1 - 20 of 47 Posts
Founder/Admin
Even though the mileage reaches over 1,200
miles (2,000 km), the clutch may take longer to
properly engage if the vehicle is mainly driven in
town at a low speed. NISSAN recommends
breaking in the clutch at a GT-R certified
NISSAN dealer
huh?
Founder/Admin
go to 5-31 thats launch control 4
R MODE START FUNCTION
This function enables the driver to start acceleration from a stop by selecting R mode with the
VDC and transmission setup switch. The engine
output will be maintained at approximately 4,000
rpm. When using the R mode or the R mode
start function, always use proper seating position and follow the safety instructions in Section
1 of this manual
HOW TO USE R MODE START
FUNCTION
position. M& or A& 1. Move the shift lever to the
2. Select the R mode with the transmission
"VDC, transmission and setup switch. (
suspension setup switches" page 5-24)
3. Select the R mode with the VDC setup
switch.
4. Depress the brake pedal firmly with your left
foot and keep depressing the brake pedal.
5. Depress the accelerator pedal quickly to the
floor with your right foot while the brake
pedal is depressed. The engine speed will
increase to approximately 4,000 rpm and
will be maintained.
6. Within 3 seconds after depressing the
accelerator pedal, release the brake pedal.
Founder/Admin
The R mode start function has been .
developed not only for controlling
the engine, transmission and VDC
system, but also the settings of the
suspension and tires. Therefore, any
modification of the vehicle may
disrupt the vehicle's balance. This
will not only reduce the optimum
performance of the vehicle but may
also cause damage to powertrain
components, including the transmission.
If the R mode start function is used .
4 times consecutively, the function
may be disabled and cannot be
turned on to protect the vehicle
system. While the function is disabled, the warning light illuminates.
When the warning light illuminates,
perform cool down driving.
"Cool down" page GTR-12) (
When the warning light turns off,
the function can be used again.
The performance of start may vary .
depending on the amount of wheel
spin, or increase and decrease of
the engine output in response to the
outside temperature. (This vehicle
was set up according to the road
surface conditions of the straight
sections of the Sendai Highland
F8 Raceway course in Japan at 59
C).) 8 (15
VDC control automatically activate .
when driving on a slippery road
surface such when it is wet in order
to apply brakes or limit the engine
output for safety.
Frequent use of the R mode start .
function increases the load on the
powertrain related parts such as the
clutch and transmission compared
to normal driving. In particular, the
clutch will wear out more quickly
Founder/Admin
I also notice they reference Motul Nismo diff oil, is it the 1st year they do that?
Shingo, I found it on the nissan website, but it's not linked to directly from their site until Feb 3.
I still have my '09 .. plan on keeping it for a while
i think its new but i didnt go over the 11 manaul with a fine tooth comb either ... also they spell out alot for performance driving this time aswell
Founder/Admin
They sure do.. Airstrip exclusion!? somehow there's a guy at Nissan that enjoys the Texas Mile
the usual void your warranty disclaimers
Driving with the VDC off, .
Racing, .
Any competitive driving of any sort whatso- .
ever,
Use on a track or driving on any airstrip
thanks a lot for the post, Nick. ... i'll be getting no sleep tonight!
"California Perchlorate Advisor" ... aren't you out of state guys glad that perchlorate can't hurt you?
Awesome post
Founder/Admin
NISSAN dealer
huh?
any insight on WTF that means?
Founder/Admin
Use "DUNLOP SP SPORT MAXX GT 600
DSST CTT" tires specified for 2012 NISSAN
GT-R produced from November 2010. "DUNLOP SP SPORT 600 DSST","BRIDGESTONE
POTENZA RE070R" with/without R2 mark were
manufactured before November 2010 and
cannot be used.
Is this only with 2012s?
On page GTR-8
INCREASE TIGHTENING OF THE
STRUT SUPPORT BAR ATTACH-
MENT SECTION WITH THE SHOCK
ABSORBER
Great post NickTO.
But why is the wording about VDC Off invalidating the warranty still there?
I thought that was sorted YEARS ago and only damage deemed to have been incurred whilst VDC was off would be suspect?
Definitely looks like LC with VDC R is covered though as it is specifically mentioned.
How much slip will the TCM allow in VDC R I wonder? If launching in a straight line, it should hopefully allow a useful amount before cutting in.
1 - 20 of 47 Posts
