So I'm currently running the Stage 3 OTS.
My mods are:
Catless DP and MP
Stock Cat
Stock Pump
1000cc Injectors
Cobb Big SF intakes
Cobb Bypass Valves
Before the Catless DP, on the original tune (apparently was tuned with ECUTek, bought the car used).
I would get rear o2 sensor codes (obviously because there were no cats).
I flashed the OTS with the rear o2 codes off, I get P0171.
I was taking a look at my AFR Correction B1/B2, and they are relatively close to each other. Is there anything else I should log? Another unrelated question, but I've read that if we start seeing knock the Boost Gauge will flash, does that mean the stock boost gauge or the one in the AP will flash??
My mods are:
Catless DP and MP
Stock Cat
Stock Pump
1000cc Injectors
Cobb Big SF intakes
Cobb Bypass Valves
