Sold
+1Interesting build and strategy. glwts
Thank you, Danny! By far the best all around car/setup I have ever had, and the next will be better!I can vouch for an amazing car and stand up guy. I bought my GTR from him two years ago.
Car is setup perfect and at this price, nothing can compare.
2015 price tag but with almost 1200hp.
GLWS Tim.
Those are corrected numbers.1168rwhp uncorrected with no cams on gtx30r? I didn't know that was possible.
Many cars have made mid 700's and even over 800 on GT30's and pump gas. Running 93 octane on a 10.1 motor is perfectly fine, many people run pump gas with that compression.What is the most the car can make with 93 octane? I noticed it is 10:1, which is great for E85, not sure how it does with 93.
It's no problem. My tuner can work with you to maximize your power safely on pump gas. I can even put you in touch with him to discuss specifics if you would like.Ok, with that compression I would expect a higher torque figure ... is the timing set lower below a certain rpm to inhibit peak torque because of safety due to a mechanical limitation, like the trans components? Unfortunately where I live E85 is not readily available in many places, hence my questions.
