1 - 5 of 5 Posts
2015 White on Black Premium: 1436whp/1054wtq on E90, built by Cicio North
Are you looking for a dyno graph with stock cams or Tomei 274s?
I have a dyno graph of my old setup with 58mm turbos and GSC S2 cams which are 274° Adv duration.
Hi,
Looking for a dyno graph with Tomei 274s with 58mm turbos. S2 dyno graph are also interesting. Thanks
Slope Plot Rectangle Font Parallel
The pink line is E85 and the red is 93 octane pump gas. This pull was 36psi if I remember correctly. This dyno in particular reads a tad lower than a typical Dynojet. This setup is 58mm turbos in the stock frame and GSC S2 cams which are nearly identical to Tomei 274s. These heads are mildly ported and the springs were upgraded among many other accompanying mods to support the power.
1 - 5 of 5 Posts
