[background=rgb(246, 246, 246)]GReddy RX Throttle Body Kit / IN STOCK[/background]
[background=rgb(241, 241, 241)]The GReddy RX Throttle Kit was developed to take advantage of high volume turbo kits used with the GReddy RX Intake Manifold for high horsepower GT-Rs.[/background]
- LH and RH set of Billet CNC Throttle bodies for VR engine.
- The system uses the factory electronic throttle motors in it's precision machined gears
- 13% Larger butterfly valve - RX 68mm (OEM 60mm)
- Maximum precision machined venturi inner-opening for smooth air flow (not stepped)
- 80mm outer-diameter inlet and 70mm inner-diameter outlet to intake manifold.
[background=rgb(241, 241, 241)]75mm mounting dia., 68mm butterfly dia., 70mm plenum dia. [/background]
[background=rgb(241, 241, 241)]Anodized Aluminum finish [/background]
[background=rgb(241, 241, 241)]*special gasket included [/background]
[background=rgb(241, 241, 241)]**drive by wire motor, acessories & sensors not included (uses OEM) [/background]
[background=rgb(241, 241, 241)]***Must purchase 80-70mm silicone hose reducers (x2) and hose clamps (x4) if using in conjunction with GReddy RX Intake Manifold Spl Piping Kit, part# 13920401 [/background]
[background=rgb(241, 241, 241)]Use with GReddy RX Intake Manifold p/n 13522330[/background]
BENSOPRA IS THE JAPAN IMPORTER FOR HIGH END TUNING PARTS AND AERODYNAMICS PERFORMANCE.
CONTACT US FOR PRICING,
BENSOPRA MOTORSPORT USA
949-887-0894 (CALL OR TEXT)
WWW.BENSOPRA.COM
[email protected]
WWW.BENSOPRA.COM
[email protected]
[background=rgb(246, 246, 246)]OPERATION HOURS: MON-SAT 9AM-6PM (PST)[/background]
[background=rgb(246, 246, 246)]IN STOCK READY TO SHIP AND INSTALL!!![/background]
[/background]
[/background]
[/background]
[/background]
[background=rgb(246, 246, 246)]GReddy RX Billet Throttle Body Kit on BenSopra GTR's[/background]
[/background]
[/background]
