About time we got some AMS Alpha 12 action Down Under.
I was originally looking at the Alpha 10 kit but in the end the lure of 1,300 odd horsepower kept calling. I pulled the trigger on an Alpha 12 kit that will be built by the guys at AMS and shipped down under. A big thanks to Jeremy at Speed for Sale for sorting this all out and sourcing everything for me and to Eric at AMS and also Handbrake for answering my questions. The car already has substantial mods to strengthen the trans, gearbox etc so I'm looking forward to getting this all fitted up and running: The full spec list including the upcoming AMS gear is listed below:
AMS 4.0 liter crate motor with:
AMS sleeved forged shortblock
AMS Spec JE Pistons
AMS Extreme duty Rods (Manlet manufactured)
AMS CNC machined cylinder heads
AMS alpha spec Kelford cams
Ferrea Competition Plus +1mm intake valves
Ferrea Competition Plus +1mm exhaust valves
Ferrea dual valve springs and titanium retainers
AMS Spec head studs
AMS Engine block strengthening
AMS Alpha 12 turbos
AMS 90mm catless downpipes
AMS Intercooler
AMS intercooler piping
AMS Fuel Rails
Injector Dynamic 2000cc injectors
Gotboost 3" intake pipes
The trans and cooling mods are already in place with all of the Willall gear.
Willall items:
Front Mount Transmission Oil Cooler (WR35TC)
Rear Diff Cooler (WR35DC)
Front Diff Cooler (WR35DC-F)
Water misting cooling system (WR35MS)
High Volume Oil pan (WR35OP)
Trans fluid (WR35TM)
Diff Fluid (WR35DF)
Motor Oil (WR35MO)
GR6 Gearbox seals (WR35GS)
GR6 Gear Stops (WR35GS)
GR6 piston seal replacement (WR35PS)
GR6 Transmission pressure unit (WR35TPU)
Clutch retaining clips (WR35CCL)
High performance Syncro baulk ring (WR25BR)
GR6 14 plate composite clutch pack (WR35CPR)
Isometric transmission mounts (WR35GM)
Transmission brace (WR35TB)
Rear LSD Super lock kit (WR35DS)
Camber Arms (WR35FCA / RCA)
Performance Mid pipe (WR35MP)
Centre exit straight through exhaust (WR35CE)
GTR Brake Cooling system (WR35WS)
Engine Management Tuning (WR35TU)
Anti Surge Fuel System (WR35FS)
Shift light (WR35SL)
Trunk supports (WR35TSP)
The other mods already on the car are:
PPG 1st gear set
HKS Super Sequential BOV Kit
HKS A/F Knock AMP Sensor
HKS super fire spark plugs
AAM engine oil cooler with custom fabricated lines
Switzer Cooling kit
Aeromotion S2 rear wing
Volk TE37 G2 wheels
Yokohama Advan A005 20" slicks
Penske / AP Racing 3 way adjustable coil overs
AP Racing Carbon Ceramic Matrix brake kit
Forged Performance Anti-Sway bar kit
Stillen stainless steel brake lines
Custom Endless Brake pads
Top Racing carbon bonnet
Top Racing carbon front and rear bumpers
Top Racing carbon doors
Velo Apex driver and passenger Carbon seats
Hopefully Eric can post some pics up during the engine build....please...
Will keep the thread updated throughout the install process. Looking forward to firing up the first Alpha 12 in Australia.
AMS Spec JE Pistons
AMS Spec head studs
AMS Alpha 12 turbos
AMS Intercooler
AMS Fuel Rails
Willall items:
Diff Fluid (WR35DF)
Motor Oil (WR35MO)
PPG 1st gear set
Switzer Cooling kit
Volk TE37 G2 wheels
