Hello all! I am currently in the process of researching a good build. I was curious if I could get some recommendations from all of you. My goals are for around 600whp, but I am not stuck to a number by any means. I purchased the car with some light mods which are: Harman Motive CAI, HKS Superior SpecR Full Exhaust, CBRD Y-pipe. I am not married to these mods either, so I have no problem swapping them out. I have another thread going about exhaust note, so I will more than likely be swapping out the mid-pipe. The exhaust I plan to keep for now till this build is complete to see how it sounds then. I was also unsure if there was a better CAI out there, or what I current have will work. The following mods are what I was recommended to get:
Full exhaust, actuators, intercooler, intercooler piping, BOVs, Fuel Pumps, Injectors, Intakes and a tune, down pipes.
I just purchased a Boost Logic Intercooler, thank you pcasso87!, so that takes care of that part. I have also been lurking around the classified section for some of the other items. My biggest issue with being so new to the car is that I don't know what brands are the better more reliable ones to get, I am unsure of sizes to get i.e. injectors, fuel pumps or systems, Cobb AP 005 or 006, and other small issues like these. The only thing I have decided on are the AMS downs, and probably some type of suction pipe/kit. Everything else is just kind of out there.
Also, as I do this build at what point should I have to worry about upgrading engine, transmission, and other things. I really don't want to do any of that because the car is still actually under warranty, so if something happens (and I can be lucky enough) I want to TRY and keep it warratyable.....
The car is a 2009 with about 25k on it also... Almost forgot that.
Thank you ahead of time for help on this!!!
