1 - 3 of 3 Posts
Methods of payment
  • CASH ( USD/ CAD) / Wire transfer ( full amount must be deposited and cleared ) prior to shipping or pickup
  • Bitcoin 1.86 bitcoin
if you are looking for good quality parts this is a good start , just depends how deep your pockets are and how crazy you want to go
if you are looking or a show car , you will need to paint or wrap
Brought over from japan to Canada since 2011 , if you are interested pin me directly
before any offers , take the time to understand what each of the parts listed cost
  • 128,000km on body
  • 694whp (800hp+)
  • Body in excellent condition with no rust
  • 128,000km ( in 2011 came with 108,000km)
  • Engine build with less than 5,000km of use
  • N1 24U RB26 Block - NISMO N1-Gen 1 “24U”p/n A1002-24U00( here )
  • Wiseco pistons 8.5:1
  • Eagle Rods + ACL bearings
  • Stock machined crank + Naprec coating + extended crank collarN1 oil pump + N1 water pump + OEM tensionners (new)
  • Greddy aluminium pulleys
  • Fluidampr crank pulley\
  • Tomei baffle in sump
  • Greddy Oil cooler
  • Fully rebuilt head with Supertec overhauled kit
  • Manley valves (sodium exh.)
  • Tomei Type B Poncams + ajustables Tomei cam gears
  • Kevlar timing belt
  • Valve cover -10an fttings to baffled catch can
  • Hot side
  • Precision 6466 Gen2 1.00ar T4 divided turbo
  • Xfactor manifold (flow tested)
  • Tial MVS external wastegates 45mm x2
  • Custom 3.5 inch. exhaust (ceramic coated black)
  • Tomei cat delete
  • Apexi muffler
  • Cold side
  • Greddy Trust intercooler 4"
  • HKS SSQV IV blow off valve
  • Radium Fuel rail + ID1000cc injetors
  • Tomei type-L FPR
  • Splitfire Coilpacks + ingnitor delete
Electronics
  • ECU Master + high/low boost switch
  • Wiring specialities complete engine harness + new oem coilpack harness
  • Apexi AVC-R boost controller
  • Map sensor to ECU
  • Aem wideband gauge to ecu
  • Defi oil presure gauge
  • Defi oil temp gauge
  • Defi water temp gauge
  • Defi boost gauge
  • Bee*R power builder
  • AEM water meth V2 kit + AEM fail safe gauge
  • Exterior
  • Original color is KH2, it was re-painted R35 GTR "desert shadow" color in 2017 (7/10)
  • 3piece Intelesse Gold wheels - 265/35/18 squared
  • Seibon Carbon Hood
  • Cusco radiator panel
  • Co2 spray system to intercooler
  • Nismo front bumper ducts
  • Interior
  • Nardi Steering wheel
  • Nardi shif knob
  • Bride Low Max gradation seats
  • Takata racing seats belts
  • Rear seats removed ( available and sold with the car )
  • Cusco roll cage 5point
  • Carbon fiber pillar
  • Red top battery relocation
  • Co2 Cryogenic kit tank + water trigger (not functional needs rewiring)
  • Digital speedometer
  • Chasis Suspension
  • Nismo engine and transmission mounts
  • Competition clutch twin disk ceramic (rated 1200hp)
  • BC racing coilovers + custom springs
  • Nismo front tension rods
  • GKtech rear camber arms
  • Front axles rebuilt
  • Front Calipers rebuilt
  • DBA disk + Hawk pads all 4 wheels
  • Braided brake lines
  • Misc.
  • ABS delete
  • AC delete
  • OEM oil cooler delete
  • Heater delete
  • Complete engine gasket overhaul kit
Hood Motor vehicle Automotive design Automotive exterior Automotive lighting
Automotive parking light Automotive side marker light Car Grille Hood
Discussion Starter · #2 ·
i don't understand what you are asking for?
just so i am super clear
not my face and photo , but the car ( with a piece of paper with todays date on it ? ) and you want these two photos uploaded where exactly ? as the username section only has 1 photo to upload
1) you want a piece of paper with the hood popped open , vin showing and a piece of paper with todays date in large font
2) you want a 2nd photo , with the same piece of paper with todays date showing the car ( decent size portion ) in this case the car is now in the garage and its freezing cold , and i am not starting it to move it out ( after shoving it garage beside the generator ) so a frontal photo will do ?
is this to prove that the car is real and in my position or something ?
1) updated the methods of payment in post
2) added two photos ( with todays date and username )
let me know i you need anything else
Alberta Oil & Gas
All good now buddy - thank you.
And yes, it aids in proving that the car is in your possession.
Thread cleaned for Classified Ad.
1 - 3 of 3 Posts
