Here at ACG Automotive we pride ourselves on being one of the premier installers of AMS Performance packages for the R35 GTR. Since 2010, we have been one of the premier installers of AMS packages. We pride ourselves on having countless Alpha 7, 9, 10 and 12 package builds under our belts. We have developed an easy guide to give some idea as to pricing on several common upgrades in the GTR world, as well as some intro pricing on larger builds and packages. For the package builds, these are just base prices and can change drastically depending on the addition or subtraction of parts in a build.
Cobb Accessport V3 tuning system - $950
AMS Performance Alpha Packages
Alpha 6+ - Starting at: $5,500.00 Including Installation and Dyno Tuning
This is the basic upgrade package for GTR applications. It produces 600+ wheel horsepower on pump gas and opens the gate to an easy upgrade to Alpha 7 in the future if desired.
-3 inch intake
-1000cc Injectors
-Alpha 90mm Downpipes
-Cobb AccessPORT V3 Tuning System
-Custom Tune
Alpha 6.5 - Starting at: $8999.95 Including Installation and Dyno Tuning
Producing 650 wheel horsepower on pump gas, this package is a fantastic way to wake up your GTR. The addition of the full exhaust allows the car to breath far better, making more power.
-3 inch intake
-1000cc Injectors
-Alpha 90mm Resonated Mid-pipe (race version available)
-HKS Legamax Exhaust System (Other Systems Available Such as Akrapovic,
GTC Titan, Innotech iPE, Meisterschaft etc.)
-Custom Tune
Alpha 7 - Starting at $13,000.00 Including Installation and Dyno Tuning
The Alpha 7 capitalizes perfectly on the stock turbos. Making a reliable 700hp on pump gas, this package is a great option to ease into the Alpha line, while still opening the gateway for further modification down the road. This package utilizes FULL AMS ALPHA bolt on upgrades. This is the ultimate on stock turbos and your choice of fuel, setting you up perfectly for an Alpha 9 upgrade in the future.
-AMS Front Mount Intercooler
-3 inch intake
-Alpha 90mm Mid-pipe (resonated version available)
-1000CC Injectors
-Cobb AccessPORT V3
-Custom Alpha Calibration Map for pump fuel
Alpha 7+ (ACG Spec) - Starting at $16,500.00 Including Installation and Dyno Tuning
The Alpha 7+ Package maximizes the stock turbos. Making a reliable 750hp on pump gas, this package is a great option to ease into the Alpha line, while still opening the gateway for further modification down the road. This package utilizes FULL AMS ALPHA bolt on upgrades in addition to an AMS RACE intercooler. This is the pinnacle of stock turbos with your choice of fuel, and sets you up perfectly for larger turbos down the road.
-ALPHA Race Front Mount Intercooler
-AMS Intercooler Piping
-3 inch intake
-Tial Blow Off Valves
-1000CC Injectors
-Cobb AccessPORT V3
Alpha 9 (ACG Spec) - Starting at: $29,999.95 Including Installation and
Dyno Tuning
The Alpha 9 package is our most streetable package for the GTR. The Alpha 9 offers almost double the stock horsepower, for uncompromising power without any sacrifice to the drivability. Aside from being a little bit louder than stock, theres no way to tell until you put your foot down.
-GTC Titan 102mm Titanium Exhaust
-Alpha 9 Billet Wheel Upgraded Turbochargers
-Alpha Spec Wastegate Actuators
-Alpha Race Front Mount Intercooler
-AMS Induction Kit with Tial Q Blow-off Valves
-Alpha Fuel System Upgrade
-Injector Dynamics 1300cc Injectors
-Alpha Coolant Expansion Tank
-Cobb AccessPORT Tuning System
-Alpha Calibration Map(s) (ACG Spec 3.8L Race Engine required for race gas
map)
Recommended Upgrades to maximize the ACG Spec Alpha 9+ package:
ACG Spec Race Shortblock Upgrade - $9,999.95 Including Labor and Fluids:
-AMS Spec Manley 95.5mm 9:0:1 Forged Pistons Dome/Dish with Upgraded Wrist
Pins
-Manley Extreme Turbo Tuff I Beam Connecting Rods
-New Main Bearings
-New Connecting Rod Bearings
-AMS Alpha Head Stud Kit
-AMS Alpha Main Stud Kit
-Magnetic Oil Drain Plug
-Nissan R35 GT-R Engine Gasket Set
-Engine Balancing
-3 Engine Oil Changes, Delivered with fresh Motul 300v
-Nissan OEM Coolant
-Nissan OEM Spark Plugs
-Nissan OEM Power Steering Fluid
-A/C Evac and Recharge
-Engine Professionally Broken In
ACG Spec Race Longblock Upgrade - $13,999.95 Including Labor and Fluids:
Pins
-New Main Bearings
-AMS Alpha Camshafts
-Ferrea Intake Valves
-Ferrea Exhaust Valves
-Ferrea Valvesprings
-Engine Balancing
-Nissan OEM Coolant
Alpha Ronin, 10, 12, 14 and 16 Packages Available
ShepTrans Stage 2.5 v2 - $6,995.00
-Dodson 1st gear set
-Dodson/Exedy 8 disc clutch
-Dodson Forged A basket
-Dodson Forged B basket
-Sheptrans custom clutch Snap Rings
-Dodson Piston shaft seals
-Dodson FWD retainer
-Dodson Mechanical lock #1
-Dodson Mechanical lock #2
-Dodson O-ring and seal upgrade kit
-Dodson Oil pump shaft upgrade with blueprint
-Dodson Output shaft end float shim
-Dodson 2,4,6 Thrust bearing circlip
-Dodson 1,3,5 Thrust bearing circlip
-Dodson Selector Piston Shims x 4
-6 neodymium magnets
-Dodson High temp rear differential oil seal
-Dodson Stainless re-usable internal filter
-OEM Fwd output seal
-OEM Rear Differential Axle Seals
-Oem Nissan transmission and rear differential drain plug gasket
-Oem Nissan transmission and Rear differential fill plug gasket
$1196 - PPG Rear Reduction gears
$450 - ShepTrans Viton piston seal upgrade ( 2009-11)
ShepTrans One-K Transmission - $14,995
-PPG V 2.1 Nissan GTR R35 6spd H/C Synchro Set
-ShepTrans/Dodson 18 plate clutch
In Addition to modification packages such as the above, we offer competitively priced maintenance as well as an endless list of cosmetic and performance modifications. We are proud to carry AMS, Akrapovic, IPE, HKS, Cobb, Meisterschaft, Amuse, Aeromotions, GTC, Wald International, Zele, Password: JDM, Technocraft, C-West, ADV.1, HRE, BBS, Forgestar, Brixton Forged, Klassen, DPE, KW, JRZ, Volk, Advan, Brembo, Alcon, Endless, and many other fantastic products.
Please Comment, PM, or Email me at [email protected] if you have any questions.
-3 inch intake
-1000cc Injectors
-Custom Tune
-3 inch intake
-1000cc Injectors
-Custom Tune
-3 inch intake
-1000CC Injectors
-Cobb AccessPORT V3
-3 inch intake
-1000CC Injectors
-Cobb AccessPORT V3
Dyno Tuning
map)
Pins
-New Main Bearings
-Engine Balancing
-Nissan OEM Coolant
Pins
-New Main Bearings
-Engine Balancing
-Nissan OEM Coolant
