I updated to the newest firmware version last night and wanted to find out whether I should be factoring actual A/F via the "Old" or "New" tabs?
Ben, seeing that the wastegates are 100% maxed out and the voltage is 4.82 at that level.....do you still feel its important to upgrade as the car currently sits?from going from too rich 85% af correction your now 120% lean
and like i said that 2.75' intake hitting 4.82 not giving much room
AFR new on the AP has been wrong for a very very long time... Thistle had a solution which was implemented in the AP but got lost in between firmware updates.Bringing thread back.
I noticed tonight that if I use the AP to log AFR old is reading 14.4-14.6 as my AFR new is reading 13.2-13.5. But if I switch to Access Tuner and use the computer my AFR new is dead on at 14.5-14.7.
So which is correct? I have the latest firmware on both PCM/TCM
I've got a fix in for testing.I pointed this out again the other day as I hadn't logged with the AP in a long time and then saw incorrect AFR new. They are on the case.
joe,I've got a fix in for testing. Joe
The conversion bug is in the AccessPORT firmware not the software. Which one were you using?joe,
that means we cant relay on the AFR new reading on the latest update as it was spot on with my AEM AFR on the ppreviousVersion. please let me know.
