1 - 20 of 43 Posts
Just hit 12,000 Miles and I'm due for an Oil Change, my local Nissan Dealer quoted me 130$ for the GT-R. Is this too steep? Would i be better off buying the oil from the nismo shop and taking it to them? They said its about an hour of labor..
Also i have read that at 12,000 Miles or 12 Months i should be getting a POS, should i bring this up to them or should they already know? I believe its a free alignment
Thanks
Thanks
May I know which dealer quote you $130 for oil change? That sounds like a pretty good rate.
· Stop the persecution of Falun Gong
$84.43?!
The oil change for my daily (2011 Maxima) is like $100 (I put the good oil in it as it is recommended and oil is cheaper than an engine).
Thanks
All in all, $130 is reasonable if they do it right. Including oil and filter, sure. That means they're about $80/hour (in the ballpark), at $7 per quart on the oil (in the ballpark), and reasonable for filter and "shop charge".
What about changing the oil yourself?
Changing oil isn't bad.
Usually, people get tripped up on the jacking part. You'll need a fairly low jack. And you'll need a mini ramp just to get the jack under it (in most cases). Now that I think about it, I've got quite the little investment going here:
1. Mini ramps (home made from home depot): $20
2. Jack (2000 lb.): $250?
3. 2 Reverse logic jack points: $80
4. 2 Esco Jack stands: $160
5. Quick release oil valve: $30 (not necessary... just easier).
6. Oil catch can: $8
Some of this I needed anyways just to be able to change tires for track. But if I was only doing it to save money on oil changes, you've really got to place a large value on pride of doing it yourself.
3. 2 Reverse logic jack points: $80 Hockey puck (4): $13-20
5. Quick release oil valve: $30 (not necessary... just easier). Not needed
That's a good price....i paid $78 but with my 09 it was closer to $200....not sure if Nissan has made it easier for the '12s.....
Discussion Starter · #19 ·
Do you remember whom did you talk to that gave you this $130 quote?
I wonder how well is their Service Dept; anyone on board has experience with Puente Hills Nissan service?
I will let you know today as i am taking my car today, i remember him though, he gave me his card but i forgot his name and lost it haha. Will report back
1 - 20 of 43 Posts
