It's really hard to strike a balance...each has +/-'s. And...the surface you are on can play a huge role too. 888's are probably your most neutral bet.I'm looking for better traction on my car I have Advan gts with MPSS tires , they just don't hook up well with 900hp what else is better and worth the $ , still want to street / track the car and have it ride good
That burns clutches and you will find out the repercussions of that shortly(if you haven't already), and your 20s are the reason you cook tire through 3 gears. In my experience anything close to the 1000 hp mark or above will need a much stickier tire then the r888 to actually use that power. So I say once again 18 with a M&H and you will be hooking up much better, I run them with 1300 whp on the street and track and I get awesome traction for the most part.I like my 20s
The noise is why I'm still on mpss.... I'm afraid the noise would kill me. That and I can't come to terms with having 315s on my car instead of 335s.![]()
I trust your advice sadly I was gonna try to use r888sThat burns clutches and you will find out the repercussions of that shortly(if you haven't already), and your 20s are the reason you cook tire through 3 gears. In my experience anything close to the 1000 hp mark or above will need a much stickier tire then the r888 to actually use that power. So I say once again 18 with a M&H and you will be hooking up much better, I run them with 1300 whp on the street and track and I get awesome traction for the most part.
If oyur car is making 900whp, the noise it is creating will likely be louder than the R888. There is a lot of road and mechanical noise to begin with on these cars.Man this is hard choice,,, r888 people say are unbearable noise daly driving and don't know about the Nt-01s
Tried the NT01R ... it suckedMan this is hard choice,,, r888 people say are unbearable noise daly driving and don't know about the Nt-01s
Don't get me wrong ... the R888 is one of the best tires I have been on, but when stacked up against a 18 inch rim + drag radial, there is no comparison ... the latter is far superiorI trust your advice sadly I was gonna try to use r888s![]()
