[background=rgb(246, 246, 246)]Contact me considering all offers of $65,000 or best offer[/background]
[background=rgb(246, 246, 246)]which is more then reasonable for a car of this magnitude and can't be duplicated for less [/background]
[background=rgb(246, 246, 246)]R32 Gtr:[/background]
[background=rgb(246, 246, 246)]Engine-[/background]
[background=rgb(246, 246, 246)]Motor build is Brand new everything and only Dyno time.. [/background]
[background=rgb(246, 246, 246)]>Block maged [/background]
[background=rgb(246, 246, 246)]>proefi 128, with can logger display, flex fuel, airfuel, coolant temp sensor, oil temp sensor, 2x 150psi , map sensor, traction control.[/background]
[background=rgb(246, 246, 246)]>precision 7175 cea Ball Barring turbo[/background]
[background=rgb(246, 246, 246)]>Darton sleeved block[/background]
[background=rgb(246, 246, 246)]>Acl race main bearings[/background]
[background=rgb(246, 246, 246)]>Acl race rod bearings[/background]
[background=rgb(246, 246, 246)]>New frost plugs [/background]
[background=rgb(246, 246, 246)]>Oil from head to bottom end [/background]
[background=rgb(246, 246, 246)]>Saddle aligned and checked [/background]
[background=rgb(246, 246, 246)]>Bored and honed [/background]
[background=rgb(246, 246, 246)]>Balanced rods and pistons [/background]
[background=rgb(246, 246, 246)]>87mm Manley Pistons [/background]
[background=rgb(246, 246, 246)]Pin: 1.193CR: 8.5:1[/background]
[background=rgb(246, 246, 246)]>Arp studs through out [/background]
[background=rgb(246, 246, 246)]>tomei cam cap studs [/background]
[background=rgb(246, 246, 246)]>Carrillo h beam rods with Carrillo studs[/background]
[background=rgb(246, 246, 246)]>Cams are oil fly cut [/background]
[background=rgb(246, 246, 246)]>Tomei 272 cams 10.25 lift, head has been re cut to allow with timing sprockets [/background]
[background=rgb(246, 246, 246)]>Port and polished Tomei +2 lifters[/background]
[background=rgb(246, 246, 246)]>valves are Ferrara +2 oversized with cam locks [/background]
[background=rgb(246, 246, 246)]>New Nissan valve shims [/background]
[background=rgb(246, 246, 246)]>Tomei b springs with cam caps [/background]
[background=rgb(246, 246, 246)]>Tomei oil orifice [/background]
[background=rgb(246, 246, 246)]>Tomei oil holder, [/background]
[background=rgb(246, 246, 246)]>Tomei intake gaskets, [/background]
[background=rgb(246, 246, 246)]>Hks boost regulator [/background]
[background=rgb(246, 246, 246)]>Hks Turbo Manifold[/background]
[background=rgb(246, 246, 246)]>Rips Intake plenum 90mm Throttle[/background]
[background=rgb(246, 246, 246)]>5 inch trust intercooler [/background]
[background=rgb(246, 246, 246)]>Hks turbo out and gaskets [/background]
[background=rgb(246, 246, 246)]>Okada plasma direct coil packs for the r34 Gtr, r32 igniter has be eliminated.[/background]
[background=rgb(246, 246, 246)]>Ross race trigger kit with the race harmonic balancer[/background]
[background=rgb(246, 246, 246)]>tomie head gaskets and engine gasket kit[/background]
[background=rgb(246, 246, 246)]>N1 water pump [/background]
[background=rgb(246, 246, 246)]>Tomie over sized oil pump [/background]
[background=rgb(246, 246, 246)]>fuel system, 3x bosh 044 pumps with the stock intake pump.. Fuel pumps are staged with the proefi to common on a certain psi level and surge tank [/background]
[background=rgb(246, 246, 246)]>FID 1400cc all fuel injectors [/background]
[background=rgb(246, 246, 246)]>Greddy 11mm fuel rail[/background]
[background=rgb(246, 246, 246)]>All Russell and Erals 10an fitting throughout, fuel system, catch can.[/background]
[background=rgb(246, 246, 246)]>2x 50 micron Molly stainless fuel filters[/background]
[background=rgb(246, 246, 246)]>tomie cam gears[/background]
[background=rgb(246, 246, 246)]>HKS 3-plate clutch[/background]
[background=rgb(246, 246, 246)]>HKs 60 MM wastegate[/background]
[background=rgb(246, 246, 246)]>4" Turbo Back exhaust[/background]
[background=rgb(246, 246, 246)]> O.S Giken transmission 1-5 gear sets with holinger input shafts.[/background]
[background=rgb(246, 246, 246)]> O.S Giken Rear diff X[/background]
[background=rgb(246, 246, 246)]> Cusco Font Diff[/background]
[background=rgb(246, 246, 246)]> nismo slave cylinder [/background]
[background=rgb(246, 246, 246)]>Spal 14" electric fan[/background]
[background=rgb(246, 246, 246)]>Rips alternator bracket[/background]
[background=rgb(246, 246, 246)]>koyo radiator[/background]
[background=rgb(246, 246, 246)]>turbosmart fuel regulator [/background]
[background=rgb(246, 246, 246)]>rips pulley set[/background]
[background=rgb(246, 246, 246)]>gt-garage carbon fibre full cooling panel [/background]
[background=rgb(246, 246, 246)]>auto select power steering tank [/background]
[background=rgb(246, 246, 246)]>Auto staff oil catch can with over flow tank [/background]
[background=rgb(246, 246, 246)]>Custom titanium turbo intake[/background]
[background=rgb(246, 246, 246)]>Custom covers for power steering, brake booster and fuse box[/background]
[background=rgb(246, 246, 246)]>nismo engine front strut bar[/background]
[background=rgb(246, 246, 246)]>nismo engine and transmission mounts[/background]
[background=rgb(246, 246, 246)]>Burnt Titanium full engine dress up kit[/background]
[background=rgb(246, 246, 246)]>DEI Gold heat tape all around engine bay[/background]
[background=rgb(246, 246, 246)]>Full engine and engine bay burnt Titanimun dress up bolts.[/background]
[background=rgb(246, 246, 246)]Body:[/background]
[background=rgb(246, 246, 246)]>Full paint job, every panel and modding taking out, Windows, car has been stripped to the bone and repainted with a 3 stage Sher Williams paint.[/background]
[background=rgb(246, 246, 246)]$12,000 paint job.[/background]
[background=rgb(246, 246, 246)]>brand new front windshield and mouldings[/background]
[background=rgb(246, 246, 246)]>brand new rear window mouldings [/background]
[background=rgb(246, 246, 246)]>nismo n1 side skirts [/background]
[background=rgb(246, 246, 246)]>fujimura carbon fibre lip [/background]
[background=rgb(246, 246, 246)]>Ganador Carbon Fiber Mirrors [/background]
[background=rgb(246, 246, 246)]>top secret type 2 carbon fibre rear diffuser[/background]
[background=rgb(246, 246, 246)]>voltex type 3 carbon fibre wing[/background]
[background=rgb(246, 246, 246)]>Sibon carbon fibre hood with aero catch locks[/background]
[background=rgb(246, 246, 246)]>Carbon fibre Nismo n1 air ducks[/background]
[background=rgb(246, 246, 246)]>clear corner signal lights[/background]
[background=rgb(246, 246, 246)]>Volk Rays Gtc Top secret rims in top secret gold, with brand new r888 tires 275/35/18 all around.[/background]
[background=rgb(246, 246, 246)]>Brembo Gran Turismo 6 pot front brakes with cross drilled rotors 370mm[/background]
[background=rgb(246, 246, 246)]>Stock r32 rear brakes with slotted rotors[/background]
[background=rgb(246, 246, 246)]>R32 Gtr tien street flex coilovers[/background]
[background=rgb(246, 246, 246)]>Titanium top secret rear badge [/background]
[background=rgb(246, 246, 246)]Interior-[/background]
[background=rgb(246, 246, 246)]>Motec c125 Dash with logging brand new, connected to the proefi.. Full race digital cluster.[/background]
[background=rgb(246, 246, 246)]>Car has been insulated with Dynamat throughout the whole interior and trunk[/background]
[background=rgb(246, 246, 246)]> Very rare r34 V-spec II front and rear seats in Black[/background]
[background=rgb(246, 246, 246)]> only one ever made Endless 3 spoke steering wheel[/background]
[background=rgb(246, 246, 246)]>Brand new top secret floor mats including trunk mat[/background]
[background=rgb(246, 246, 246)]>Top secret Shifter[/background]
[background=rgb(246, 246, 246)]> Tomie short shifter[/background]
[background=rgb(246, 246, 246)]>Motec c125 dash with logger brand new[/background]
[background=rgb(246, 246, 246)]>fujimura cluster bezel[/background]
[background=rgb(246, 246, 246)]>Very Rare Tial carbon fiber GT-R door still brand new[/background]
[background=rgb(246, 246, 246)]>carbon dipped interior on all plastic panels [/background]
[background=rgb(246, 246, 246)]>HKS torque splitter[/background]
[background=rgb(246, 246, 246)]>works bell quick release [/background]
[background=rgb(246, 246, 246)]>carbon fibre arm rest [/background]
[background=rgb(246, 246, 246)]Extras:[/background]
[background=rgb(246, 246, 246)]>Brand New Gt-Garage carbon fibre Canards[/background]
[background=rgb(246, 246, 246)]>Stock Hood[/background]
[background=rgb(246, 246, 246)]Have all receipts for all the parts bought.[/background]
