That test is yet to be done....That's indicated speed though, strap on a GPS and the car won't be doing 200mph?
It is 2012/ 2013 stock or the original modded?That test is yet to be done....
It is a modified old GTR.It is 2012/ 2013 stock or the original modded?
Not so fast! Tire size is uknown in our case. Speedometer assumes that stock size tires are being used.... If you change that, you change everything.I ran a Vbox on my last track day (Silverstone UK), at the end of Hangar Straight indicated speed was 155mph and Vbox showed 147mph. So 204mph indicated would be maximum 196mph, which happens to be the factory listed top speed![]()
Then you should have stated the assumption that he's running different size tyres. I'll make the assumption he's running stock tyres and somwhere around the 196mph markNot so fast! Tire size is uknown in our case. Speedometer assumes that stock size tires are being used.... If you change that, you change everything.
sounds like excusesNot so fast! Tire size is uknown in our case. Speedometer assumes that stock size tires are being used.... If you change that, you change everything.
