1 - 3 of 3 Posts
Over $140k in receipts for the build. Car comes with factory spoiler and factory wheels and tires too. I can send invoice for serious buyers only. Have video's of the car running. Only reason I am even thinking of selling is because Cicio Performance just build my Lamborghini Huracan (the one on TRC). I can handle your financing needs. Trades considered if I am handling your financing.
VIN: JN1AR5EF3KM750107
Engine, Turbo and Fuel System
-Cicio Performance 4.1L Street R35 Nissan GT-R Short Block
Cicio Performance Wet Sump Oiling Upgrade - R35 Nissan GT-R
ARP 625+ Head Stud Kit: Nissan GT-R VR38DET
Alpha Performance R35 GT-R Race X Billet Flywheel
Cicio Performance GT-R Level 3 CNC Ported Cylinder Head Package
Cicio Performance Combustion Sealing Rings
GSC Power-Division Billet VR38DETT S3 Camshaft Set
-Xona 9569S Turbos with custom copressor wheels
-Cicio Performance R35 Nissan GT-R Oil Catch Can System w/ Line Kit - Wrinkle Black
-Cicio Performance Coolant Expansion Tank for R35 Nissan GT-R - Wrinkle Black
-ALPHA GT-R Carbon Fiber / Billet Intake Manifold w/ Secondary Fuel Rail (12 Injector) - Blue
-ETS Super Race Intercooler Upgrade Kit for R35 GT-R
-Tial Q BOV 11 Psi Spring; Blue
-Boost Logic 3.5" Titanium Intakes for R35 GTR without MAF Flange
-ETS Nissan GTR 4.0" (102mm) Stainless Steel Exhaust System
-Cicio Performance Fuel Rail Kit With Regulator - Nissan GT-R R35
-Injector Dynamics ID1700X injector set for R35 GT-R (12 Injectors)
-Fore Innovations GT-R Triple Fuel Pump Module - 3x Walbro 285 Pumps, -8 AN 90 Feed, No Return Fitting
Transmission
-Shepherd Stage 4 Transmission
Dodson Extreme 1-6 Gearset
Dodson Pro Max clutch/Alloy version ( Sheptrans spec )
Dodson Heavy Duty clutch return spring retaining clips
Dodson Piston shaft seals
Dodson FWD retainer
Dodson Mechanical lock #1
Dodson Mechanical lock #2
Dodson Selector Piston Shims x 4
Dodson O-ring and seal upgrade kit
Dodson Oil pump shaft upgrade with blueprint
Dodson Reusable transmission filter
6 neodymium magnets
Dodson High temp rear differential oil seal
ShepTrans FWD ball retainer
ShepTrans Billet front thrust plate
ShepTrans FWD clutch Fluid
OEM Fwd output seal
Dodson 2,4,6 Thrust bearing circlip
Dodson 1,3,5 Thrust bearing circlip
OEM Nissan transmission pan gasket
Transmission and Rear differential Fill plug gasket (2)
Rear differential drain plug washer x1
OEM Nissan Rear differential side seals
GT1R rear diff brace
Arp Rear diff bolt upgrade
Dodson Surge/Baffle kit
Dodson Billet Drag Pan Kit
Dodson Rear Reduction Gears
DSS Pro-Level Rear Axles w/ Rear Axle Stub Shafts for 2015+ R35 Nissan GT-R
Engine Management System
-MoTeC M150 Engine ECU Kit; Nissan R35 GT-R
Safety
-Cicio Performance Welded in Half Cage
Wheels & Tires
-Cicio Performance Exclusive 18" Front Wheel/Radial Package R35 Nissan GT-R - Brushed Blue Gloss
-M&H Racemaster Radials
-Cicio Performance Exclusive 17" Wheel/Slick Package
-Mickey Thompson ET Street R
Wheel Tire Car Vehicle Land vehicle
Wheel Tire Vehicle Car Automotive lighting
Tire Wheel Vehicle registration plate Car Automotive tail & brake light
Wheel Tire Car Vehicle Hood
Vehicle Hood Car Motor vehicle Automotive design
Vehicle Car Automotive lighting Grille Motor vehicle
Rectangle Slope Plot Font Parallel
1 - 3 of 3 Posts
