ALL BLACK FRIDAY PRICING HAS BEEN EXTENDED THROUGHOUT CYBER MONDAY. (Valid until 12:00AM 11/29/11)
BLACK FRIDAY! PM|CALL|EMAIL for quote's on ANYTHING. Ridiculous pricing on EVERYTHING going out the door. CALL or PM FOR QUOTES ON SKUNK2|EIBACH|GRIMMSPEED|HKS|GSC|KELFORD|FIDANZA|ARP|AEM|COMETIC|MANLEY|WISECO|CARILLO|TEIN|PERRIN - NAME IT 631.414.7449
If you don't see it here, just ask!
Brian Crower Pro Series Connecting Rods
Made from premium, 4340 steel billet material, Brian Crower connecting rods are available in two distinct styles depending on horsepower, budget and engine application, but both include the exclusive Brian Crower oiling groove in the pin bushing for added oiling.
The bROD Series is intended for moderate boost applications and all motor race applications where peak horsepower is not going to exceed 700 at the flywheel. Utilizes venerable ARP2000 fasteners.
The BC625+ Series rods are designed for high horsepower, high boost and extreme rpm applications where nothing but the best rod will do. Features include ARP's premium Custom Age 625+ bolt rated to 280,000 p.s.i. for ultimate fastening capabilities as well as aluminum-bronze bushings to insure long, reliable service, no matter what the boost, nitrous or RPM.
Notes: Connecting Rods; I-Beam; w/ARP Custom Age 625+ Fasteners; Set of Six
Manufacturer: Brian Crower
Rod Length: 6.496"
Retail: $1405.00
TOPLEVEL: PM or call 631.414.7449
Mishomoto Performance Radiator:
Whether you are a daily driver looking for an upgrade to your OEM radiator, or a racer looking for a dependable quality radiator, we have just what you are looking for! Mishimoto Performance Radiators are 100% brazed aluminum, ensuring a lasting lifetime of efficient cooling.
All Mishimoto Performance Radiators come with a 1 Year Warranty and most include a 1.1BAR Mishimoto Radiator Cap.
Retail: $700.00
TOPLEVEL: $525.00
GReddy Oil Cooler Kit
GReddy/GREX Oil Cooler Kits help prolong the life of your oil and in turn your internal engine components. Hard driving causes higher engine temperatures. GReddy/GREX oil coolers are an excellent addition, and are especially effective in harsh driving environments. By using a similar inner-fin core design as our famous intercoolers, we are able to increase oil capacity, decrease oil temperatures, and extend engine and oil life. Our systems also offer an internal (or external) thermostat (opening range 71-85 C) to allow for quick engine warm up. The efficient core and durable steel-braided lines ensure good flow and a leak free installation.
RETAIL: $3050
TOPLEVEL: $2750
GReddy Intercooler Kits:
RETAIL: $3,175.00
Turbosmart Blow Off Valves - Kompact Series - Plumb Back:
The Kompact Series BOVs have been designed as a bolt-on replacement for plastic factory Bosch or Denso BOVs, the Kompact Series products offer superior flow, full adjustability and greater structural integrity under boost.
Retail: $179.99x2 (2 Required)
Turbosmart Blow Off Valves - Dual Port:
All Turbosmart BOVs are made out of tough and durable billet aluminium and offer a host of features designed to give them superior flow and performance. Turbosmarts Universal Fit BOVs have been developed to fit most popular makes and models and come supplied with pictorial fitting instructions on a CD.
*DESCRIPTION* Three BOVs in one. The Dual Port can be configured to vent to the atmosphere, back into the air intake or both! Hybrid technology allows the user to convert a Dual Port to a Plumb Back or to a Supersonic.
RETAIL: $359.99
TOPLEVEL: $300 SHIPPED
Cobb 09+ Nissan GTR Dual Blow Off Valve Kit
The COBB XLE BOV can operate in one of three modes with simple adjustments. Full recirculation is achieved by plumbing the primary output back into the intake pre-turbo with the auxiliary port closed. Full atmosphere is possible by opening both the primary port and auxiliary port to atmosphere. A hybrid mode is also possible by pluming the primary port into the intake and leaving the auxiliary port open to atmosphere, causing much of the air to recirculate to retain driveability, while still creating an audible exhaust of some of the boost pressure.
Spring preload determines the pressure differential across the BOV piston required before the BOV opens and releases the pressurized intake charge. The COBB XLE BOV can be adjusted by loosening the locknut and turning the hex-head shaft clockwise for more preload or counter-clockwise for less preload. Once preload is set, the locknut is retightened and ensures the adjustment is secure.
Materials used to construct the COBB XLE BOV ensure ease of maintenance and long service life. The mounting flange, body, vent cover and piston are constructed of 6061 T6 aluminum, the spring seat is made from 303 stainless steel and the primary outlet is polished cast aluminum. O rings are used around the piston and on the mounting flange to ensure optimal sealing. The valve body is hard anodized for strength and corrosion resistance. The piston is dry filmed lubricated, providing enduring maintenance free service.
RETAIL: $595.00
Cobb 09+ Nissan GTR Black 12 piece Turbo / Intake Silicone Hose & Clamp Kit
COBB Tuning Silicone Hose Kit replace the stock rubber and plastic connections to the intake, turbos and intercooler with high-quality silicone hoses which reduce ballooning under boost and are more resistant to high heat and high pressure.
Boost hoses are 4-ply steel reinforced for additional strength and resistance to deformation under pressure and vacuum. The short run intake hoses and straight couplers are 5-ply silicone for additional flexibility and ease of installation. All hoses have smooth inner wall surfaces for improved airflow.
*Specifiy BLUE or BLACK*
RETAIL: $695.00
