I will make VIR this weekend. Haven't gotten an update from AAM. Like I said they are prototyping new coolers on my car so it's taking them longer. Have fun.
2009 GT-R with AAM GT-650 R Package and AAM V2 exhaust, DIY Nav Hack, Aeromotions R2 2 rear wing, APR CF front splitter, CF engine and radiator covers, CF shift surround, AAM hard pipe kit, AAM FMIC, AAM oil and trans coolers, KW Sleeve kit, Carbotech pads, AP J hook front rotors, Umbrella Auto Designs rear ultra suede interior, High volume AAM MAF sensors, four custom made CF rear diffuser fins (contact me if you want a set). Speedware GT-R harness bar with Schroth Profi II ASM harnesses and a Speed for Sale shock tower brace. Four Forgestar 19x10 wheel with Toyo R888 295-30 ZR 19s. Stillen canards and mud flaps. Speed for Sale shock tower brace.
3 AAM custom tunes with on the fly switching
2000 Supercharged NSX
1993 RX-7 TT
2006 MazdaSpeed 6 w numerous mods
2004 Volvo V70R
#7 pi-man
pi-man
    OnTrack Maniac
  • 1654 posts
Posted 06 October 2010 - 02:25 PM
Sorry to hear you won't be there. I was just up at AAM yesterday (differential fluid change) and Clint mentioned that they were working on some stuff for you. Hopefully it will be back up and running for next time. I'll be back at VIR with Trackdaze next month if you're interested.
#8 Bernie (OOParts)
Bernie (OOParts)
  • 513 posts
Posted 10 October 2010 - 06:06 PM
Another alternative if you feel concerned about replacing the stock bleeder valves is a vacuun type system like the Mity-vac. This also turns bleeding your brakes into a 1 man job and you don't have to climb in and out of you car. Just turn on the vacuum, and sit at your brake reservoir to fill it occasionally.
Bernie, OOParts International
1991 Nissan 300ZXTT (Stage XII+ 630 hp)
2002 Subaru WRX (TXS Stage 3 ~300hp)
2008 Mercedes Benz AMG ML63 (stock 503hp... so far)
2009 Nissan GT-R (for the street: Cobb AP stage 1, for the track: stock 483hp)
Track times for GT-R in stock configuration with Bridgestone tires: Homestead- club configuration: 1:41.7, Palm Beach International Raceway - 1:29.7
#9 NickTO
NickTO
  • 3704 posts
Posted 12 October 2010 - 08:33 AM
Edited by NickTO, 18 September 2013 - 10:55 PM.
I am no longer active on this site.
#10 w00tw00t
w00tw00t
  • 470 posts
Posted 27 August 2012 - 10:27 PM
reviving an old thread .. pi-man & descartesfool - how are these holding up for you? I had these on my motorcycle many years ago and were fantastic for bleeding brakes..
also what would be the bleeding procedure with speedbleeders for the gtr? I've never bled a car before and I'm just starting my research..
#11 FiR1
FiR1
  • 284 posts
Posted 06 September 2012 - 04:40 PM
Been using thest on my R1 for years. I should get these for the R35. Completely forgot about it until I saw this thread. Thanks for the reminder!
2012 R35-B/E
#12 descartesfool
descartesfool
  • 2595 posts
Posted 27 September 2012 - 01:19 PM
They just keep on working fine. No issues. I don't drive cars with them in the winter, so no idea if corrosion is an issue, but I don't see that they would be any different than the OEM ones in that respect. Plus thread sealer likely makes them easier to un-screw than plain steel ones.
When you install them, brake fluid will leak out once you remove the OEM bleed screws, so make sure no fluid stays on any painted surface, including calipers. Once Speedbleeders are in, use a bleeder bottle with a clear line to fit over the bleeder nipple. I prefer to have two bottles, one for inside and outside bleed screw on the front calipers. Then just open them both just enough to bleed fluid out and bleed fluid into bottle, making sure you have no bubbles in the clear lines, and that the line is tight over the end of the Speedbleeder. Close them both and brake pedal should be rock hard with the engine off. If not, bleed until you get a rock hard pedal meaning you have no air in the system. Don't over-tighten bleed screws, just a light touch is all that is required, or you can break them. 12-16 Nm or 8-10 ft-lbs is all that is required for Brembo bleed screws typically. Usually start to bleed caliper furthest from master cylinder, so RR, the LR, the RF, then LF. I really see no difference in bleeding front outside or inside first, and OEM service manual does not say which to do first IIRC. When you bleed just one at a time, (usually the outside one first according to some people) most old fluid from caliper will come out the first bleed screw, then very little bleeding required to do the second to get new fluid to come out as the caliper has been mostly flushed of old fluid from the first bleeder (the sides of the calipers are linked via hard brake lines that go between them, so it is just one circuit. But with two bleed bottles, it doesn't matter if you bleed both at the same time. I use Genesis bleed bottles with the cable. There are tons of theories on bleeding brakes. I have tried them all. As long as your pedal is rock hard, it's fine.
http://www.amazon.co...e/dp/B000W7F2GI
