1 - 20 of 76 Posts
Just put a Maxima wheel in..No one will notice the difference.
Anyone retrofit it yet?
I contacted a eBay seller who is selling the 17+ Nismo steering wheel. Here is what he said
Good morning, I have not attempted to install a 17+ steering wheel onto a previous year R35. I believe the airbag harness is slightly different and would required to be hardwired. As far as the paddles, once wired they should work but I also think a few other parts maybe required. Thank you for reaching out and let me know if you have any other questions.
The older style shift paddle has 2 pins connecting to it. Im guessing the newer spiral cord must have 4 additional pins for the shifter paddles. If we could find those out, we will be able to slice the wires making a connection back to the 2 pin connector.
It is easily doable.
Awesome, I figured you could. I've PM,ed but figured more people on the forum would need this info. Basically what all is needed besides the obvious wheel and airbag? Clock spring, harnesses, etc...? Thanks for the insight man. Oh and do all buttons on wheel function properly?
I told you already via Pm, this job is easy. Everything bolts right on.
Every time you change your steering wheel you will probably need an alignment though.
1 - 20 of 76 Posts
